Braking at high speeds causes vibration. - Focus Fanatics
Old 10-10-2004, 06:53 PM   #1
Karifan
Karifan's Avatar
Fan#: 1383
What I Drive: '05 Sentra SE-R Spec V
FF Reputation: 1 Karifan Good Standing Member
I know this has probably been covered before, I have spent the past 2 hours searching with different keywords on this forum but can not find anything that covers this problem.
My problem is not vibration in general (although at high speeds I do have a slight vibration) this is more of a vibration and steering wheel shake when I brake at 70 + mph speeds.
I have replaced my brakes a while back ago completley bcs the rotors were damaged. I replaced brake pads and rotors back then about 10,000 miles ago.
the thing is at slower speeds I see no brake issues, so I been driving slow lately fearing that something might come flying away from under the car.
If the above makes any sense pls advise.
0-60 in under ..............
Karifan is offline
Old 10-10-2004, 06:57 PM   #2
sexy2002svt
Fan#: 3468
What I Drive: JDM Mugen Turtle
FF Reputation: 4 sexy2002svt Good Standing Member
it sounded like warped rotors at first, but since you already replaced those.............i don't know
HOLLER
TEAM STERLING!!!
sexy2002svt is offline
Old 10-10-2004, 07:00 PM   #3
Karifan
Karifan's Avatar
Fan#: 1383
what does wrapped rotors mean (a brief describtion if possible)? I have replaced them a while back, do u think they could rap after 10,000 or so miles?
Karifan is offline
Old 10-10-2004, 08:48 PM   #4
Arg
Fan#: 14043
What I Drive: 2004 yellow zx3 premium
FF Reputation: 1 Arg Good Standing Member
Warped Rotors are when your rotors overheat and change shape so the two surfaces arent even.
My rotors warped after 7000 miles(on my 2004 zx3), but that is because I stop too fast.
This could be a problem depending on how you drive. I know mine began shaking at high speeds only, but got worse and did at all times. Them being warped also destroyed my pads.
Hope this helps at all.
Arg is offline
Old 10-10-2004, 08:52 PM   #5
Kicknzx3
AKA Toyotech
Kicknzx3's Avatar
Fan#: 9
What I Drive: A few
FF Reputation: 1 Kicknzx3 Good Standing Member
Buy-Sell-Trade Rating: (4)
jack up your front end. grab the tire at 9 and 3 and move back and forth. then grab the tire and move it at 12 and 6 in the same fashion...check for movement.
but it could be ur rotors again depending on ur driving style
2012 Toyota Camry SE
2012 Chevy Cruze LT/RS
2006 Ford Escape XLE V6
1991 Ford Mustang LX/5.0
Kicknzx3 is offline
Old 10-10-2004, 08:53 PM   #6
Karifan
Karifan's Avatar
Fan#: 1383
to be honest, ever since I got into modding I drive like am racing daily, the car just invites your to push it to the limits.
Would u suggest I upgrade all my brakes, like bigger disks upfront and replace the drum brakes in the back with disks too?
I know I would need new wheels and tires first to be able to go with bigger brakes, but I need to be able to stop as quick as I start.
My current mods are:
Suspension KYB GR2 shocks/struts
K&N FIPK II
FC 65 mm ported TB
Borla Catback exhaust.
Pirelli P6 all season tires.
What kind of green do I expect to spend on a all wheel/Tire/Brake upgrade?
1 G or about 2 Gs?
Karifan is offline
Old 10-10-2004, 08:56 PM   #7
Kicknzx3
AKA Toyotech
Kicknzx3's Avatar
Fan#: 9
What I Drive: A few
the bigger brakes r for show pretty much...not impressive when tested.
i have the brembo/hawk pad combo and love it... start driving normally, not like theres too much of a benefit
Kicknzx3 is offline
Old 10-11-2004, 12:10 AM   #8
Kzar
Fan#: 11782
What I Drive: 2000 Ford Focus SE
FF Reputation: 1 Kzar Good Standing Member
Maybe it is the wheel lug studs?
I ruined my credit so that I wouldn't be a victim of identity theft.
Kzar is offline
Old 10-11-2004, 12:41 AM   #9
DidHeFocus?
Fan#: 1704
What I Drive: 2003.5 ZTW PZEV
FF Reputation: 1 DidHeFocus? Good Standing Member
Heat alone shouldn't warp the rotors, unevenly torqued wheel bolts and heat will more likely be the cause.
Out-of-round tires have been a common cause of vibrations in my experience.
I'm a middle aged guy, with a middle school mind.
DidHeFocus? is offline
Old 10-11-2004, 09:53 AM   #10
sexy2002svt
Fan#: 3468
Originally posted by Karifan
[/B]
1 G or about 2 Gs? [/B]
it all depends on what quality parts you want. If you want good stuff, yeah, the wheels themself can cost you a G. What kind of Brake upgrade do you want? A big brake kit? or just pads/rotors/lines? It all depends
HOLLER
TEAM STERLING!!!
Similar Threads
02 Focus SE keeps Blowing heater/AC Fan Fuse on High reb162 General Technical Chat 10 10-11-2013 01:57 PM
Brake Vibration at High Speed Garystrick Brakes, Suspension & Chassis 17 06-05-2010 01:33 AM
Could use some help please? Iceberg General Technical Chat 13 06-30-2009 09:26 PM
Focus Light Bulb Guide (MOD STICKY THIS) TKE_Quailman MK2 Focus 13 11-09-2008 04:36 PM
VF Motor Mounts and Vibration Jholewin General Technical Chat 10 03-13-2008 11:23 PM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
