Something's wrong with my Cruise Control... - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-03-2012, 10:47 PM   #11
mccreet
Fan#: 93598
What I Drive: 2002 black/lime green zx3
FF Reputation: 1 mccreet Good Standing Member
I ve replaced steering wheel switch,servo 3 times, checked fuses, and brake lights and i hope this procedure somebody posted will save me.
mccreet is offline
Old 02-06-2012, 02:54 PM   #12
spiller
spiller's Avatar
Fan#: 75607
What I Drive: 11 Sangria SE sed, 01 Wht SE Wagon
FF Reputation: 1 spiller Good Standing Member
CC Servo $480 or the junk yard...
Yea, hope for a switch or cable issue.
spiller is offline
Old 02-06-2012, 04:26 PM   #13
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
Those servos can be fixed. My moms 05 ZX3 has a dealership installed cruise control, and awhile ago the cruise stopped working. I had dealt with cruise control problems in the past so I knew what was involved, and after finding no problems elsewhere I looked at the servo and shook it and could feel/hear parts loose inside the servo box. Took it apart and found that some screws had come loose from the plastic gear mechanism. Fixed it easily and it works like a champ now. The one in her car uses an electromagnet to pull on its throttle cable and the servo was actually mounted on top of the engine on a rail, I know factory installed are not as accessible as that.
Mccreet, you have any luck with that self diagnostic procedure?
6SPD_soul is offline
Old 02-06-2012, 06:00 PM   #14
mccreet
Fan#: 93598
yeah thanks, i tried the diagnostic test and it came back 3 flashes, which means brake switch curcuit, my mechanic is gonna handle it from there. i got 3 servos at the junkyard for each one like $15. i will let u know how it turns out in a few days.
mccreet is offline
Old 02-08-2012, 12:08 PM   #15
jay-rod05
Fan#: 24351
FF Reputation: 5 jay-rod05 Good Standing Member
The brake switch circuit should be an easy fix. Go back to the junk yard and pull a stop lamp switch and brake pedal position switch:
jay-rod05 is offline
Old 04-22-2013, 01:43 PM   #16
hmagayle
Fan#: 113852
What I Drive: 2005 red zx4
FF Reputation: 1 hmagayle Good Standing Member
cc doesn't work and no cc light
cc doesn't work, I check all fuses and replaced two. First of all the cc light on dash doesn't lite and when I replaced fuses it still doesn't lite. when starting or in start position before engine starts no light for the cc. any ideas
hmagayle is offline
Old 04-22-2013, 01:46 PM   #17
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,384, Level 65
Points: 9,384, Level: 65 Points: 9,384, Level: 65 Points: 9,384, Level: 65
Level Up 12% Completed
Forum Activity 6%
Check your tail lights make sure none are burnt out. Including the high mount.(third brakelight)
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 04-16-2014, 04:00 PM   #18
tmarc75
tmarc75's Avatar
Fan#: 156474
What I Drive: 2003 Oxford White ZX3
Points 10, Level 1
Points: 10, Level: 1 Points: 10, Level: 1 Points: 10, Level: 1
Level Up 19% Completed
FF Reputation: 1 tmarc75 Good Standing Member
Sorry to bump an old thread but I did the diagnostic and got the zero flashes. So suspect circuitry or steering wheel controls. How can the wheel controls be an issue if in doing the self test all are pressed and the self test works? So suspect cicuitry. What needs replaced? Any input from anyone?
tmarc75 is offline
