Old 11-04-2011, 08:04 PM   #1
Fumey
Fan#: 89510
What I Drive: 2012 se hatchback
FF Reputation: 1 Fumey Good Standing Member
2012 oil change message
Whats the longest some of you have gone before your change oil message has come on? The owners manual says it may be as long as 10k , depending on driving habits . I'm over that amount , mostly hiway miles , no notice yet , but I'm going to change oil anyway as this amount of time between oil changes makes me nervous . Dipstick says okay , just worried some oil viscosity sensor thingy may be malfunctioning....
Fumey is offline
Fan#: 1
Old 11-04-2011, 08:52 PM   #2
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
FF Reputation: 15 mikeeshaq Great Standing Member
I bought a TC [see left panel] new. Oil change interval is 7500 miles [you got to be kidding!]
A Ford mechanic once said to me, if you want that engine to last, change oil at 3000 miles. I need the TC to last to 500,000 miles!
At one point in the literature Ford says the TC can last up to 150,000 miles [at 7500 mile oil change] What do you think the engine is good for if the oil change is at 3000 miles?
Now if one gets a car and will dump it at 100,000 miles, alright go with recommended oil change interval
mikeeshaq is offline
Old 11-04-2011, 09:00 PM   #3
05focusST91
05focusST91's Avatar
Fan#: 83640
What I Drive: 2005 ST
FF Reputation: 4 05focusST91 Good Standing Member
yeah but 10k is the cut off, if you saw what your oil looked like when its draining after 10k its not pretty, even in a new car on full syntec i wouldnt go over 5k, my st is almost at 80k now and i change it every 4000 since i do alot of stop and go
D23 crew #27, the look on their face when they see foci taillights
05focusST91 is offline
Old 11-04-2011, 09:58 PM   #4
sailor
"Elder"
sailor's Avatar
Fan#: 57268
What I Drive: 2004 Pitch Black ZTS
FF Reputation: 48 sailor Great Standing Member
Oil is changed a LOT more than needed, EXCEPT for those who NEVER bother to even check the level....
As long as there is oil in the engine, it probably WON'T break because of an oil issue...
On the other hand, I got into the habit of fall & spring changes, just so it doesn't get forgotten - and a little extra TLC keeps the vehicles running indefinitely....
Luck!
sailor is offline
Old 11-04-2011, 10:37 PM   #5
sailor
"Elder"
sailor's Avatar
Fan#: 57268
Luck!
sailor is offline
Old 11-04-2011, 10:53 PM   #6
Chewie12
Chewie12's Avatar
Fan#: 88284
What I Drive: 2012 Hatch
FF Reputation: 4 Chewie12 Good Standing Member
Depends what kind of oil your running I just switched to synthetic in my 12 so well see when I get to the 10+ marker.
Chewie12 is offline
Old 11-05-2011, 08:20 AM   #7
csvt2060
csvt2060's Avatar
Fan#: 84122
What I Drive: 2013 Ford Escape Titanium
FF Reputation: 2 csvt2060 Good Standing Member
We are coming to the conclusion the oil change monitor doesn't work on the 2012 Focus. There are multiple people over 10K miles with no warning, which is the max interval. I have 9400 miles with no warning. Problem is that the interval is so long and according to Ford it's varaible with miles, time elapsed, and use it's hard to diagnose why it's not working.
csvt2060 is offline
Old 11-05-2011, 07:22 PM   #8
don627
Fan#: 56863
What I Drive: 2007 infra-red zx3
FF Reputation: 1 don627 Good Standing Member
There is no sensor its just an algorithm in the computer that tries to guess when the oil should be changed depending on ambient temps, engine temp, speed and other things like that. GM has used a similar system since the 1970's with no increase in oil related engine failures. However lately they have had timing chain issue with certain model year vehicles (chevy traverse is one) due to the computer letting the cars go too long before triggering a oil change light. They were issued a TSB to recalibrate the computer to disalllow this.
don627 is offline
Old 11-07-2011, 12:28 AM   #9
Fumey
Fan#: 89510
Originally Posted by csvt2060 View Post
we are coming to the conclusion the oil change monitor doesn't work on the 2012 focus. There are multiple people over 10k miles with no warning, which is the max interval. I have 9400 miles with no warning. Problem is that the interval is so long and according to ford it's varaible with miles, time elapsed, and use it's hard to diagnose why it's not working.
arrrgh.
Fumey is offline
Old 11-07-2011, 05:47 AM   #10
05focusST91
Fan#: 83640
yeah in the fiesta/focus its pretty stupid plus people coming in think the wrench light is on -____- and leaving oil in for that many miles causes sludge build up, maybe not much but over time it will hurt the motor
