Lifter Noise Extraction - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-06-2011, 11:34 PM   #1
Br3nn1
Fan#: 92455
What I Drive: 2001 Platinum Silver ZX3
FF Reputation: 1 Br3nn1 Good Standing Member
Unhappy Lifter Noise Extraction
Well that time has come again for the necessary Tune-Up. I have been noticing erratic clicking like i drive a diesel, so presumably its lifters as its coming from the top.
Buying the items today, i came across a lifter silencer from a brand called 'Solder Seal Gunk' (Yellow bottle, 354ml) ... Has anyone used this product before? It's a bad/good thing to do? Don't bother with it just get the damn things checked and fixed? Mind you i do not have the necessary tools...and the country i'm in could barely handle looking after there own car so why bother with mine...
I heard noisy lifters are a semi extreme problem most of the time, and any form of help i can get to stop it sounding like a Toyota Hilux would be great :)
Br3nn1 is offline
Old 12-06-2011, 11:40 PM   #2
fhh02a
HATCH NATION
fhh02a's Avatar
Fan#: 57548
What I Drive: 2004, Pitch Black Zx3
Points 16,184, Level 81
Points: 16,184, Level: 81 Points: 16,184, Level: 81 Points: 16,184, Level: 81
Level Up 67% Completed
FF Reputation: 13 fhh02a Great Standing Member
Buy-Sell-Trade Rating: (10)
well, I dont know if tht stuff would help. I just live with the noise and go on.
fhh02a is offline
Old 12-06-2011, 11:51 PM   #3
ah1f39
Alone in the Cave
ah1f39's Avatar
Fan#: 70006
What I Drive: 2000 Explorer 4x4, 04 Mini Cooper S
Points 4,625, Level 43
Points: 4,625, Level: 43 Points: 4,625, Level: 43 Points: 4,625, Level: 43
Level Up 38% Completed
Forum Activity 3%
FF Reputation: 28 ah1f39 Great Standing Member
Dont put that junk in your engine!
Are you sure it's the lifters? Or could it be noisy fuel injectors?
ah1f39 is offline
Old 12-06-2011, 11:52 PM   #4
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,933, Level 87
Points: 18,933, Level: 87 Points: 18,933, Level: 87 Points: 18,933, Level: 87
Level Up 17% Completed
Forum Activity 11%
Buy-Sell-Trade Rating: (4)
If it's something that's just developed, it isn't the lifters.
More likely would be a accessory belt pulley and/or tensioner.
Second in line are the pulleys for the timing belt.
There is no additive of 'snake oil' that will calm the noise our lifters make. The zetec is a solid lifter design and by design there has to be some clearance. That clearance is where the noise comes from. Think of it like the cam lobe slapping the lifter, vs a hydraulic lifter where the cam is in constant contact with the lifter.
Additives are for hydraulic lifters. By the majority, the additives clean the built up gunk out of them and try to make them function as new again.
Mechanical lifters either work or don't. No saving them, replacement is the only remedy.
121,000 members and still no sponsored racing.
iminhell is offline
Old 12-06-2011, 11:55 PM   #5
Br3nn1
Fan#: 92455
@ iminhell ............................ that sucks :(!! Appreciate the advise.. i just figured that the whole circulation of oil movement could have had some effect on it.... shrugs :(
Appreciate it.. service is gonna be done tomorrow XD
And no.. this has been the same problem for approx 36k miles
Br3nn1 is offline
Old 12-08-2011, 10:41 PM   #6
FecalRocket
FecalRocket's Avatar
Fan#: 75116
What I Drive: 07 Liquid Gray ST
Points 1,643, Level 23
Points: 1,643, Level: 23 Points: 1,643, Level: 23 Points: 1,643, Level: 23
Level Up 44% Completed
FF Reputation: 3 FecalRocket Good Standing Member
This is what my car sounds like and is what ive been told is lifters causing the noise. Only happens when the car is returning down to idle.
YouTube Video
Not sure if thats what yours sounds like or not... I have a warranty still and they refuse to fix the issue because it hasnt failed yet. My warranty ends here REALLY soon in about 3,000-6,000 miles so i think they just dont want to fix it. Starting to piss me off.
Is that really lifters (tappets or buckets or whatever) thats making the noises??? mine did randomly happen after running my car pretty hard and getting the RPM's pretty high
FecalRocket is offline
Old 12-09-2011, 01:45 AM   #7
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 11%
Your's sounds like a failing timing chain guide to me. IIRC they are based on oil pressure. If either the guide becomes worn or the solenoid becomes plugged up with gunk, the guide can't move far enough/fast enough to take up the slack in the chain, and the chain makes a ticking sound as oil pressure drops. Generally it's only on decel because then there is slack on the intake side of the chain. Under acceleration there is naturally tension on the intake side of the chain.
iminhell is offline
Old 07-19-2013, 09:07 AM   #8
ponty47
Fan#: 116894
What I Drive: 51 Ford Focus 1.8 Zetec 3dr
FF Reputation: 1 ponty47 Good Standing Member
My 2001 Focus 1.8 rattles/taps/clicks. You can hear 'a noise' under idle, however the noise is most prolific when the throttle is held around the half way mark, normally a tad below. Im not sure if its lifters or as mentioned perhaps the solenoid. Dont think it'll be the belt tensioner as this was replaced last march after it failed. Is due for a service tho. Ps, the noise is around the cam cover. Help?
ponty47 is offline
