Let me see your SLAMMED/LOWERED Focus!... - Page 117 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-08-2013, 09:53 AM   #1161
Wobbn08
Fan#: 90548
What I Drive: 2008 Silver SES Coupe
Points 1,306, Level 20
Points: 1,306, Level: 20 Points: 1,306, Level: 20 Points: 1,306, Level: 20
Level Up 6% Completed
FF Reputation: 6 Wobbn08 Good Standing Member
Buy-Sell-Trade Rating: (4)
Just get Ksports.. Trust me
SES #018
Wobbn08 is offline
Old 02-09-2013, 08:22 PM   #1162
redSVT_03
redSVT_03's Avatar
Fan#: 78206
What I Drive: 2003 red SVTF
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 4 redSVT_03 Good Standing Member
scares me.. im on dgr's
Smoke tires not drugs
redSVT_03 is offline
Old 02-13-2013, 10:27 PM   #1163
trevor_shiggs
Fan#: 67337
What I Drive: 2009 Black SES Coupe
FF Reputation: 2 trevor_shiggs Good Standing Member
Are you on ksports?
Im looking at getting ksports, they no longer come with adjustable camber plates. I was wondering if the spc camber/caster kit for the front gets a car lowered quite aggressively to within alignment specs. I am also assuming I will need adjustable rear arms. I also read on here somewhere that wheel spacers are needed. 15mm front and 20mm is one combination I read. Obviously depending on how low I go.
I want do lower my car quite aggressively but want to do it right and keep everything as close to spec as possible for alignment.
Thanks.
trevor_shiggs is offline
Old 02-13-2013, 10:34 PM   #1164
Wobbn08
Fan#: 90548
Originally Posted by trevor_shiggs View Post
Are you on ksports?
Thanks.
I am on KSports.. They do NOT come with camber plates on them, and the spc camber kit won't work with KSports... Depending on how low you go though that might not be a problem. I had 2 degrees of camber on my car when I dropped it and that was enough for 17s.
Spacers also depend on how low you go, and what size/et/specs of your wheels.
You will need adjustable Toe Arms. I suggest Massives as I have them and they are great. With the alignment, the only thing you need to worry about is getting your Toe set to 0 Degrees. Camber won't wear your tires down unless you're around 5 degrees which I highly doubt you will be. Every time i've gotten my car aligned after being lowered, I have gotten the Toe specs to 0 at all 4 corners and never once had an issue with tire wear.
SES #018
Wobbn08 is offline
Old 02-13-2013, 10:45 PM   #1165
trevor_shiggs
Fan#: 67337
Thanks, That post was very helpful.
I just have the factory 215/45/17's and switch to 195/60/15's in the winter. I commute about 120 km a day to work. But rotate my tires every 10 000km or less.
You have the 06-07 ksport kit correct?
Old 02-13-2013, 10:47 PM   #1166
Wobbn08
Fan#: 90548
Yes, I do... call Never Enough Auto in Michigan. They will hook you up.
How low do you plan on going? 205/40s will suit you much better if you're going really low.
SES #018
Wobbn08 is offline
Old 02-13-2013, 10:54 PM   #1167
trevor_shiggs
Fan#: 67337
I want to eliminate the wheel gap but not too worried about tucking or anything.
2.5-3 inches most likely. I don't think I will go to 4 inches. I've been browsing through this thread to find 08-11's that are quite low. Its not really stated what set-ups everyone is using tho, or how low they are.
Old 02-13-2013, 10:56 PM   #1168
trevor_shiggs
Fan#: 67337
Originally Posted by cmmike1 View Post
how many inches would you say this is lowered?
Old 02-13-2013, 11:23 PM   #1169
homelessmonkey
homelessmonkey's Avatar
Fan#: 98498
What I Drive: 2003 black zx3
Points 846, Level 15
Points: 846, Level: 15 Points: 846, Level: 15 Points: 846, Level: 15
Level Up 46% Completed
FF Reputation: 2 homelessmonkey Good Standing Member
homelessmonkey is online now
Old 02-13-2013, 11:26 PM   #1170
IngotMK3
IngotMK3's Avatar
Fan#: 42911
What I Drive: MK3 Focus
Points 4,172, Level 41
Points: 4,172, Level: 41 Points: 4,172, Level: 41 Points: 4,172, Level: 41
Level Up 11% Completed
FF Reputation: 1 IngotMK3 Good Standing Member
w00t
IngotMK3 is offline
