LED Exterior Lighting Help - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-16-2011, 05:32 PM   #1
PhillyPhocus
PhillyPhocus's Avatar
Fan#: 75919
What I Drive: 2010 Black SE Coupe
FF Reputation: 1 PhillyPhocus Good Standing Member
So what would I need to do/ know to change my brake lights, back-up lights, front turn signals, and side markers to LED's? And if this is do-able, where is the best place to order these kind of LED's? Thanks for any help folks!
PhillyPhocus is offline
Old 12-16-2011, 10:06 PM   #2
misfire
Moderator
misfire's Avatar
Fan#: 31379
What I Drive: 2012 SEL Hatch, 2014 Mazda CX-5
Points 17,083, Level 83
Points: 17,083, Level: 83 Points: 17,083, Level: 83 Points: 17,083, Level: 83
Level Up 47% Completed
Forum Activity 7%
FF Reputation: 31 misfire Great Standing Member
Buy-Sell-Trade Rating: (13)
here is the WEBSITE i just got my led tag lights from. this link will take you to the bulbs i got. they dont have much there. most people use this WEBSITE
Will aka Misfire
2003 LX "traded in"/2010 SES "traded in"/2012 SEL Hatch "current"
misfire is offline
Old 12-16-2011, 10:20 PM   #3
uh60james
uh60james's Avatar
Fan#: 6968
What I Drive: 2010 Sterling Grey SE Sedan
FF Reputation: 6 uh60james Good Standing Member
I would go with the first link misfire posted for tag lights. There have been complaints about the bulbs from the second link flickering after being installed for some time, this is probably due the tag light sockets putting out around 14.5v. The 42 draft design bulbs are made to handle that higher voltage.
Check out his second link for your other exterior lights. They have a vehicle application guide where you just input your vehicle info and it will show you which bulbs fit but be sure to double check what it tells you. For the turn signals you will need to install load resistors or you will get the fast blink you get when one of your signals is out. All other lights should just be plug and play.
Team Duratec #39 / Sedan Revolution #35
uh60james is offline
Old 12-16-2011, 10:39 PM   #4
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
also check out www.oznium.com they have been well used and liked by many on here and other forums.
to change them you will need to remove the headlights and taillights (not hard to do, follow instructions in owners manual for changing bulbs). i wouldn't bother with the front side markers as they have a lense over them and will be less noticable of a change. for the brake/turn lbulbs you will need a bulb that has leds on top and around the sides since that bulb mounts from the bottom facing up rather than aimed to the back like previous models.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 12-16-2011, 11:58 PM   #5
PhillyPhocus
Fan#: 75919
thanks for all the help guys, but what exactly is a load resistor, and how do I install it? Do they require extra wiring, or is it something I just plug into the bulb or socket? BTW i actually already ordered LED's for the tag lights from 42draftdesigns and they work great, and my interior and trunk bulbs came from superbrightleds.com and they work awesome too.
Old 12-17-2011, 02:49 AM   #6
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
What I Drive: '03 SVT EAP "Eurotrish"
Points 2,125, Level 27
Points: 2,125, Level: 27 Points: 2,125, Level: 27 Points: 2,125, Level: 27
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 22 Sniper Focus Great Standing Member
A load resistor simulates the draw of a filament bulb to fix the turnsignal hyperblink issue that LED bulbs have. Since LEDs draw little current the car thinks that a turnsignal bulb is blown and the resistor fixes that.
You just wire the load resistor inbetween the tunsignal/brake 12v wire to the ground wire or chassis ground. I got some Platinum 3157 tail light bulbs from V-Led's and some load resistors and I love them. I also have the 42 draftdesigns plate bulbs.
Sniper Focus is online now
Old 12-17-2011, 03:37 AM   #7
roswelltop
Fan#: 83279
What I Drive: 2014 Ruby Red Titanium Hatch
Points 2,414, Level 29
Points: 2,414, Level: 29 Points: 2,414, Level: 29 Points: 2,414, Level: 29
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 14%
FF Reputation: 1 roswelltop Good Standing Member
Member uh60james said "...Check out his (misfire's) second link for your other exterior lights. They have a vehicle application guide where you just input your vehicle info and it will show you which bulbs fit but be sure to double check what it tells you."
However, I did not see reference to the link--for the headlights, fogs, tails, etc.
Thanks guys.
roswelltop is offline
Old 12-17-2011, 05:56 AM   #8
PhillyPhocus
Fan#: 75919
Awesome thank you, just 2 more questions... looking at the load resistors page of V-LED's, there's a few different types. Which one would I need for the amber front turn signals and rear brake/turn signals. And last question, probably a really dumb one... do I get red bulbs for the rear or super white. Just wasn't sure because it's in a red housing.
@roswelltop, just go to V-LEDS.com and click on the picture in the top left hand corner. That'll connect u to a reference guide.
Old 12-17-2011, 06:35 AM   #9
roswelltop
Fan#: 83279
Forum Activity 14%
Ross, thanks for the info.
Former resident of East Falls neighborhood of Philly here.
Old 12-17-2011, 11:59 AM   #10
uh60james
uh60james's Avatar
Fan#: 6968
If you still want to look at superbrightleds check this link roswelltop http://www.superbrightleds.com/vehic...d/focus/20/533
