Auto-Dimming Mirror - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 03-11-2013, 08:53 PM   #21
riparke
Fan#: 95781
What I Drive: 2012,red,se,hatch,manual,sport pkg
Points 419, Level 8
Points: 419, Level: 8 Points: 419, Level: 8 Points: 419, Level: 8
Level Up 38% Completed
FF Reputation: 1 riparke Good Standing Member
They screwed up. the gentex 40 I installed has a red for switched power (mirror) a yellow for constant power, but I connected it together with the red to 12v and a black to ground. Brown wire is for map light - not used. I added a add-a-fuse to the fuse panel below the glove box. All devices must be fused to prevent fires. Red wire must be switched to prevent it from draining the battery. Take it back and have them fix it and show you where the fuse is.
riparke is offline
Old 03-13-2013, 05:39 PM   #22
JasDmw
Fan#: 105501
What I Drive: 2013 Focus Ti Hatch Sterling Grey
Points 215, Level 4
Points: 215, Level: 4 Points: 215, Level: 4 Points: 215, Level: 4
Level Up 30% Completed
FF Reputation: 1 JasDmw Good Standing Member
Originally Posted by JasDmw View Post
I just had a GENK40 gentex autodimming mirror with homelink installed yesterday. Used my dealers recommended aftermarket electrical install shop. Unfortunately, the autodimming function is not working. Also, whenever I press one of the 3 buttons to activate a garage door, the 4 way flashers come on! Pressing one of the buttons again turns them off. Anyone else with this type of aftermarket install have this issue? Note that I did get the homelink to work fine to open my 2 garage doors. Am using the 3rd, unused homelink button for shutting off the 4 ways. Do intend on taking the car back to that shop, but am looking for some insight first. The installer says he works on many new fords and the 5 wires in there were a piece of cake for him. Obviously not, unless the mirror is flawed.
So I took it back and they admitted they installed it wrong! They called MITO corp, the manufacturer and got the right help. Connected the power to the "blue" wire in the fuse panel and all is well. Mine has a constant green light when the autodim funciton is on and nothing when it's off. When you activate one of the Homelink buttons it changes to red.
Would be nice if the buttons were illuminated; tough to see in the dark!
Otherwise, works really well.
JasDmw is offline
Old 04-16-2013, 07:58 PM   #23
4havnfun
Fan#: 107430
What I Drive: 2013 Blue Candy Titanium
FF Reputation: 2 4havnfun Good Standing Member
Does anyone know if the wiring for the mirror is still up in the headliner of the 2013 Titaniums or if it was stripped out when they removed an auto dimming mirror as an option?
4havnfun is offline
Old 04-30-2013, 03:45 PM   #24
dbsimms63
Fan#: 110359
What I Drive: 2013 Performance Blue Titanium 5dr
Points 1,820, Level 25
Points: 1,820, Level: 25 Points: 1,820, Level: 25 Points: 1,820, Level: 25
Level Up 20% Completed
Forum Activity 5%
FF Reputation: 2 dbsimms63 Good Standing Member
I guess you'll have to look for yourself.
dbsimms63 is offline
Old 05-01-2013, 09:57 AM   #25
Flybigrc
Flybigrc's Avatar
Fan#: 103155
What I Drive: 2013 Ford Focus ST
FF Reputation: 1 Flybigrc Good Standing Member
I was wondering if the connections were in the headliner of the ST.
2013 Focus ST Performance Blue
2004 Corvette Coupe Magnetic Red
1968 Corvette Convertible Safari Yellow
Flybigrc is offline
Old 05-01-2013, 12:19 PM   #26
dbsimms63
Fan#: 110359
Forum Activity 5%
Let everyone know if you look and find them, they would be very interested.
Old 05-22-2013, 12:31 PM   #27
dbsimms63
Fan#: 110359
Forum Activity 5%
Did anyone ever find out if the electrical connections for the auto dimming mirror are still under the head liner?
Old 05-23-2013, 03:08 PM   #28
Billacuda
Billacuda's Avatar
Fan#: 114361
What I Drive: 2013 Titanium Hatchback
Points 189, Level 3
Points: 189, Level: 3 Points: 189, Level: 3 Points: 189, Level: 3
Level Up 78% Completed
FF Reputation: 2 Billacuda Good Standing Member
I'd like to know as well before I go ripping stuff apart to run wires.
2013 Ford Focus Titanium Hatchback
2013 Ram 1500 ST 4x4
Billacuda is offline
Old 05-27-2013, 04:02 AM   #29
garyd9
Fan#: 114024
What I Drive: '13 Dark Gray Focus Titanium Hatch
FF Reputation: 1 garyd9 Good Standing Member
On my job2 2013 Ti, I couldn't find a harness/plug in the headliner for an auto-dimming mirror.
My Gentex autodimming mirror (with homelink) had three wires: ground, constant 12v (homelink) and ACC (ignition) 12v. I was able to wire all three into the moonroof MOTOR harness.
If you pull out the plastic upper console (that contains the sunglass holder, moonroof switch, etc), and look up into the roof (assuming you have a moonroof), you should see a gray connector that plugs in facing the passenger side of the car.
The BLACK wire (heavier gauge, thin white stripe) is ground.
The white wire (thinner gauge) is accessory power and turns off immediately with ignition.
In one corner of the connector, there's a heavier gauge orange wire (forget the stripe and I didn't get photos) that's constant power.
TEST ALL OF THIS BEFORE TAPPING ANYTHING!!!!!!
Get a cheap multimeter... you shouldn't be messing with wires without one. Learn how to check for 11-15 volts DC. Test everything you read on these websites. Don't tap wires unless you've seen for yourself what they do.
If you don't have a moonroof, It's possible you still have the harness and plug. Check and see... if you do, it's a great source for the mirror.
garyd9 is offline
Old 08-25-2013, 11:18 PM   #30
Loveit
Fan#: 117758
What I Drive: 2012 SILVER SEL HATCH
Points 5, Level 1
Points: 5, Level: 1 Points: 5, Level: 1 Points: 5, Level: 1
Level Up 9% Completed
FF Reputation: 1 Loveit Good Standing Member
Great write up Garyd just did this today ,just a few notes my May 2012 SEL accessory power wire was white with brown stripe and to remove upper console open sunglass holder and on each side of button are holes you need to insert small screwdriver or something else in those holes and push straight back to release clips then it comes out.
Loveit is offline
