Removing OEM shift knob: How to - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 11-27-2011, 01:27 AM   #1
Twenty
Sonic's Mk3 Crew #17
Twenty's Avatar
Fan#: 90312
What I Drive: 2012 YB SE sedan w/ ST exterior
Points 22,520, Level 93
Points: 22,520, Level: 93 Points: 22,520, Level: 93 Points: 22,520, Level: 93
Level Up 17% Completed
Forum Activity 14%
FF Reputation: 10 Twenty Great Standing Member
Tonight I decided to go ahead and take apart the shift knob/boot/trim on my Focus, to figure out the procedure. Searching forums showed lots of questions but no definite answers for taking everything apart, nor were there any for the thread pitch of the shift knob.
So, here's how it went:
First, remove the trim piece around the base of the shift boot. There are clips all around it, but the ones that really hold it down are located in three of the four corners (The corner missing one is the rearward passenger side, next to R). By gripping the trim piece through the boot, some firm tugs and pulls should see them pop out, one by one. I shifted through a few gears to reposition the shifter, giving the boot extra slack when needed so that I didn't stretch it. For undoing the knob, grip the top of the boot to prevent it from spinning and start unscrewing. It can take a fair bit of effort to get the knob to start turning.
When the whole assembly is out of the way, this is what's left:
This is everthing that came out, taken apart.
The boot clips to the underside of the trim. It's very easy to remove and clip back in - the boot itself is pretty much permanently mounted to the plastic base that allows it to clip in though. An aftermarket boot would probably have to be attached to this base (With the original boot cut out) if you're looking for a quality, OEM-looking install.
The shift knob is held to the boot via a clip that sandwiches the top of the boot between itself and the base of the knob.
Said clip sits here on the boot (Looking from the inside)..
..and the knob then pops in here.
After figuring out the removal and installation procedure, next was to measure the thread pitch. I'm brand new to Focuses, so I didn't know if it's be the same as previous generations or not. I measured it as 12 x 1.25.
So anyway, that's what I discovered in my trial tonight. Now that I know how, and the thread pitch, I can go pick a nice new shift knob for the Fofo. Hope this helps!
officialTHREETWENTY
2012 YB Focus SE Sedan [featured in Performance Ford, Sept '14]
1992 BW Grand Prix SE Sedan [restomod project]
SR#74/SMk3C#17/YBOC#03
Bill M.
Twenty is offline
Old 11-27-2011, 10:23 AM   #2
mainest
mainest's Avatar
Fan#: 60163
What I Drive: '04 Red Euro SVT
Points 1,869, Level 25
Points: 1,869, Level: 25 Points: 1,869, Level: 25 Points: 1,869, Level: 25
Level Up 69% Completed
Forum Activity 3%
FF Reputation: 8 mainest Good Standing Member
Buy-Sell-Trade Rating: (12)
Very nicely done, great pics. Thanks for sharing!
mainest is offline
Old 11-30-2011, 09:09 AM   #3
ihdillon
ihdillon's Avatar
Fan#: 88321
What I Drive: 2012 Blue Candy Metallic
Points 577, Level 11
Points: 577, Level: 11 Points: 577, Level: 11 Points: 577, Level: 11
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 1 ihdillon Good Standing Member
Awesome write up, but I am stuck with removing the shift knob from the boot. How do you unclip the shift knob from the boot?
ihdillon is offline
Old 11-30-2011, 09:51 AM   #4
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,416, Level 29
Points: 2,416, Level: 29 Points: 2,416, Level: 29 Points: 2,416, Level: 29
Level Up 78% Completed
Forum Activity 11%
FF Reputation: 13 BetaDnB Great Standing Member
I like you.
P.S. I just added the Blox teardrop knob to my Christmas list.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is online now
Old 11-30-2011, 02:32 PM   #5
Twenty
Twenty's Avatar
Fan#: 90312
Forum Activity 14%
ihdillon: I assume you have it apart and can see the clip that sits under the boot, holding the knob in place? Note that there are four tabs which clip in place and secure the knob; using two small flathead screwdrivers (Read: model / R/C size), I worked them between the knob and two of the tabs, prying them open. A couple of good yanks and the knob popped out. The tabs are very stiff, so don't be surprised if you have to really work at them for a minute.
BetaDnB: A Blox knob is on my list now too. I'm waiting on a local shop to get the specific one I want in, so that I can go treat the Focus - I mean, myself - to a little gift.
officialTHREETWENTY
Bill M.
Twenty is offline
Old 12-01-2011, 09:57 AM   #6
ihdillon
ihdillon's Avatar
Fan#: 88321
Thanks Twenty! I installed a shift knob this morning! Added a new shift knob today!
ihdillon is offline
Old 12-01-2011, 12:58 PM   #7
Twenty
Twenty's Avatar
Fan#: 90312
Forum Activity 14%
You're welcome! Looks good, I can't wait to pick mine up.
officialTHREETWENTY
Bill M.
Twenty is offline
Old 12-27-2011, 02:21 PM   #8
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Forum Activity 11%
Installed! My only issue was the front right clip. I couldn't get it to come out all the way. The retaining nut that came with the knob makes it a little taller, so the boot gets a bit tight, but I don't think tight enough to pull it out of gear. The remedy? Short shifter. HURRY UP STEEDA!
Old 12-27-2011, 03:22 PM   #9
Twenty
Twenty's Avatar
Fan#: 90312
Forum Activity 14%
Looks good! I went with a Blox as well.
officialTHREETWENTY
Bill M.
Twenty is offline
Old 12-27-2011, 08:23 PM   #10
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Forum Activity 11%
I've actually modified how I have my shift boot. I'll post a pic tomorrow. I have a feeling I'll be taking my knob off and keeping it with me in certain areas.
