2012 Focus Wheel/Tire Guide - Page 15 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-09-2012, 01:30 PM   #141
wanna1
Fan#: 84689
What I Drive: 2008 Mazda MX5
FF Reputation: 1 wanna1 Good Standing Member
Originally Posted by RonMaiden View Post
Finally got my new rollers.
What are the sizes of those rims and tires?
Thanks!
wanna1 is offline
Old 07-09-2012, 01:41 PM   #142
RonMaiden
RonMaiden's Avatar
Fan#: 99230
What I Drive: 2012 Red Candy Metallic Hatch SE
Points 4,216, Level 41
Points: 4,216, Level: 41 Points: 4,216, Level: 41 Points: 4,216, Level: 41
Level Up 33% Completed
Forum Activity 11%
FF Reputation: 6 RonMaiden Good Standing Member
17x7 with 215/50s which is the OEM sizes. The fitment is pretty good but I wouldn't mind a set of Eiback pro-kit springs which is said to give it a .8" drop which would take that gap away nicely.
'12 Focus Red Candy SE Sport 5 spd
'99 Toyota 4Runner Sport
'11 Subaru WRX STI Hatch
RonMaiden is offline
Old 07-09-2012, 01:54 PM   #143
wanna1
Fan#: 84689
Thanks!!
They look good!! I have the same color 5 door.
wanna1 is offline
Old 07-24-2012, 07:28 PM   #144
mrpostman
Fan#: 95963
What I Drive: 2012 Focus Titanium
FF Reputation: 1 mrpostman Good Standing Member
Help please!!! I have a question regarding winter tires and appropriate size. I am a litte unfamiliar when is comes to changing size from the original manufacture. For my previous card, I have always used the original rims and swapped only the tires for the winter. I have a Focus Titanium with the 18" rims. I am looking at purchasing a separate set of winter tires and rims but in size 17". I assume going with the "standard" Titanium tire size of 215/50R17 would be the best while using 17X7 rims with a proper offset. Can anyone provide any tips or advice on this? I don't want any issues and I figured using the size that Ford uses for the standard Ti rim/tire would be most appropriate.
mrpostman is offline
Old 07-24-2012, 07:36 PM   #145
SterlingArcher
Fan#: 100651
What I Drive: 2012 SE hatch, Sterling Gray
FF Reputation: 1 SterlingArcher Good Standing Member
Search for an online tire calculator, you can enter the 2 different tire sizes and it will tell you the differences, mainly if your speedo will be off. Another option is to put your info into tirerack.com, select the appropriate 17x7 wheel, and click 'shop for tires'. They'll show you the best recommended size and they are typically dead on right.
SterlingArcher is offline
Old 07-24-2012, 08:20 PM   #146
jsr72
jsr72's Avatar
Fan#: 97393
What I Drive: MK III
Points 153, Level 3
Points: 153, Level: 3 Points: 153, Level: 3 Points: 153, Level: 3
Level Up 6% Completed
FF Reputation: 5 jsr72 Good Standing Member
For snow, narrower tires are better. Why not drop down to the 16" or 15" stock size? You can run snow chains on those sizes too if needed.
jsr72 is offline
Old 07-24-2012, 09:21 PM   #147
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
What I Drive: LesVagon
Points 3,706, Level 38
Points: 3,706, Level: 38 Points: 3,706, Level: 38 Points: 3,706, Level: 38
Level Up 38% Completed
FF Reputation: 16 TiStick Great Standing Member
I too have the Ti 18's, but I also have a set of 205/50-17 Blizzaks in my garage waiting to be mounted. I am picking up a set of OEM 17's next week to do exactly what you were thinking. It will work just fine.
Sonic's Mk3 Crew #11
Hatch Nation#163
Originally Posted by suss6052 View Post
Watch out for the D
TiStick is offline
Old 07-25-2012, 12:26 PM   #148
Dr. Woo
Dr. Woo's Avatar
Fan#: 90817
What I Drive: 2012 Focus SE Sport SGM
FF Reputation: 0 Dr. Woo Newbie
Is there a generally-accepted "safe" range for wheel spacers? I have a set of +60mm offset Jaguar wheels (17x7.5) that I want to use, but the backspacing is only 1mm short of the Handling Package's wheel/tire set, and the wheels will look even more "sunk in" to the well. At what point would we need new studs?
I know zx3matt is using 15mm spacers on his (stock) rear wheels, but I'm not sure if he replaced the studs.
╠╬╝ 2012 SE Sport - SGM | 2009 Pontiac G8 (2011-2011) | 2008 VW R32 (2007-2011) | 2006 VW GTI (2006-2007) | 2001 Audi A4 (2002-2006)
Dr. Woo is offline
Old 07-25-2012, 12:57 PM   #149
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
I think my math is correct.....
zx3Matt is using 15mm on +45mm offset wheels, effectively making a +30mm offset. So, the +60 Jag's would end up at +45, which should be fine. I'm fairly certain he is using OE studs, but I'll ask him when I go get his OE wheels that he replaced with new hotness.
Hatch Nation#163
Watch out for the D
TiStick is offline
Old 07-25-2012, 01:33 PM   #150
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,017, Level 96
Points: 26,017, Level: 96 Points: 26,017, Level: 96 Points: 26,017, Level: 96
Level Up 67% Completed
Forum Activity 56%
Activity: 56% Activity: 56% Activity: 56%
He replaced the studs on the 15mm set, not on the 5's up front. I think 8 is the max we can get away with without changing studs.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
