Where to buy Door seals at??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-04-2011, 05:55 PM   #1
kcw12
Fan#: 92445
What I Drive: 2001 Focus Wagon Grey
FF Reputation: 1 kcw12 Good Standing Member
I searched the forums but didn't find what I was looking for!
I have a 2001 Focus Wagon, and the passenger side door is leaking at the door seal. (I see a hole through it)
I was wondering where is the best/cheapest place to get the seal so i can replace it?
Thanks
kcw12 is offline
Old 12-04-2011, 08:10 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,745, Level 73
Points: 12,745, Level: 73 Points: 12,745, Level: 73 Points: 12,745, Level: 73
Level Up 74% Completed
Forum Activity 99%
Best replacement is the "Dealer" part, & cheapest is through our Focus internet dealer sources of Hilbisch or Tousley.
if you're near the Carolinas, it would be Hilbisch, Since you're closer to Tousley in Minneapolis, I'd recommend them - since I've got good advice & cheap parts from them myself...
"unobtanium" is often avail. through Steele rubber products for ALL older or "collector" cars...
sailor is online now
Old 03-19-2013, 05:21 PM   #3
kyle9563
Fan#: 102046
What I Drive: 2000 Silver ZTS
FF Reputation: 1 kyle9563 Good Standing Member
What kind of weathstripping do you buy? i have a 2000 focus with a similar problem and i cant find which shape or kind to buy
kyle9563 is offline
Old 03-19-2013, 09:05 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
IF it's not avail. from Ford, MANY shapes & sizes are avail. at an auto parts store like NAPA.
Take a sample with you, or draw a diagram of what it would look like from the side (as in a cross section view) plus a measurement of the width & height.
Looking at their catalog of weatherstrip in the store, you'll see a shape picture, dimensions, and often common uses listed.
Same basic style & size will work, even if not identical.
They'll sell you official weatherstrip cement as well, since except for odd places like the extra piece at the bottom of our doors MOST is glued on.
luck!
Old 03-19-2013, 09:25 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
FWIW - "Factory" or "Reproduction" pieces of weatherstrip are the easiest to use & give the best results simply because they are "pre-fitted" with the correct bends, sometimes even welded or connected in a loop for the best fit. Bulk rolls are cheaper, but installation will be more involved & a bit tedious if you are to get acceptable results.
Plan on at least one "gooey" finger, when dealing with the cement you need to spread it on both parts - let it "tack up" - then carefully place the weatherstrip. I like to reserve an index finger for spreading, then DON'T touch anything else with it! Practice a way to hold the strip glue side up before starting (like with some weights on a piece of cardboard). Otherwise it's likely to curl around & get stuck to everything nearby!
Hope this helps.....
Old 03-20-2013, 06:02 AM   #6
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
Try our vendor "Village Ford" <-- linky and see if they have factory weatherstrip. We get big discounts from them, so hopefully you can get the part you need.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
