C.O.P. conversion - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-21-2013, 12:21 PM   #31
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.0L Zetec)
Points 372, Level 7
Points: 372, Level: 7 Points: 372, Level: 7 Points: 372, Level: 7
Level Up 44% Completed
Forum Activity 6%
FF Reputation: 1 GhostTribute Good Standing Member
Originally Posted by jdmzx5 View Post
I have been told by engineering that it's a risk to burn the drivers, and pcm prices are high. Also I've replaced many pcms with failed drivers due to bad coils and high resistance power circuits to the coils. The factory setup fires one coil, then when the field collapses, the other coil fires, the system Fires multiple sparks below 2500 rpm, and the rest is waste on compression and exhaust. What is your reasoning for disliking waste spark? Getting rid of it won't free up power
Ok so then in this instance my COP setup fires 2 coils at one instance. However, it still requires less amperage to fire them both than it does to fire the stock single coil. I still don't see how the drivers are going to burn up with my setup? From computer to spark pug tip it has less resistance than the stock setup did.
I have two spare PCM's here that I bought for under $100 at the local scrap yard... not sure where you are getting your prices, unless you are a tech @ a dealership replacing them with brand new units?
Why don't I like wasted spark,
I don't see the need to waste spark on the exhaust stroke. I would rather fire my coils once per 720 of engine rotation then twice. Seems like it would be much easier on the system to have them only fire once. Then all these worries about overheating or burning drivers and other system components would be cut in half.
GhostTribute is offline
Old 07-26-2013, 10:26 PM   #32
Hardline
Fan#: 117092
What I Drive: 2000 ZX2 Turbo
Points 381, Level 7
Points: 381, Level: 7 Points: 381, Level: 7 Points: 381, Level: 7
Level Up 62% Completed
FF Reputation: 1 Hardline Good Standing Member
I am running VW/Audi 4 pin coils on mine. Full Sequential as well. How, might you ask? Megasquirt3
Hardline is offline
Old 08-02-2013, 02:38 PM   #33
GhostTribute
Fan#: 107929
Points 372, Level 7
Forum Activity 6%
Would much rather be running smart coils fully sequential as well. I have 2 sets of Honda K series 3 wire smart coils that I will end up using when I finally decide to swap in my ITB's and tune with my MS3. ;)
For now I'm just playing with stuff I have laying around the garage!
Old 02-19-2014, 04:39 PM   #34
GhostTribute
Fan#: 107929
Points 372, Level 7
Forum Activity 6%
Finally got around to mocking up a set of my Honda K series coils with the aluminum valve cover and spare cylinder head. Took me a little while to get everything lined up, cut out and drilled on the cover plate.... Thankfully first one worked out.
Old 02-19-2014, 04:56 PM   #35
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
Way too tall.
Buy shorter boots and you can get them to sit flush.
iminhell is online now
Old 02-19-2014, 05:05 PM   #36
GhostTribute
Fan#: 107929
Points 372, Level 7
Forum Activity 6%
I'm not 100% but I think these are a fixed length coil. The boots are only 0.5" tall. Besides, the 1/2" extra length will help keep the ignitor and coil cool. Once the individual throttles and air box are installed you won't even notice them.
Cost me $50! I'm not really looking to put a lot of money into this build...... The engine management will be the most expensive part. Everything else will be in the rat rod tradition of throwing available parts at it and if they don't fit, you make them fit....
Old 02-19-2014, 08:13 PM   #37
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,506, Level 100
Points: 52,506, Level: 100 Points: 52,506, Level: 100 Points: 52,506, Level: 100
Level Up 0% Completed
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
There has been a lot of guys do this over the years , its all for looks and wont hurt anything in the ECU , no performance gains come from adding the COP
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 02-20-2014, 12:13 AM   #38
GhostTribute
Fan#: 107929
Points 372, Level 7
Forum Activity 6%
If there are no gains to a COP system. Why is it that pretty much every auto manufacturer switched to fully sequential ignition with a coil on plug per cylinder? I will agree that there really are no gains to be had going COP on a wasted spark system and a stock or ROM/flash tuned ECU.
Wasted spark and single CDI coils are old tech. Individual coils are for more than just looks. Specially when you have an EMS that will allow you to make use of them and individually tune them for better emissions and power per cylinder.
Old 02-20-2014, 12:13 AM   #39
GhostTribute
Fan#: 107929
Points 372, Level 7
Forum Activity 6%
It's an added bonus that they look really cool.
Old 02-20-2014, 12:23 AM   #40
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,444, Level 100
Points: 140,444, Level: 100 Points: 140,444, Level: 100 Points: 140,444, Level: 100
Forum Activity 59%
Activity: 59% Activity: 59% Activity: 59%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Emissions plane and simple.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
