WMI with JRSC W/BBK? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-24-2012, 03:08 PM   #21
Rod H
Rod H's Avatar
Fan#: 53555
What I Drive: 1959 Austin Healey (Zetec Engine)
FF Reputation: 1 Rod H Good Standing Member
I connect my water/meth nozzle onto the intake for the SC. I just tapped one of the vaccum ports w/ 1/8 npt threads and screwed it in. That way it is after the throttle body but, before the SC.
http://www.spritespot.com/gallery/Bu...geye_Water_Inj
Rod
Rod H
The older I get the more cynical I become, but, I can't keep up
Rod H is offline
Old 08-23-2012, 01:26 AM   #22
Michael_Price1990
Michael_Price1990's Avatar
Fan#: 101650
What I Drive: 2003 Yellow SVTFocus. Infiniti FX35
FF Reputation: 1 Michael_Price1990 Good Standing Member
can you guys get the pictures back up? i just purchased a JRSC for my SVT and i'm considering going with WMI myself. i dont have it yet. literally on its way in the mail. im trying to order everything at once so i can install all at once and tune with tom!
- Michael Price
2003 SVT Focus
205+ HP
JRSC
Michael_Price1990 is offline
Old 09-03-2012, 07:38 PM   #23
Jmoorer5
Jmoorer5's Avatar
Fan#: 88981
What I Drive: 2003 Screaming Yellow SVT w/JRSC
Points 656, Level 13
Points: 656, Level: 13 Points: 656, Level: 13 Points: 656, Level: 13
Level Up 12% Completed
FF Reputation: 1 Jmoorer5 Good Standing Member
So Tom, what do you think, should the port for the w/m be before the SC or after. I also heard that the W/M will damage the coating on the sc blades.
Jmoorer5 is offline
Old 09-09-2012, 01:08 PM   #24
Jmoorer5
Jmoorer5's Avatar
Fan#: 88981
Have you started your install yet and if so, can you post a few pics
Jmoorer5 is offline
Old 09-10-2012, 11:49 AM   #25
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,526, Level 100
Points: 52,526, Level: 100 Points: 52,526, Level: 100 Points: 52,526, Level: 100
Level Up 0% Completed
Forum Activity 63%
Activity: 63% Activity: 63% Activity: 63%
Buy-Sell-Trade Rating: (28)
I feel the WM (if you feel its a must) should be after the rotors / SC
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 09-10-2012, 02:29 PM   #26
turbosvtfocus04
turbosvtfocus04's Avatar
Fan#: 100806
What I Drive: 2004 black svt
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 1 turbosvtfocus04 Good Standing Member
Are you guys just adding wmi without a tune to help lower IAT or are you getting a tune for w/m? Just by adding w/m will lower IAT but will also change air/fuel ratio which will make the car run slower due to it running rich. An example,
I've ran w/m on my other turbo car and my air/fuel ratio went from 11.8 to 10.2, ran slower until I adjusted the air/fuel and added timing.
turbosvtfocus04 is offline
Old 09-10-2012, 04:06 PM   #27
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 63%
I have done hundreds of Hrs and never seen WM drop a WOT air fuel 1.6 points , if this did happen then you had far to much WM going in and effecting your air fuel gauge and performance
I will NEVER tune the engine / fueling to run water meth , In my opinion this is the most dangerous thing you can do , if the
Tank runs out of meth
line comes loose
jet stops up
fuse blows
turn on switch doesnt work
You will loose an engine faster then you can let off , tuning for WM in my opinion is foolish , use it for safety and it works ok
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 09-10-2012, 04:38 PM   #28
turbosvtfocus04
Fan#: 100806
Points 233, Level 4
How many times have you had that happen Tom?
Because all those are preventable.
In the year and a half I've used w/m, I've never had an issue and I push the limits. 58mm turbo 17psi with 35 degrees of timing air/fuel at 11.7 no knock.
All my other buddies and people that run it never had issues with w/m.
If its hooked up correctly, you won't have a problem with it. The kits now are very well designed.
Old 09-11-2012, 11:01 AM   #29
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 63%
How are you going to prevent the jet from stopping up (11 times), wire from coming (3 times)loose , WM from running out when your out cruising (5 times) , micro switch/electronic psi device that turns it on (5 times) line rubbing a hole in it (4 times) , pump failure (2 times)
That just the cases and round # of people that lost engine that just I know over the years from turbo , high compression , Diesel , SC , boat engines over the years I have been playing with WM on customers cars , none of which I installed because I dont use it
Never tune for WM , use it for safety and to cool the charge and your fine , tune for it and at some point you will loose an engine
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 09-11-2012, 11:19 PM   #30
gimmemoreboost
gimmemoreboost's Avatar
Fan#: 83716
What I Drive: 2007 Pitch Black ZX5
Points 1,745, Level 24
Points: 1,745, Level: 24 Points: 1,745, Level: 24 Points: 1,745, Level: 24
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
FF Reputation: 1 gimmemoreboost Good Standing Member
Buy-Sell-Trade Rating: (4)
Then you were obviously doing something wrong because everyone I've ever talked to about it has said tune for it and these articles say so as well.
I'll send my uncle an email about it and see what he says. Chris Johnson of SCT and JMS.
http://www.stangtv.com/tech-stories/...injection-101/
http://www.turbotalk.org/bb/viewtopic.php?f=13&t=55
http://www.tristatetuners.com/forum/...ad.php?t=14745
As it says in the above post, you are risking detonation and catastrophic engine failure because of added timing, boost, and leaner fuel trims. But that is what wmi is for, so you can run those things on pump gas. The benefits outweigh the risks tenfold.
gimmemoreboost is offline
