Motorcraft battery->red indicator->battery is dying? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-26-2011, 04:29 PM   #1
BeeFzX3
BeeFzX3's Avatar
Fan#: 46655
What I Drive: 2013 Focus ST
Points 5,963, Level 50
Points: 5,963, Level: 50 Points: 5,963, Level: 50 Points: 5,963, Level: 50
Level Up 7% Completed
FF Reputation: 40 BeeFzX3 Great Standing Member
Buy-Sell-Trade Rating: (8)
Question Motorcraft battery->red indicator->battery is dying?
A year ago I replaced my battery with the motorcraft one. Few days ago, after it was sitting for about 2 days, I try to start it and it cranks really slowly. I thought it might not even start, but after like 20 turns it finally starts. So I check the battery and the indicator is red.
I drove it for about 20min and then later for 1hr, indicator stays red. It sat for 3 days and started just fine.
Then I went to the dealer so they can check it, they checked it and told me that it's fine.
What does that red indicator really mean? It's staying red.
Is the battery dying?
If it's bad I want to make ford replace it under warranty. Dealership told me even if the indicator is red, they won't replace the battery because when they tested it, it showed 590 cranking amps. Well duh I just drove the car there for 20min so the battery got charged.
Could something else be malfunctioning? When the car is running my volt gauge shows 14volts, so alternator is working.
If it's not the battery I don't know what could have caused it to crank slowly...
Any input/ideas would be greatly appreciated
Thanks!
BeeFzX3 is offline
Old 11-26-2011, 04:45 PM   #2
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
FWIW, from Ford diagnostic manual: "No battery with a red test-eye should be replaced. The red eye only means the battery is discharged, not necessarily defective."
They then go on to say to use a proper digital battery analyzer meter to get true readings.
Try removing, cleaning and re-securing battery clamps as a first step.
BC_ZX3 is offline
Old 11-27-2011, 03:47 PM   #3
csvt2060
csvt2060's Avatar
Fan#: 84122
What I Drive: 2013 Ford Escape Titanium
FF Reputation: 2 csvt2060 Good Standing Member
Depending on your driving, it may take quite some time to turn back green.
A good deep charge with a trickle charger should turn it back green within 24 hours.
csvt2060 is offline
Old 11-27-2011, 05:18 PM   #4
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
After you tighten the battery clamps and I am sure you tightened the 10mm nut as much as you can... see if you cannot wiggle the battery clamps sideways.
I just seen too much of that lately...
mikeeshaq is offline
Old 11-27-2011, 05:23 PM   #5
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
Points 5,157, Level 46
Points: 5,157, Level: 46 Points: 5,157, Level: 46 Points: 5,157, Level: 46
Level Up 4% Completed
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
Charge it with a battery charger. Then have the battery and the charging system load checked. And it should still be under a warranty.
iroc34 is offline
