03 Focus Runs Very Rough- SPI engine - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-26-2011, 02:20 PM   #1
fdbyrne
Fan#: 92163
What I Drive: 2003 base model
FF Reputation: 1 fdbyrne Good Standing Member
First, an apology. This is going to be a long initial post but I want to give you everything that I know because I'm hoping somebody out there has had this problem and fixed it.
The situation: The car has 85,000 miles, has an automatic tranny, and the small 2.0 I4. It's run great until about a month ago. Now, it runs very, very rough (most of the time). By rough, I mean it's much louder than normal and there is an intense vibration at all RPM levels. It's most notable at idle but still apparent when driving. It never stalls. The problem doesn't go away once the car warms up but when warm it is slightly better at idle than when cold. The vibration is so intense that the dash rattles. No check engine light yet.
Here's what makes it really weird. Running the car around for a while and then parking it in the garage for about half an hour seems to fix the problem. Under those circumstances it runs like a dream, smooth and quiet. My only guess is that the problem isn't related to operating temperature but to the temperature of the engine compartment itself. Sitting in a garage with no wind, hood down, and a hot engine right in the middle seems to solve whatever is causing my problem.
The background: Less than a year ago we had my mechanic replace part of the EGR system. We were hearing a loud exhaust like noise but the exhaust pipe and muffler looked fine. The mechanic said I had a crack in my exhaust relay pipe. He replaced it and while it was in there we had him change the plugs and wires. It ran fine after that.
Since the current problem started in the last month I've done the following:
1. replaced the air filter
2. replaced the PCV valve
3. inspected the PCV hose and connectors (nothing wrong)
4. ran a tank of gas with fuel injector cleaner
5. tested the EGR valve by pulling the vacuum hose off the top, and blocking the hose. The idle didn't smooth out. I applied a vacuum to the EGR valve manually and the car immediately stalled which tells me that the EGR valve itself is working fine.
All of the online forums pointed to a fault in the EGR system or a hole in the PCV hose as the likely culprit. I'm certain the PCV assembly is not the problem. The EGR system might still be the problem but not with the valve itself. The vacuum pressure going to the valve puzzles me. I read that there should be no vacuum applied at idle and there was a pulsing sort of pressure coming from the vacuum hose. I don't know if that matters or not since the problem didn't seem to get better when the vacuum hose was completely separated from the EGR valve.
At this point I'm guessing that there could be a problem with the EGR sensor itself but more likely I have a pinhole in a vacuum hose somewhere. Maybe when the vacuum hose itself gets warm enough it becomes expands to close off the very small hole that's causing the problem?
Any guesses here would be greatly appreciated.
fdbyrne is offline
Old 11-26-2011, 03:59 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
We really have to know what engine you have. There were 2 2.0L engines offered in that year of Focus. One is DOHC, and one is SOHC. The DOHC has Zetec written on the valve cover. The SOHC has "Split Port Injection" written on the valve cover. If you have a hatchback, it's a DOHC, if it's a sedan, then it's likely to be the SOHC SPI engine.
So what is it- Zetec or SPI?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 11-26-2011, 04:02 PM   #3
fdbyrne
Fan#: 92163
It's the SOHC.
fdbyrne is offline
Old 11-26-2011, 04:09 PM   #4
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 5%
Oh no
Ok, well it's still running, so that's a good sign. I'm going to have to change your title so former and current SPI owners can give you the low down help you need. First off, you might as well stop spending money replacing parts that may or may not need replacement. You have to save up for a potential larger repair in the near future.
The SPI is known for dropping valve seats, specifically in the #4 cylinder. We don't know what causes it, but we do know that nearly all SPIs have this problem regardless of how well maintained the engine is. All is not completely lost because nobody that has had new valve seats installed has ever had a problem. However, if it is not repaired then the chances that you'll need a new engine are very high. The chances that you won't be able to find a good SPI engine in a junkyard are also very high, and if you do find one you'll wonder why it costs $1500 instead of the $500 you'd pay for a Zetec. This is the problem we've found with SPIs.
Running rough and clattering from the valve train is one sign. Former and current owners can tell you more, but you have some unfortunate news to deal with. You might want to try completely removing the EGR and capping it's exhaust pipe off at the exhaust manifold. It is possible that the EGR is part of the problem since it allows hot exhaust to pass through to the cylinder head near the #4 chamber.
Be eclectic.
Old 11-26-2011, 04:16 PM   #5
fdbyrne
Fan#: 92163
If that's right its certainty very bad news. One question though. Why would it get better periodically and run smooth and fine for hours at a time? The problem you are describing sounds like the symptoms would be fairly consistent. Are there any tests that can be done now to tell me if that's the problem?
fdbyrne is offline
Old 11-26-2011, 04:39 PM   #6
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 5%
No, it will get better, then worse IIRC. I have to change the title. Then someone who has had the experience will tell you what it did to them. The first thing you should do is a compression test to determine if you do have that problem.
Be eclectic.
Old 11-26-2011, 04:51 PM   #7
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
If your compression checks out - always good to check with the SPI motor as whynot states - your "vibration at cold idle/OK when warm" description suggests to me the front hydraulic motor mount needs attention.
BC_ZX3 is offline
Old 11-27-2011, 07:15 AM   #8
alz focus
Fan#: 67546
What I Drive: 2002 Blue SE
Points 975, Level 16
Points: 975, Level: 16 Points: 975, Level: 16 Points: 975, Level: 16
Level Up 75% Completed
FF Reputation: 5 alz focus Good Standing Member
^^^^^2nd that, motor mounts.
If you were having valve seat issues, you would definitely know it. Very loud rattling in the top end and lose of power.
Al
2002 Focus SE Zetec ATX
2000 Focus SE SPI ATX
2006 Freestyle SEL AWD
alz focus is offline
Old 11-27-2011, 09:50 AM   #9
fdbyrne
Fan#: 92163
Thats what I was thinking, thanks. There are no strange noises and no lost power. There is more noise but its an exhaust sort of noise.
fdbyrne is offline
Old 11-27-2011, 12:13 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,737, Level 73
Points: 12,737, Level: 73 Points: 12,737, Level: 73 Points: 12,737, Level: 73
Level Up 72% Completed
Forum Activity 99%
Compression check first as mentioned, once you know the engine is mechanically sound the first hurdle has been passed....
While doing the compression check, you can see what the recently replaced plugs look like - that can give hints as to other operating problems...
Motor mounts are a common vibration issue (yes, to the point of the dash rattling), and enough vibration can cause exhaust piping to break making even more noise...
Of course if the engine isn't running smoothly as well, ALL of these other problems get that much worse...
Bottom line, as long as the engine basic mechanical condition is sound, the possible other issues can be addressed since they are all common age related maintenance issues that we see often on the forum.
It just gets a bit trickier when more than one problem has developed, since a single fix won't "solve" the problem by itself & each issue makes the others worse...
Luck!
sailor is offline
