Installing Heated Mirrors - Page 16 - Focus Fanatics
Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus
Old 09-09-2013, 01:41 PM   #151
flyboyike
Fan#: 98206
What I Drive: 2012 Race Red SE sedan
FF Reputation: 3 flyboyike Good Standing Member
My hat's off to y'all, all kidding aside.
flyboyike is offline
Old 09-13-2013, 01:19 AM   #152
wylee
Fan#: 116984
What I Drive: 2013 ST1
FF Reputation: 1 wylee Good Standing Member
A few pics. I didn't take a lot as I didn't have a helper and most of the process would be self explanatory for someone experienced enough to want to tackle this project anyway.
C238 connector (pic from an earlier post):
The green arrow points to the blue 18 gauge wire coming out of the Delphi pin I add to C238 behind the glove box. This for the mirror heat. This is the only place I ended up using a terminal pin that needed a terminal crimper.
Driver's door module:
The lower driver's door module connector were I removed pins to make the inside the door connections. You can see the bottom row is numbered 13-24 (left to right) thus making the top row 1-12 (left to right). I removed pins 6 & 7 in the center of the top row:
Passenger's door module:
The upper passenger's door module connector were I removed pins to make the inside the door connections. You can see the top row is numbered 13-24 (right to left) thus making the bpttom row 1-12 (right to left). I removed pins 6 & 7 in the center of the bottom row:
wylee is offline
Old 10-28-2013, 09:08 PM   #153
wylee
Fan#: 116984
Is anyone interested in my C339 connector with pigtails? I removed B2, B3, B4, & B5 for my project. There are no 18 gauge wires left, but there are enough 20 gauge wires to do another heat and puddle upgrade. This connector was removed from an ST, obviously with door modules. I put it in the for sale section. http://www.focusfanatics.com/forum/s....php?p=4912906
I think I can also throw in a couple of the Delphi pins for C238; I just need to make sure I can find my spares.
wylee is offline
Old 02-25-2014, 07:30 PM   #154
koopiskeva
Fan#: 106078
What I Drive: 2013 Focus ST
FF Reputation: 1 koopiskeva Good Standing Member
Thanks for the info wylee. Has anybody else attempted this from his write-up? I'd been meaning to upgrade mine to heated mirrors as well, but have just not had the time. And from reading this, doesn't seem as it as I thought it would be.
koopiskeva is offline
Old 02-26-2014, 04:09 PM   #155
wylee
Fan#: 116984
Honestly, after going through a winter, I'm not sure I'd spend the money again. The Focus mirrors just don't seem to collect frost the way my prior cars did.
I do like the puddle lights but that alone is probably not worth the cost of new mirrors.
wylee is offline
Old 02-26-2014, 04:25 PM   #156
koopiskeva
Fan#: 106078
Well, I applaud the effort then and thanks for letting us know!
Old 04-07-2014, 03:25 PM   #157
JStump2490
Fan#: 154402
What I Drive: 2013 TS ST
FF Reputation: 1 JStump2490 Good Standing Member
Has anyone done a write up on this yet? I want to do it but the instructions seem a bit vague to me. I need some pics of where the wires are feeding from the mirror to the module inside please and thanks.
JStump2490 is offline
Old 04-07-2014, 03:59 PM   #158
novus
novus's Avatar
Fan#: 107022
What I Drive: '12 Tuxedo Black Focus SEL
FF Reputation: 2 novus Good Standing Member
Originally Posted by wylee View Post
The driver's side mirror is on and wires have been run. I added pins to empty slots A9 & A10 at C339. I was able to get the C339 connector out without taking the door off by squeezing the rubber boot down. The back side of C339 is a bear to access.
For the connections inside the door, I pulled pins 6 & 7 from C501B, cut the pins off, and connected the new wires I ran through C339 A9 & A10.
The connections are not tied into the car yet. The heat will be connected to C238. The puddle lamps will be tied into a relay behind the glove box that will be fired by the passenger footwell lamp
Heat is now connected and working. The mirrors get nice and warm in just a couple minutes @ 66 F outside temp.
Puddle lamps will have to wait for it to stop raining.
I was able to get the C340 housing out without removing the door as well. I used the only two empty pin slots for my pins (A3 & B8) or (A8 & B3). I can't remember which number went with which letter.
The connections inside the passenger door were essentially the same as the drivers door. I removed pins 6 & 7 from C652B, cut the pins off, and connected my newly run wires to the pin 6 & 7 wires.
Interesting mix and match on my front speakers...the driver's side had a poly cone, a much bigger magnet, and some extra "stuff" at the speaker wire connection. The passenger side had a paper cone with smaller magnet.
Nope.
But look above.
He pointed out all the details.
novus is online now
Old 04-07-2014, 04:04 PM   #159
wylee
Fan#: 116984
Originally Posted by novus View Post
Nope.
But look above.
Thanks.
I was just looking through to see what I missed. I don't see anywhere to add anything.
wylee is offline
Old 04-07-2014, 04:17 PM   #160
novus
novus's Avatar
Fan#: 107022
Thanks.
I think what he's looking for is a set, set of instructions. Start to finished.
Pictures showing which connector, where it's found. Which pins to add to what connector and where.
novus is online now
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
