#351 | ||||
Sonic's Mk3 Crew #17
Very convenient excuse, isn't it?
![]() Quote:
I do rather like how the ST uses a black center stack, so that's an option. Ideally, real carbon fiber would be my choice. In the meantime I'll wait for my trim to come back, and then I can reinstall that and see what I want to do next. First though, another update is coming...
Facebook.com/OFFICIALTHREETWENTY 2012 Yellow Blaze Focus SE Sedan (DD+Project) 1992 Bright White Grand Prix SE Sedan (Project) SR #74/SMk3C #17/YBOC #03 Bill M. |
#352 | ||||
MS3 mount and T1R antenna:
![]() Yesterday after work the Focus went up in the air again to have the MS3 mount installed. The photos from the install are from my phone, so I apoligize for the quality. The install is very simple, it's a total of 5 bolts (after you remove the tray under the engine) and fits perfectly. The new MS3 mount and bolt, and a comparison of it next to the stock Focus piece. ![]() ![]() Two bolts hold in the mount, and the last three hold in the 'bracket' that connects to it. All removed, it looks like this (Left and right of picture are rear and front, respectively): ![]() Installation is just the reverse of removal, with the mount going in first and then the bracket following it. The mount is at the top of this picture, though it's mostly hidden from view (Top and bottom of picture are rear and front, respectively). ![]() Really, as long as you can figure out how to remove the stock piece you can put the new one in. It's very simple. While the Focus was in the air I also grabbed a quick shot to better show the mounting of the front lip. You can see the bolts, which use the OEM clip mounting locations. ![]() With the MS3 mount in place the change is immediately noticeable. Shifting feels much more precise, and the 1-2 shift is the one that really improved. I highly recommend this upgrade. The second part of today's post deals with a part I picked up on Wednesday; a T1R stubby antenna. A fellow member of a local forum had one for sale so I messaged him and picked it up. It is much shorter than the stock piece but there has been no change in reception yet to speak of. ![]() ![]() ![]() There is a difference in finishes however, the antenna being glossy and the base being more satin. I may need to see what I can do about that. Regardless, it's time the rest of the exterior saw some more changes, since the nose has received almost all of them.
#353 | ||||
What's the difference between the ford mount and the Mazda mount??
Sent from jeremy's iPhone using FF Mobile |
#354 | ||||
Sonic Mk3 Crew #00
If Twenty doesn't mind... Stronger (steel rather than aluminum) and there's more rubber for a higher duro.
Hatch Nation #156. Sonic's Mk3 Crew Founder and #00 Moderator: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, SW Fanatics, Sonic's MK3 Crew |
#355 | ||||
Sonic Mk3 Crew #01
Sent from my stupid phone.
HN Member #161 *155 hp / 143 lb ft (DCT)* Moderator for- DURATEC Ti-VCT Performance (2012-2013) ST Performance (2013) MK3 Focus ST Focus Sonic's MK3 Crew |
#356 | ||||
Okay, sweet!
Didn't know that Leeann something new everyday!! Sent from jeremy's iPhone using FF Mobile |
#357 | ||||
I'm an A55
#358 | ||||
It just gives us something else to tinker with.
#359 | ||||
Sonic Mk3 Crew #01
Out of curiosity, how well does that antenna pick up radio stations? I replaced mine (different brand) and I may as well not even bother trying the radio because it is nearly useless now. Not a huge deal because I listen to Sirius, but I try to incorporate some function instead of just form...
#360 | ||||
I WILL correct you.
~~~~~~~~~~~~~~~~~~~~~~ <>< Sonic's Crew #015 "Werehog" --- HN005 April 2013 HOTM |
| Thread Tools | |
| Display Modes | |
