Throttle Body Comparison - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-23-2011, 02:50 PM   #21
apagios
apagios's Avatar
Fan#: 40891
What I Drive: '03 ZX5 SVT, '05 Mazdaspeed Miata
Points 873, Level 15
Points: 873, Level: 15 Points: 873, Level: 15 Points: 873, Level: 15
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
FF Reputation: 3 apagios Good Standing Member
Originally Posted by SVTFocusOnMe View Post
Yea I think the car should want to rev easier. It feels like it takes forever to actually take off in first gear because of the slow response.
Actually i think if you are talking about it taking forever to rev in 1st gear and pull away you are more concerned with Flywheel.
The throttle response is "slow", but I think what you are feeling is the engine trying to spin up. Do you have a stock flywheel?
Stock flywheel is 24.5 lbs, I have a spec 12 lb Al flywheel and my SVTF revs like crazy. I love it.
And Yes I can feel the sluggish throttle response when I first start, but "slow" response to the throttle input is still on the order of vastly less than 1 second. I suspect your sense of "takes forever" is most likely due to the engine spinning up a 24.5 lb flywheel. If your sense is that it's on the order of seconds, you are no longer talking about throttle response.
Personally I looked at the CFM throttle body a lot and came to the conclusion that with a light weight flywheel I could just deal with the less then 1/4 second throttle response delay since my engine revs so much faster now. $250 is a LOT of money for only 1 or 2 mm. No way I am spending that much money to gain 1 mm in diameter with the BBK. Let alone 2 mm for the CFM. (for a street car, if you are competitively racing the SVT where every ounce of performance counts, I can understand forking over for a slightly larger TB)
If you don't have a light weight flywheel I suggest looking into them seriously when you come due for a new clutch. They are very common to come with a clutch kit since it's easily done as 1 job. I am not sure I would spend the money to put in a lightweight flywheel if I didn't need a clutch though.
As a random plug, I love my Spec Stage 2 clutch & Al flywheel, I am on my second one (1st kit was to replace stock at 45k miles when the stock one crapped out, that lasted till 120+k miles even with LOTs of downtown DC driving in traffic, and I replaced it early during some other work)
apagios is offline
Old 11-23-2011, 06:43 PM   #22
02SVTAZ
Fan#: 90533
What I Drive: 2002 Black SVT, 2nd owner, #238
FF Reputation: 1 02SVTAZ Good Standing Member
I feel a slight bog in the throttle when I shift (2.5-3k rpm), if I only get on the throttle light-medium. If I'm in the throttle fairly hard, I don't notice it. Was wondering if this was the sort of thing that a throttle body replacement would help with. I don't need a clutch anytime soon (hopefully), and am not wild about all the noises and clunking I'm reading about with aftermarket clutch/flywheel setups in these cars. Those noises would make me nuts...
02SVTAZ is offline
Old 11-23-2011, 08:16 PM   #23
cmajaa
Fan#: 73417
What I Drive: 2003 ZTW zetec
FF Reputation: 1 cmajaa Good Standing Member
Throttle body
I ported my stock throttle body and you will feel a considerable improvement in throttle response and engine power below 2000rpm, now I don't know for a fact that I'm making any more power, but I can tell you that it feels more like I thought an SVTF should and you will enjoy driving the car a lot more.
cmajaa is offline
Old 11-24-2011, 07:18 PM   #24
Jack The Ripper
Jack The Ripper's Avatar
Fan#: 81179
What I Drive: '04 SVT ZX5 & '10 Mustang V6
FF Reputation: 1 Jack The Ripper Good Standing Member
BBK's headquarters is literally like 5 miles from my house. I just had to say that lol.
SoCal Crew #666
Jack The Ripper is offline
Old 11-30-2011, 03:01 PM   #25
blackjack
Fan#: 69988
What I Drive: Black 03 SVT
FF Reputation: 2 blackjack Good Standing Member
Buy-Sell-Trade Rating: (22)
Originally Posted by iminhell View Post
BBK is 1mm larger than stock, CFM is 2mm larger.
If that convinces you to spend $250 so be it. I don't think it's worth it.
Stock: 20.5735 in^2
BBK: 21.2114 in^2 (0.6379 in^2 larger than stock)
CFM: 21.8591 in^2 (0.6477 in^2 larger than BBK)
I don't see how this can be....
I remember when I had my old FC 65mm TB, my stock SVTF TB would actually fit inside the the FC 65mm TB. I wish I took a pic to show it.
As for the OP, I have only seen one a normal zetec BBK TB, the outsides of it isn't as smooth as the FC or CFM ones. But it worked perfect like the others. Find someone with a Powerworks SC kit installed. I think some of those kits came with a larger BBK TB.
But TurboTom is correct, i liked how everyone ignored him. A bigger TB will not yield HP gains, just better throttle response and a stiffer gas pedal due to the stiffer spring on the new TB. Porting the stock TB would be the more economical move or find one used...
blackjack is offline
Old 02-21-2013, 11:36 AM   #26
SVTFocusOnMe
SVTFocusOnMe's Avatar
Fan#: 89087
What I Drive: 2003 SVT EAP Screamin' Yellow ZX3
Points 1,097, Level 17
Points: 1,097, Level: 17 Points: 1,097, Level: 17 Points: 1,097, Level: 17
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
FF Reputation: 4 SVTFocusOnMe Good Standing Member
Okay so resurrecting this tread from the dead because I finally got the BBK TB. I have no way to compare it to the CFM but I am very impressed with the quality and impact the part has on my car.
I wrote this in another thread already but I figured I would throw it in here too. The BBK TB is on ebay for 250 shipped or make an offer. I offered both sellers 200 for it and they both accepted. Not a guarantee that it will be the same for you but if your in the market for one I think it is worth a shot. Links below...
http://www.ebay.com/itm/BBK-02-04-FO...3ccab6&vxp=mtr
http://www.ebay.com/itm/BBK-1754-02-...75d9b7&vxp=mtr
If anyone would like I can post pics of it installed.
03 Ford SVT Focus JRSC BBK
The Bad Cat (97 Merc Cougar XR7)
SVTFocusOnMe is offline
Old 02-21-2013, 07:40 PM   #27
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,236, Level 41
Points: 4,236, Level: 41 Points: 4,236, Level: 41 Points: 4,236, Level: 41
Level Up 44% Completed
Forum Activity 4%
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Ooooor you could support a site sponsor, like CFM, and purchases directly from them. Sooooo CFM continue to make parts for the mk1.
I now drive a Japanese Ford.
macdiesel is offline
Old 02-21-2013, 08:53 PM   #28
SVTFocusOnMe
Fan#: 89087
How am I a bad person for buying a quality part from a reputable company and save myself money?
Old 02-23-2013, 06:31 PM   #29
macdiesel
macdiesel's Avatar
Fan#: 31579
Forum Activity 4%
Never said "bad" or " person" in my post. Personally, I'd rather support a company that's makes more than one part for an aging chassis.
Old 02-24-2013, 05:27 PM   #30
ukfan50
ukfan50's Avatar
Fan#: 91208
What I Drive: 2003 VW Golf GTI 20th AE #2485/4000
FF Reputation: 1 ukfan50 Good Standing Member
I just left the eBay seller from post/link above a "Best Offer" of $200 (free shipping).
2003 BMP VW Golf GTI 20th AE #2845 of #4000 (Purchased 3/2014)
2002 Sonic Blue SVT Focus #1200 (Sold 2/2014)
2000 T-Red SVT Contour #1089 of #2150 (Sold 10/2011)
1998 BDP Subaru Impreza 2.5RS #1595 of #1695 (Sold 1/2010)
ukfan50 is offline
