DURATEC Performance (2003-2011) The place to chat about any Duratec 23, 23E, and 20 engine performance, tuning and exhaust related upgrades.
#31 | ||||
Without the IM do you think I would be able to upgrade to a 3" MAF intake tube rather than the small FSwerks CAI tube? Once everything is complete I will be doing the tune so I am trying to squeeze as much out of everything that I can without getting the cossie IM. Who sells an upgraded MAF for the duri?
Giddyup focus.... Giddyup... |
| Sponsored Links | |||
Advertisement | |||
#32 | ||||
My plan was to modify the FSWerks CAI maybe buying a second one and cut the sections off where it tapers down and tap into it there and just use hose clamps and stuff to connect it all back up. It will need a tune for sure
DX3?.. huh?.. well ZX3 = Zetec the 05-07 has a Duratec so DX3 |
#33 | ||||
Crower stage 1's
He was going w/ crower stage 1's
Interduce Mr. Torsen to the mix |
#34 | ||||
What could I expect using stage 1's on my 23 w/ fwerk's tune/header/borla/ cfm's UDP's/ BSD plug & windage tray? & I was thinking 'bout the Escape 23 i.m.= delete's the IMRC, but still uses the IMTV.
#35 | ||||
did the stage 1 come with that pressed ring on the end for the cam position sensor.. if so whats the part number only thing left stock in me build is the cams....
2008 focus s fully built engine with nitrous... when on spray get the &^$% out of my way.... dynoing setup soon..... well when data logging is fixed.... |
#36 | ||||
i miss them summit discounts.lol. i had a friend there for yrs. he was there from 92 to 05.
i got the stage ones for 2.3 head, got the head to. not on yet. but got all the same as you it looks like. i am interested in seeing your dyno.
I spend money, I don't have. To buy things, I don't need. To impress people, I don't know. |
#37 | ||||
i got the 2.3 head ford racing spec reproduction. but im still going to use the 2.0 bottom end and thus i need the cam position sensor so i need the cams to have that press ring on them.
#38 | ||||
i got the 2.3 head as well 2.0 built bottom end but if u run the 2.0 ecu u need the cam position sensor from what im told. thats why i cant run the 2.3 cams in my build. rweally wanted to squeze out even bit out of this build. but guess it will give me somethig later to add into the car. i got all the data logging sofeware and an unlocked tuner and the tuning software from a shop i worked with. might be usefully. just want my 450 with nos goal....
#39 | ||||
#40 | ||||
sadly i have an 08... heads look the same minus all the cnc porting. all else fails imma have to use one of the other 4 heads i have for the d20. i need to sell these things all nare fresh rebuilt heads with minor porting done. might my self just get bored and hand port them.
| Thread Tools | |
| Display Modes | |
