Rear suspension squeak solved! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-16-2011, 07:03 AM   #1
RLoos
RLoos's Avatar
Fan#: 90057
What I Drive: 2007 Dark toreador red ZX3
Points 887, Level 15
Points: 887, Level: 15 Points: 887, Level: 15 Points: 887, Level: 15
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
FF Reputation: 1 RLoos Good Standing Member
I had this horrible squeak that sounded like it was coming from the right rear shock top mount. As it turned out,the right ebrake cable was squeaking where it went thru that hoop beneath the car. I cut a pice of rubber hose and zip tied it around the cable and no more squeak! Thank you focus fanatics!
RLoos is offline
Old 11-17-2011, 11:46 AM   #2
plex07st
plex07st's Avatar
Fan#: 46577
What I Drive: 2007 Pitch Black ZX4 ST
Points 173, Level 3
Points: 173, Level: 3 Points: 173, Level: 3 Points: 173, Level: 3
Level Up 46% Completed
FF Reputation: 1 plex07st Good Standing Member
I did the same thing last year. It drove me nuts before I fixed it.
plex07st is offline
Old 11-17-2011, 02:36 PM   #3
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
I'm getting the same from the front end and thought it was the cheap after market control arms I installed until a recent thread said it was the ebrake cable too.
Hmmm - never would have thought that could make a 'crunching' sound but will have to look at that also.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 11-19-2011, 04:13 AM   #4
iroc34
iroc34's Avatar
Fan#: 69289
What I Drive: 2011 Ford Taurus Limited
Points 5,157, Level 46
Points: 5,157, Level: 46 Points: 5,157, Level: 46 Points: 5,157, Level: 46
Level Up 4% Completed
FF Reputation: 18 iroc34 Great Standing Member
Buy-Sell-Trade Rating: (13)
I spent 4 hours last night chasing that damn squeak. I put the hose around my e brake cable .Still there. This has been driving me crazy for a few months. So last night I removed the sway bar and the urethane bushing. Still squeaks. I crawled up under the car and had a buddy of mine bounce the car up and down a thousand times. I lubed the crap out of every joint and bushing.. still squeak. WTF ? I took the bottom shock mount off. Up on jack stands, with the shock hanging down I found that sob ! Mine was the upper spring perch rubber . I sprayed it with white lithium grease. No more squeak. And I bet the bottom of my car won't rust either . Man what a relief.
iroc34 is offline
Old 11-19-2011, 10:47 AM   #5
RLoos
RLoos's Avatar
Fan#: 90057
Life is good!
RLoos is offline
Old 11-20-2011, 12:39 PM   #6
autolite
autolite's Avatar
Fan#: 46002
What I Drive: 2006 pitch black zx4
Points 457, Level 9
Points: 457, Level: 9 Points: 457, Level: 9 Points: 457, Level: 9
Level Up 14% Completed
FF Reputation: 3 autolite Good Standing Member
I took a plastic oil container and cut it and wrapped it around the cable and slid it thru the bracket problem solved.Been over a year no more noise
autolite is offline
Old 11-30-2011, 10:11 PM   #7
Ronsfocus
Fan#: 92267
What I Drive: 2006, Silver, ZS3, SES
FF Reputation: 1 Ronsfocus Good Standing Member
Wow, this might be it! I'm dropping it off next weekend to have it looked at and will report back. Thanks to all who have replied so far.*
zzzz
Ronsfocus is offline
Old 11-30-2011, 10:25 PM   #8
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
A little humor...
Brand new Cadillac...
Owner is real pleased except when it goes over a bump there is a klunk
Goes to dealership, can't fix right off
Brings it back again, then they start replacing stuff
No good still a klunk
Bring it back, It takes 6 burly mechanics to jerk the Cadi up and down then they hear the klunk.
The klunk is coming from an area with no access, so they cut a small hole and fish out a big nut with a note attached:
"I hope you never find this you rich xxx" [expletive deleted]
mikeeshaq is offline
Old 11-30-2011, 10:32 PM   #9
iroc34
iroc34's Avatar
Fan#: 69289
Originally Posted by mikeeshaq View Post
A little humor...
That`s probably a true story .... Funny as hell though.
iroc34 is offline
Old 12-02-2011, 01:24 PM   #10
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,388, Level 36
Points: 3,388, Level: 36 Points: 3,388, Level: 36 Points: 3,388, Level: 36
Level Up 26% Completed
Forum Activity 25%
Activity: 25% Activity: 25% Activity: 25%
Hey Ronsfocus,
Keep me up to date with your status. You can PM me with the details, including your VIN, mileage, contact info, dealer name and location. I want to make sure the issue was solved.
Thanks,
Noemi
FORD SERVICE
p: 800.392.FORD
FordService is offline
