SVT Focus short block, various Zetec and Focus SE and ZX3 parts. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-06-2011, 05:45 PM   #1
jjzx2sr
Fan#: 74691
What I Drive: 2001 Green Focus ZX4
FF Reputation: 3 jjzx2sr Good Standing Member
UPDATED Cleanign out my shop, need to make room for a new project.
The Zetec performance bottom end rebuild kit
JE forged 10.5:1 pistons in .007ths overbore, Total Seal moly rings, Eagle 4340 rod set with 3/8 ARP series 2000 rod bolts, SVT crank with Mahle main and rod bearings, Ford Racing oil pump. Rear main seal and retainer.
Crankshaft was cleaned, micro-polished and rebalanced. All parts and components mic'd and remic'd for clearances. .
Asking $1000.00
Rebuilt SPI engine:
Speed Pro pistons and rings, ARP bolts, block bored .020ths, Mahle main and rod bearings, Ford oil pump. Improved casting head, thicker in critical area's to prevent cracking and dropped valve seats. New cam and lifters and retainers. Gates timing set and water pump. Complete running engine, with intake and oil pan. All aluminum parts were cleaned and ceramic media cleaned to restore the new aluminum look.
Block was cleaned and pressured checked and machined for proper head gasket mating. Crankshaft was cleaned, micro-polished and rebalanced. All parts and components mic'd and remic'd for clearances. Rings were filled individually for each specific cylinder to ensure proper end gap.
New zero miles. Can be crated and shipped from my shop.
Asking $1250.00
Zetec parts:
2 rebuilt Zetec heads, one stock with cams, the other milled .070ths to raise the compression to 10.5:1 on a stock piston. asking 300.00 for the stock head and 375.00 for the milled head.
Stainless steel intake valves, stock size. $100.00
Ford racing high lift valve spring and retainer set. $150.00
Gates timing set for 2.0L Zetec, includes belt, pulleys and tensioner. $100.00
SVT Focus oil cooler. $45.00
SPI engine parts:
SPI improved casting head, thicker in critical areas and prevents dropped valve seats, includes, new cam, lifters and retainers. $350.00 have 3 available.
Focus Transmissions and Parts
Stock refinished flywheel. $35.00
00-04 Focus shifter cable pair, new. 135.00
00-04 Focus automatic shift cable. 35.00
4F27E transmission out of an 01 Focus SE with an SPI engine with 70k miles. $375.00
Have lots of body parts and panels for a ZX3 focus and some SE parts also.
jjzx2sr is offline
    Quick reply to this message
Old 11-06-2011, 06:59 PM   #2
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Level Up 0% Completed
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
damn i need some boost friendly pistons
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 11-06-2011, 07:56 PM   #3
jjzx2sr
Fan#: 74691
Sorry i don't have any 9.0:1 compression pistons currently.
jjzx2sr is offline
Old 11-06-2011, 08:05 PM   #4
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
damn thanx for replying thou
FF MODERATOR
RIFF CREW
Old 11-06-2011, 09:51 PM   #5
jjzx2sr
Fan#: 74691
I have a friend that started a turbo build but then totaled his car, ill see if he still has his turbo build lying about.
jjzx2sr is offline
Old 11-06-2011, 10:42 PM   #6
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
ok. i got eagle rods full turbo kit. just need pistons and bearings
FF MODERATOR
RIFF CREW
Old 11-07-2011, 06:47 AM   #7
jjzx2sr
Fan#: 74691
I have a set of bearings, both main and rod, you need standard or oversized?
jjzx2sr is offline
Old 11-07-2011, 06:56 AM   #8
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,933, Level 87
Points: 18,933, Level: 87 Points: 18,933, Level: 87 Points: 18,933, Level: 87
Level Up 17% Completed
Forum Activity 11%
Buy-Sell-Trade Rating: (4)
If it was higher compression and that included shipping, I'd be all over this. Sadly though 10.5:1 isn't high enough for me ... But let me kick it around a bit and I might bite, I'll let ya know. No dibs or anything though.
And just because I am curious, how much was milled from the deck? (if it was something like 0.050" and it's now a zero deck block I might be able to swing something)
121,000 members and still no sponsored racing.
iminhell is offline
Old 11-08-2011, 12:47 PM   #9
jjzx2sr
Fan#: 74691
It had .015ths shaved from the block deck, i could dissassemble it and have it remilled if interested.. wouldnt take me but a day to have it done. Why not just mill the head instead to compensate for the compression.
jjzx2sr is offline
Old 11-08-2011, 02:33 PM   #10
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 11%
My head is already milled 0.045", and I have a spare virgin head too. But the milled head had the chambers opened up a bit, cc's went from 44 stock to 46cc's after milling.
So I'm trying to figure out what static would be ... and it looks like I'd be in the 12's somewhere, which might work out.
Just waiting on JE to email me the specs of the pistons.
I get paid Friday and I'll let you know where I stand.
Is the price shipped, or is shipping extra?
iminhell is offline
