TC and ABS lights after brake job - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-03-2011, 08:41 AM   #1
Laminar
Laminar's Avatar
Fan#: 81298
What I Drive: 2013 SE
Points 452, Level 9
Points: 452, Level: 9 Points: 452, Level: 9 Points: 452, Level: 9
Level Up 4% Completed
Forum Activity 5%
FF Reputation: 2 Laminar Good Standing Member
I replaced the front pads and rotors on my wife's '07 ZX4 SES. About a week later, the traction control and abs lights came on, and of course she has no TC or ABS now.
Some general searching has told me to use a DMM set to AC volts to test the sensor output. Once she's home from work I'll do that. I've also read to check the air gap under the sensor. Does anyone have a picture of where exactly that's done? I have plenty of feeler gauges, but a quick glance at the knuckle didn't make it obvious to me exactly where I can access the bottom of the sensor.
I have a new sensor ready to go if one actually is bad, but I need to get this fixed by this weekend because I'm leaving the country and winter is coming fast.
Thoughts?
Laminar is offline
Old 11-03-2011, 09:25 AM   #2
GodLovesUgly
.Flat Out.
GodLovesUgly's Avatar
Fan#: 56705
What I Drive: ^^^ That!
Points 28,333, Level 98
Points: 28,333, Level: 98 Points: 28,333, Level: 98 Points: 28,333, Level: 98
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 10 GodLovesUgly Great Standing Member
Buy-Sell-Trade Rating: (7)
if the sensor is anything like 00-04 models it will have one bolt right above the knuckle, just unbolt that and lift up on the wire. after i changed my knuckle my TC and ABS turned off as well, so i unbolted the sensor and blew some air in the hole, re-installed the sensor and the issue was fixed.
The Rich Get Richer Until The Poor Get Educated.
Do Vegetarians eat Animal Crackers?
Moderator of Ford Focus Racing Discussions & Rocky Mountain Fanatics
GodLovesUgly is offline
Old 11-03-2011, 10:50 AM   #3
Laminar
Laminar's Avatar
Fan#: 81298
Points 452, Level 9
Forum Activity 5%
I already pulled both sensors, cleaned their mounting points and surfaces, and reinstalled, it didn't fix the issue.
Laminar is offline
Old 11-04-2011, 06:38 PM   #4
Laminar
Laminar's Avatar
Fan#: 81298
Points 452, Level 9
Forum Activity 5%
I pulled each sensor plug and hooked up my multimeter to the sensor's prongs. When set to AC volts, there was a definite change in reading as we manually spun the tire, so the sensors are sending out some kind of signal.
Can someone confirm that I'll have to pull the brake rotors off to measure the sensor air gap? I have 24 hours to fix this issue before I'm out of the country, and I'd rather not have to have her take it to the dealership.
Laminar is offline
Old 11-04-2011, 07:46 PM   #5
focusZX505
FOCUS REVOLUTION
focusZX505's Avatar
Fan#: 19251
What I Drive: 08 Black Coupe 14 fiesta ST
Points 6,234, Level 51
Points: 6,234, Level: 51 Points: 6,234, Level: 51 Points: 6,234, Level: 51
Level Up 43% Completed
FF Reputation: 4 focusZX505 Good Standing Member
IIRC you can't really check the air gap on these sensors. it's built into the wheels bearsing and spindle. also it should be sending out a signal
FOCUS REVOLUTION
FSWERKS
MASSIVE SPEED SYSTEMS
SCSCC #320
focusZX505 is offline
Old 11-04-2011, 09:09 PM   #6
Laminar
Laminar's Avatar
Fan#: 81298
Points 452, Level 9
Forum Activity 5%
What do you mean by "it should be sending out a signal"? I confirmed that the AC voltage reading of both front wheel speed sensors changed with tire speed. What else can I do?
Laminar is offline
Old 11-05-2011, 08:35 PM   #7
focusZX505
FOCUS REVOLUTION
focusZX505's Avatar
Fan#: 19251
It should be sending a signal to the elm to know what each wheel speed is that's how abs and tv work if it reads fronts are alot fast then rear it apples the brakes to allow better traction did you check the rear sensors
Posted via FF Mobile
Old 11-05-2011, 08:50 PM   #8
don627
Fan#: 56863
What I Drive: 2014 Focus Hatchback
Points 208, Level 4
Points: 208, Level: 4 Points: 208, Level: 4 Points: 208, Level: 4
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 2%
FF Reputation: 1 don627 Good Standing Member
The issue may not have anything to do with the brake job. Need to find out what the codes are in the ABS module to really diagnose anything. Could be as simple as a broken wire in the wheel sensor wiring harness, if the sensors are working you need to verify that the signal is coming out the other end of the wire.
don627 is offline
Old 12-22-2011, 05:28 PM   #9
Laminar
Laminar's Avatar
Fan#: 81298
Points 452, Level 9
Forum Activity 5%
Turns out the brake job was a red herring. I took it into the dealer today and they pulled the code for me - RR wheel speed problem. They took off the wheel and drum and found the tone ring was damaged. I paid for the diagnosis ($89) and the tone ring only ($46), they didn't charge me any labor or time. Very pleased to have this working again, just in time for snowy weather.
Laminar is offline
Old 12-22-2011, 08:28 PM   #10
suby6
suby6's Avatar
Fan#: 57613
What I Drive: 2003 ZX5
FF Reputation: 1 suby6 Good Standing Member
Odd, not sure how the tone ring would get damaged with a front brake job lol.
Also when I did my rears I bent the rings a bit and banged them back as straight as possible but still visibly not perfect and I don't have any codes....
Atleast it's fixed for yoou now anyway.
Wish it is as fast as it sounds...
suby6 is offline
