2nd oil change much better than the first - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus SVT > SVT Performance (2002-2004)
Old 10-12-2004, 07:30 PM   #1
blee
Fan#: 5962
What I Drive: 2004 Sonic Blue SVT Focus ZX5
FF Reputation: 1 blee Good Standing Member
I learned my lesson after the first oil change debacle on this car. This time I put the car on ramps and waited a good two hours before crawling underneath. Yeah, it's better to change oil when it's hot...well, not at the expense of burned flesh. And since I typically change oil every 3000 miles or so anyway, I'm not too worried about draining non-hot oil. I had my skin all over the header pipes this time and my arms are as perfect as they were before I started. :p
Since I'm the one who tightened the oil filter this time, and not the boys in Hermosillo, it came off without any major fuss. I loosened it from below, then reached down for it through the engine bay and unscrewed it the rest of the way. Just one harness connector to disconnect, and a nearly no-mess filter change.
Finally, since the car is now over 4000 miles old, I put in Mobil 1. I've experienced valve tapping noises, particularly on cold mornings, with the dino oil. The tapping got louder as I burned up more oil; I suspect that I was down maybe .25 - .5 quarts before I changed oil today. Now the engine is smooth again, and I expect the better lubrication to lead to slightly less valve noise. We'll see about that.
blee is offline
Old 10-12-2004, 07:44 PM   #2
RockyNBullwinkle
Fan#: 12930
What I Drive: 2002 SVT Focus, 01 Silverado Z71
FF Reputation: 1 RockyNBullwinkle Good Standing Member
What harness did you disconnect?
I've never disconnected anything through the course of an oil change. You should have went with Royal Purple as well, I liked Mobil 1 before I tried Royal Purple. I'm hooked now. You want to talk about quiet engine and smooth running. Royal Purple or Redline :D
Comment to wife: " Who's side of the car is the steering wheel on? ALRIGHT THEN I'LL CONTINUE TO DRIVE IF THAT'S OKAY WITH YOU!!!"
RockyNBullwinkle is offline
Old 10-12-2004, 09:06 PM   #3
blee
Fan#: 5962
There's a harness with the female end sort of held in place near the passenger side shock tower. By disconnecting that I was able to snake my arm through the engine bay from above to access the oil filter, making its removal a no-mess proposition. Truthfully, there isn't a whole lot of oil that comes out of there anyway...but I was just being anal retentive. It would have been just as easy to do it all from underneath the car with a few more paper towels.
Yes, RP and RL make some good fluids. I just can't justify the extra expense for something I already change more frequently than indicated by the maintenance schedule.
blee is offline
Old 10-12-2004, 09:26 PM   #4
d3bilhan
Fan#: 12408
What I Drive: 2002 Silver ZX5
FF Reputation: 1 d3bilhan Good Standing Member
If you were starting to get valve noise at 4,000 miles. I would seriously think about whether you have a problem.
Support Our Troops!
Drive like you mean it!
[img]
d3bilhan is offline
Old 10-12-2004, 09:37 PM   #5
blee
Fan#: 5962
In my case, I suspect the valve noise was a result of low oil levels. I'm usually super-vigilant about chekcing oil levels and topping off as needed, but I lapsed over the past few months and I realized last weekend that I was definitely low. Can't say how much, exactly, but that may have had an effect. It certainly wasn't low enough to damage the cams.
That said, I've got my eye on it. i doubt there's a problem, but one never knows.
blee is offline
Old 10-12-2004, 09:55 PM   #6
RockyNBullwinkle
Fan#: 12930
Well the SVT is already a pretty loud engine as it is. The only way I found to get rid of the tapping from the valves completely was switching fluids. I wouldn't worry about it too much. The SVTOA board 2 years ago had a lot of complaints about the valve noise, some speculated that it was due to a softer composite in the cam. Techs said it was natural. My Royal Purple said bye bye to the noise.
Old 10-15-2004, 05:21 PM   #7
lopoetve
Fan#: 13806
What I Drive: 2003 Sonic Blue SVT Focus
FF Reputation: 1 lopoetve Good Standing Member
wait a sec, you're burning oil at 4000 miles? Or leaking it???
duh...
lopoetve is offline
Old 10-15-2004, 05:45 PM   #8
blee
Fan#: 5962
burning. The last 4000 miles have been, er, enthusiastic. :)
blee is offline
Old 10-15-2004, 07:30 PM   #9
RockyNBullwinkle
Fan#: 12930
The engine will burn oil during break in. A very small amount but none the less it will. This is due to the clearances of a brand new engine. The rings are not fully seated thus allowing a small amount of oil to enter the combustion chamber.
Old 10-15-2004, 09:50 PM   #10
blee
Fan#: 5962
Oil will also sneak past the rings in hard driving situations on some engines. I've experienced this with two cars I've owned in the past, which didn't leak a drop of oil but would consume it when not driven gently. Not a big deal, IMHO.
blee is offline
Similar Threads
why do cars run way better after an oil change? arlenn Ford Focus & General Car Chat 32 11-20-2009 06:01 PM
Best pistons for PWSC boost shineboy General Forced Induction 46 08-21-2009 05:45 AM
oil change at wally world focuspwr DURATEC Performance (2003-2007) 19 01-17-2007 04:11 PM
chevy dealer can't even change my oil Kicknzx3 Ford Focus & General Car Chat 48 09-01-2006 05:21 PM
Oil Change Help Lil PZEV DURATEC Performance (2003-2007) 14 10-07-2003 10:11 PM
