#91 | ||||
#92 | ||||
They need to take the corn back to the grocery store as it does far more good there!! Although our Focus has not arrived yet, our other Fords always go down in mileage at least 2 or 3 mpg when using ethanol blend and/or winter gas. Definitely couldn't hurt using 93 octane except the wallet. I will probably experiment some with it.
#93 | ||||
There are so many variables that it's hard to impossible to do a truly scientific test when you don't have control over most of the variables. For one, most stations list the gas as having "Up to 10% ethanol" which means it could be anywhere from 0 to 10 and there's no way I know of to tell the difference. This variable alone could result in about 3%-4% difference in mpg. Another is the weather and that could be as much as 20% or even more difference with all else being the same. Again, we don't have much control over the weather. Then there's traffic and it's impact on stop-and-go driving. This could be 20% or more by itself. Of course there the variable behind the wheel and that could be more than 30%. In summary, when all these variables and a few others are taken into account, the mpg could vary, in a car like the 2012 FF, from less than 20mpg to just about 50mpg so parsing the cause of a 2-3mpg difference is just about impossible... Brian |
#94 | ||||
[QUOTE=amoosenamedhank;4131276]If premium fuel made a 5+mpg difference you better believe Ford would recommend premium fuel. A higher octane merely has a higher ignition temp, you WILL NOT gain 5+mpg from it. The only reason you would use a higher octane fuel is to offset KR caused by pre-ignition or to advance timing for a performance benefit.
I'm also clear that premium won't make a 5+mpg difference. I am simply expecting more than 29mpg long term and with break-in and better fuel if it can be achieved I will look to that. |
#95 | ||||
I am on my second tank of Shell V-Power/Optimax (premium91), and it appears to be at least a 3 mpg increase. On my regular back and forth to work I never got over 30mpg usually around 28. My first tank was 31.5mpg calculated not dash readout. It looks like my second tank could be even better. This was already being discussed in this thread with an interesting video.
http://www.focusfanatics.com/forum/showthread.php?t=284662 |
#96 | ||||
LOL LOL
K&N Air filter, uh - thats it, NO CAI, NO FSWerks, NO Exhaust, NO Coilovers, NO Tune, Nothing |
#97 | ||||
If you are noticing a difference, there are other factors at play. |
#98 | ||||
I think the only factor at play is the TI-VCT engine that Ford says will see improved performance with premium fuel. Seems cut and dry to me. Plus the video seems to demonstrate that some cars are actually able to gain HP and TQ with premium fuel, something I thought was only a myth. Which without high tech computer control and variable cam timing would be just a myth. Unless the video is an elaborate, slick, internet hoax, but I don't think so. Also it appears to take several tanks or an ECU reset to see the difference.
#99 | ||||
As AZfocus has pointed out, with current technology which can adjust fueling and timing on the fly, it is very possible to notice a performance increase if the car has been designed to do so. There will always be the true ecoboxs that were designed to only run 87, and anything more will only waste your money. However, vehicles even like our little Focus here, sort of empower you as the owner to decide whether you'd like to save the money at the pump or potentially enjoy a slight pump in hp. |
#100 | ||||
Prior to the V-Pover/Optimax I had run a tank of Chevron 91 and Circle K 91 and saw little to no difference. So I can't say that the V-Power is that much better than the other premiums since others in other threads have said it takes multiple tanks for the ECU to adapt without a reset. But if this trend in MPG maintains, I will continue to use premium as it is a 5% premium at the pump, that appears to yield near a 10% increase in MPG. Others have said their cost per mile is less with premium. Plus, I think the car runs better on premium.
| Thread Tools | |
| Display Modes | |
