anyone using premium gas ? - Page 51 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-07-2012, 11:38 PM   #501
Sonic_HedgeHog
Sonic Mk3 Crew #00
Sonic_HedgeHog's Avatar
Fan#: 50003
What I Drive: '12 Sterling Focus SE 5dr Sport Pkg
Points 124,710, Level 100
Points: 124,710, Level: 100 Points: 124,710, Level: 100 Points: 124,710, Level: 100
Level Up 0% Completed
FF Reputation: 19 Sonic_HedgeHog Great Standing Member
Originally Posted by VOLDAR View Post
When you say 600, you mean KM or MILES ?
He lives in Canada and there's no way you could do 600 miles on a tank... Come on ;)
Hatch Nation #156. Sonic's Mk3 Crew Founder and #00
Moderator: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, SW Fanatics, Sonic's MK3 Crew
Sonic_HedgeHog is offline
Old 07-07-2012, 11:40 PM   #502
scott7278
Fan#: 100021
What I Drive: 2012 Red Candy SEL Hatchback
Points 1,486, Level 21
Points: 1,486, Level: 21 Points: 1,486, Level: 21 Points: 1,486, Level: 21
Level Up 86% Completed
FF Reputation: 5 scott7278 Good Standing Member
If it's miles, I'll have what he's having.
scott7278 is online now
Old 07-07-2012, 11:58 PM   #503
id10t
id10t's Avatar
Fan#: 93706
What I Drive: 2002 ZX3 charcoal
FF Reputation: 3 id10t Good Standing Member
I haven't read all the posts in the thread. Maybe it's been covered. Octane is not about mileage, or performance. It's measure is the ability to resist detonation during the compression stroke. Detonation or 'knock' is very harmful to engines. With higher compression comes higher adiabatic heating of the fuel air mixture, and if there is a concentration of fuel in one area of the squish(combustion chamber during compression) it can cause the mixture to explode in an uncontrolled pattern and cause damage.
Modern engine management takes advantage of rated octane in the tank by advancing the spark timing to the point of maximum performance, with a safety margin for detonation avoidance. Of course, everything is a compromise, so the way you drive, will also have an effect on your mileage, and performance. If you regularly accelerate hard at low RPM, this is a trigger point for detonation, and the engine management will be set for greater detonation margin. If you accelerate slowly, your manifold pressure will remain lower, and the adiabatic heating will be less, so the engine management will advance the timing to make use of that for better economy.
If you look at a chart of energy density, you will find that 87 octane fuel has the same, or slightly higher energy stored in it than 91/93 octane. This is due to the additive package that is added to the base fuel to resist detonation under high compression, and high manifold pressure.
All other things being equal, 87 octane should provide the best economy, and sufficient power for all driving conditions. The reason you often find 86 or 85 octane at higher altitudes is because the lower barometric pressure doesn't allow for detonation due to less air flowing into the engine.
So, in most cases, you are better off running 87 octane for all conditions except possibly towing on a hot day. The added cost of premium may give you slightly better performance due to the engine management advancing the timing, which will make better power.
The key is energy density. It's measured in BTU/gallon. Ethanol at 10% solution in fuel reduces the energy density approx 2-3% overall, and also reduces efficiency by the same amount, or slightly more. E85 energy density is about 20% lower than straight fuel, and the economy is reduced in near the same ratio. Some engines take advantage of the better heat dissipation, and reduced potential for detonation with E85, and modify the valve timing and ignition timing to account for these factors, but energy density is still lower, and will not recover the same economy as straight fuel no matter what you do.
Empirical evidence aside, the fact is the energy density of pure 87 octane fuel is about the best you can do for your Focus. In altitudes above 3600 feet, check the yellow sticker for the octane rating and put anything over 87 in the car.
Here is a link to stations which carry pure gas with no Ethanol.
http://pure-gas.org/
Sent from my brain, using my fingers
id10t is offline
Old 07-08-2012, 12:50 AM   #504
Dylan1970
Dylan1970's Avatar
Fan#: 100905
What I Drive: 2012 Oxford White Focus
FF Reputation: 1 Dylan1970 Good Standing Member
Well, after reading these posts I think I'll stay at 89 octane. It's right in the middle, so to speak....not too high or low.
Dylan1970 is offline
Old 07-08-2012, 05:24 AM   #505
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,282, Level 95
Points: 25,282, Level: 95 Points: 25,282, Level: 95 Points: 25,282, Level: 95
Level Up 94% Completed
Forum Activity 4%
Judging by the experiences of the different forum members that have been running their own real-world tests, 89 octane may be the best compromise of fuel mileage/performance. It appears that the largest mpg jump occurs from 87-89, and the mileage from 89-93 has been minimal. From a pure cost/benefit analysis, 89 would win.
I will probably run a tank of 89 next to get an opinion on the power loss of stepping down from 93. If it is seemingly unnoticeable, I may finally reside there also. I will say that I ran some 87 after being used to 93, and it was more than evident just by SOP feel. I do care about mileage to a degree, but I am more concerned with the smile put on my face when I push the GO pedal.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 07-08-2012, 06:20 AM   #506
Chaddz3
Fan#: 96992
What I Drive: 2012 Ford Focus S Ingot Silver
Points 1,795, Level 24
Points: 1,795, Level: 24 Points: 1,795, Level: 24 Points: 1,795, Level: 24
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
FF Reputation: 17 Chaddz3 Great Standing Member
For years the cars I have driven seemed to run best on 87 E0.. but those were all engines with 9.5:1 compression or lower.. with port injection, throttle body injection or had a carb on em. the 89 octane E10 would stumble slightly with a slight miss now and then and 93 octane in those cars offered no noticeable benefit. (These were all GM engines. an olds 455, pontiac 2.5 iron duke, 2.2L GM corporate and a 2.2L Ecotec, a 2.8L v6 and a 3.1L v6.)
When I got my Focus, i started out with 87 octane as well in that, (old habits die hard). But using 87 i noticed that while not bad, the Focus just seemed to be a little sluggish on power especially with the A/C on. And it seemed to have a rough jumpy idle.. it felt almost like it had a miss in it.
(Even after the 12-5-5 TSB update) it still just wasn't quite up to par.. I just passed it off as maybe thats just the personality of this new Duratech 2.0... until after reading this forum and deciding to try Premium 93 in it.
The difference in just the way it idles and the improved throttle response. plus the fact it seems to accellerate quicker is enough to convince me to stay with the premium. I have my theories on why this thing seems to like premium so much after learning more about the engine itself and its management systems, but at the end of the day it comes down strictly to how the thing seems to act. It just simply likes premium fuel better.
Fuel Mileage, on my first tank was quite good even with A/C use. I didn't notice much of a mileage difference (for better or worse) over 87... which in and of itself is ok since my other cars took a noticable mileage plunge runing any octane higher than 87 in them. Once it cools down where i can stand to drive the thing without having to run the A/C constantly, I'll make the final call on fuel mileage... but for now, it seems to be ok.
Chaddz3 is offline
Old 07-08-2012, 09:15 AM   #507
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,339, Level 77
Points: 14,339, Level: 77 Points: 14,339, Level: 77 Points: 14,339, Level: 77
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 19%
FF Reputation: 15 Elizabeth Great Standing Member
I agree the biggest jump is from 87 to 89 octane.
I was trying to alternate regular with Premium so the tank would be in between (half empty fills)
I just do not want to bother anymore and now just fill with Premium.
The difference per gallon of $0.20 to $0.30 depending on the station, is just worth the little extra money to me.
And I want to comment on the point that 'octane' is for 'blah blah and has nothing to do with blah blah'..
Yeah fine in theory.
In the real world something is actually goinng on. What it is ??
I can only say the car runs better, idles better, accelerates better, and gets better MPGs on a HIGHER than 87 octane gas.
89 may be fine, but i just as well go to 93.
Maybe i should alternate between mid level and Premium?
Elizabeth is offline
Old 07-08-2012, 09:20 AM   #508
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 4%
I've got the feeling that when I try a tank of 89 I will be disappointed. For me, I'm sure that 93 is where my car will live. Just wanna try it once to make sure. 87? Never ever.
Never ever?
Never ever.
September '13 ROTM
2014 FiST-
Old 07-08-2012, 10:25 AM   #509
VOLDAR
VOLDAR's Avatar
Fan#: 90444
What I Drive: Volt 2014, White Diamond
FF Reputation: 3 VOLDAR Good Standing Member
I live in Canada too, but I change l/100km to MPG just to have the same "base" as you guys. I thought he might did the same. If it's 600 km, doing 7.6l/100 km = 31 MPG, you get there. I think that in a longer trip, doing 5.8 l/100km = 40 MPG should be good for 496 miles = 793 km. I'll test this in about a month, when I have to do a round trip to Toronto (Montreal-Toronto = 540 km). On my last car, a V6 (same tank capacity), I had to put some gas in it right before getting to Toronto (doing 119 km/h = 74 mph). I hope with this one, I will be able to get there and even do some city driving before filling it up.
P.S. I just acknowledge that you guys jump from 87 to 89 or 93. There is no 91 there ? Because here, at Petro-Canada, there is a 91 octane gasoline.
White Platinum Metallic Tri-Coat
303A, 6-Speed SelectShift Automatic, 17" Aluminum wheels, Luxury Package,
Parking Technology, Navigation, Winter Package
---replaced by---
Chevy Volt 2014, White Diamond, Luxury Package, S1, Navigation.
VOLDAR is offline
Old 07-08-2012, 10:39 AM   #510
Visioned
Fan#: 93729
What I Drive: 2012, Red Candy, Focus SE
FF Reputation: -1 Visioned Poor Behavior Needs Improvement
On the highway with 89 Octane (no ethanol) and relatively flat road, my car achieved 51mpg @ 55mph with cruise. After hitting some rolling hills it only went down to 47mpg. City is what kills my mpg but its still reasonable around 30mpg with air conditioning on.
Visioned is offline
