FUELLY of each of us - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-30-2011, 05:04 PM   #31
Gatorgibson
Fan#: 91669
What I Drive: 2012 HB Titanium
FF Reputation: 1 Gatorgibson Good Standing Member
<a href="http://www.fuelly.com/driver/gatorgibson/focus" target="_blank"><img src="http://mefi.us/images/fuelly/sig-us/98683.png" width="500" height="63" alt="Fuelly" title="Share and compare MPG at Fuelly" border="0"/></a>
Gatorgibson is offline
Old 11-30-2011, 05:45 PM   #32
rmlephiew
Fan#: 91437
What I Drive: 2012 Sterling Gray Titanium Hatch
Points 10, Level 1
Points: 10, Level: 1 Points: 10, Level: 1 Points: 10, Level: 1
Level Up 19% Completed
FF Reputation: 2 rmlephiew Good Standing Member
rmlephiew is offline
Old 11-30-2011, 06:15 PM   #33
Gatorgibson
Fan#: 91669
Originally Posted by Gatorgibson View Post
This is actually up from 25.1 for an avg. My last tank was at 29.1 so heading in the right direction!
Old 11-30-2011, 10:09 PM   #34
tmnCA
tmnCA's Avatar
Fan#: 91665
What I Drive: 2012 Candy Blue Hatchback SE, Sport
FF Reputation: 0 tmnCA Poor Behavior Needs Improvement
Originally Posted by fanoftheliving View Post
I ALWAYS reset the average mpg meter in the car when I fill up the car, at the same time calculating the average mpg manually (my fillups take a very long time). They should theoretically be very close, but in my car they are not. It's annoying, I wish the dash was more accurate, but at least in my case it is way off, by as much as 10%. Sometimes it is more accurate. I have not been able to figure out under what circumstances. I thought for a while that it was because some gas stations will pump a little bit more gas in after the pump clicks off. But the last 2 gas tanks I made sure this was not the case.
Bottom line is personally I would not trust the "Distance to E" on the dashboard UNLESS my manually calculated average MPG was identical to the average MPG on the dashboard since last reset. There may be something else going on that I am not aware of. If I figure something out, I will let everyone know.
An average is more accurate the more data points there are, so re-setting every fuel-up actually makes your reading less accurate. I use trip 1 for the perma-record never to be reset, and reset trip 2 when I feel like it. If you reset often, your average will be "pulled" by very low or high data points. If your data set covers a much longer time period it will portray your average most accurately.
Anyway I fuel up when the gauge shows less than 1/8, it's not good for your fuel pump to let it get too close to empty and in wet/cold weather you can get moisture in the fuel system if gas gets too low.
tmnCA is offline
Old 11-30-2011, 11:19 PM   #35
VOLDAR
VOLDAR's Avatar
Fan#: 90444
What I Drive: Volt 2014, White Diamond
FF Reputation: 3 VOLDAR Good Standing Member
I have a little question. Can we only post the fuelly and talk about everything else in another topic ? If someone is interested to see how the mpg were get, it has to click on the fuelly of the person he's interested in and that's it. All the data he need to know is there.
White Platinum Metallic Tri-Coat
303A, 6-Speed SelectShift Automatic, 17" Aluminum wheels, Luxury Package,
Parking Technology, Navigation, Winter Package
---replaced by---
Chevy Volt 2014, White Diamond, Luxury Package, S1, Navigation.
VOLDAR is offline
Old 12-01-2011, 11:06 AM   #36
chaimav
Fan#: 91850
What I Drive: Sterling Gray 2012 SEL Hatch
Points 717, Level 14
Points: 717, Level: 14 Points: 717, Level: 14 Points: 717, Level: 14
Level Up 17% Completed
FF Reputation: 2 chaimav Good Standing Member
Just opened the account
chaimav is offline
Old 12-01-2011, 12:49 PM   #37
Jarn*
Fan#: 87625
What I Drive: 2012, Silver Focus, Ti
FF Reputation: 1 Jarn* Good Standing Member
Fuelly image test
trying to put this in my signature...
[URL=http://www.fuelly.com/driver/Jarn/focus][IMG]http://mefi.us/images/fuelly/sig-us/85071.png[/IMG][/URL]
Jarn* is offline
Old 12-03-2011, 12:11 PM   #38
VOLDAR
VOLDAR's Avatar
Fan#: 90444
^ up
---replaced by---
VOLDAR is offline
Old 12-03-2011, 02:12 PM   #39
EddieWinslow
EddieWinslow's Avatar
Fan#: 86598
What I Drive: 2012 Race Red SEL Hatch
FF Reputation: 1 EddieWinslow Good Standing Member
Had two bad fill ups to do low tire pressure.
EddieWinslow is offline
Old 12-04-2011, 09:38 PM   #40
Lipshurt
Fan#: 92314
What I Drive: 2012 blue focus SE
Points 732, Level 14
Points: 732, Level: 14 Points: 732, Level: 14 Points: 732, Level: 14
Level Up 32% Completed
FF Reputation: 2 Lipshurt Good Standing Member
Assuming you just copy the link.....
http://www.fuelly.com/driver/lipshurt/focus
After two fill ups, pretty good. Over the EPA numbers at least:)
Lipshurt is offline
