Auto-Dimming Mirror - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 03-31-2012, 02:17 PM   #11
-sokO
-sokO's Avatar
Fan#: 93367
What I Drive: 2012 Ford Focus Ti Sedan
FF Reputation: 1 -sokO Good Standing Member
So I just installed a Gentex K2a Auto Dimming Mirror 79$ shipped from Amazon on my 12' Focus. Install took around 45minutes. I snaked 2 tiny wires around the passenger side headliner, then around the a-frame plastic under the airbag, and down the passenger side weather stripping to the fuse box below the glove box. There is a vertical bolt attached to the frame to the left front of the fuse box if you look up and the circle connector on the wiring fit the bolt perfectly to use for the grounding wire. Then I used an Add a Fuse on Fuse #85 which is a 7.5a fuse to attach the 12v wire(bare in mind the auto dimming mirror draws very little power). Attached mirror, plugged it in, and it works perfect.
Btw, the auto dimming mirror directions wanted me to use a vampire connector on a 12v wire but I decided add a fuse was the better route.
-sokO is offline
Old 04-08-2012, 07:47 PM   #12
TonyAKAMrClean
TonyAKAMrClean's Avatar
Fan#: 96571
What I Drive: 2012 Platinum White Ti Sedan
FF Reputation: 1 TonyAKAMrClean Good Standing Member
I have the auto dimming mirror and I can tell you, I wish it had an on-off switch. When cops are parked around here, they won't pull out for you going 5-9mph over the limit, but if they're behind you they'll pull you over for it. The mirror is so dark that when it dims, you can't see anything but the headlights, so when someone's behind you, you have no idea what kind of car it is. Kind of annoying. I think I'm going to figure out a way to cover up the sensor to turn mine on and off.
The Storm Trooper:
2012 Focus Titanium 4dr - Plat White - Arctic White Pkg - Prem Pkg - Wint Pkg - Moonroof
TonyAKAMrClean is offline
Old 04-08-2012, 08:22 PM   #13
jimmyt
jimmyt's Avatar
Fan#: 90069
What I Drive: 2012 Sterling Gray Focus titanium
FF Reputation: 1 jimmyt Good Standing Member
Easy solution, don't speed!
jimmyt is offline
Old 04-08-2012, 10:58 PM   #14
TonyAKAMrClean
Fan#: 96571
Hah! Fair enough. Even still I'm not here for tips on how to drive. I don't consider less than 10 over speeding, neither do the cops. Even if they pull you over for it they'll only give you a warning. Most everyone here drives the same speeds I do. All that aside, just felt the need to share my thoughts on the titanium auto-dimming mirror. It needs an on/off swtch or a sensitivity setting.
The Storm Trooper:
Old 04-08-2012, 11:34 PM   #15
-sokO
-sokO's Avatar
Fan#: 93367
The one I installed has a on/off. That's crazy you cant turn the OEM one on / off. I wish I could get side dimming mirrors also, my eyes are sensitive.
-sokO is offline
Old 02-08-2013, 09:22 AM   #16
HoneyBadger
Fan#: 104860
What I Drive: 2012 Ford Focus SEL
FF Reputation: 1 HoneyBadger Good Standing Member
Was anyone able to find out if there is a plug for the auto dim mirror? I have an SEL model and I know I could have had the option. I just don't know for sure if ford does all the wiring in case an option is added. Otherwise I would do the add a fuse part BUT I would also be wiring a radar detector so I don't know how many open fuses turn on with the car.
HoneyBadger is offline
Old 02-08-2013, 02:16 PM   #17
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,041, Level 17
Points: 1,041, Level: 17 Points: 1,041, Level: 17 Points: 1,041, Level: 17
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 4 thejordan Good Standing Member
I'm pretty sure there is a harness going up passenger A pillar to the headliners. it should be glued down. use a multimeter to check.
thejordan is offline
Old 02-11-2013, 01:44 PM   #18
Flybigrc
Flybigrc's Avatar
Fan#: 103155
What I Drive: 2013 Ford Focus ST
FF Reputation: 1 Flybigrc Good Standing Member
So has anyone had this Gentex mirror with the garage door opener installed by the dealer? If so how much was it? I wish it came on my ST, seems like a bit of a ripoff that it did not considering the cost of the ST.
2013 Focus ST Performance Blue
2004 Corvette Coupe Magnetic Red
1968 Corvette Convertible Safari Yellow
Flybigrc is offline
Old 02-12-2013, 01:49 PM   #19
HoneyBadger
Fan#: 104860
I would just call and ask. Might be close to $250.
Old 03-10-2013, 04:30 PM   #20
JasDmw
Fan#: 105501
What I Drive: 2013 Focus Ti Hatch Sterling Grey
Points 215, Level 4
Points: 215, Level: 4 Points: 215, Level: 4 Points: 215, Level: 4
Level Up 30% Completed
FF Reputation: 1 JasDmw Good Standing Member
I just had a GENK40 gentex autodimming mirror with homelink installed yesterday. Used my dealers recommended aftermarket electrical install shop. Unfortunately, the autodimming function is not working. Also, whenever I press one of the 3 buttons to activate a garage door, the 4 way flashers come on! Pressing one of the buttons again turns them off. Anyone else with this type of aftermarket install have this issue? Note that I did get the homelink to work fine to open my 2 garage doors. Am using the 3rd, unused homelink button for shutting off the 4 ways. Do intend on taking the car back to that shop, but am looking for some insight first. The installer says he works on many new fords and the 5 wires in there were a piece of cake for him. Obviously not, unless the mirror is flawed.
JasDmw is offline
