How to lookup the built date of your Ford Focus? - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-12-2012, 08:16 PM   #31
wgilles
wgilles's Avatar
Fan#: 91264
What I Drive: 2012 Tuxedo Black SE 5 speed
Points 1,386, Level 20
Points: 1,386, Level: 20 Points: 1,386, Level: 20 Points: 1,386, Level: 20
Level Up 86% Completed
FF Reputation: 1 wgilles Good Standing Member
First Focus ever built...heck, first THING ever built!
Haha, this is probably because I just got my VIN today, there is probably no info to show except that it is a Focus and being built in Michigan.
wgilles is offline
Old 01-13-2012, 08:25 AM   #32
Hawktwoe
Hawktwoe's Avatar
Fan#: 91129
What I Drive: 2012 Focus SE Sedan 5spd SGM
FF Reputation: 1 Hawktwoe Good Standing Member
Primary Features
Build Date: 10.11.2011
Vehicle Line: Focus (C346N)
Body Style: 4 Door Saloon
Series: SE
Engine: 2.0L Duratec DI TIVCT (160PS)
Transmission: 5-Speed Manual Trans - MTX75
Drive: LHD FWD
Axle Ratio: 3.82
Emission: 50 State Emission Requirements
Air Conditioning: Manual Air Conditioning
Paint: Sterling Grey Metallic
Ha, my car is a 4 door saloon!
It also says with Kysor radiator shutters. What are these?
12 Focus SE sedan Sport pkg, 203a, 5-spd
09 Edge SEL
02 F-150 FX-4 Lariat
63 Galaxie 500XL fastback
94 FXSTC
Hawktwoe is offline
Old 01-13-2012, 08:51 AM   #33
GhiaFan
GhiaFan's Avatar
Fan#: 50498
What I Drive: 2007 Panther Black Focus 1.6 Ti-VCT
Points 15,238, Level 79
Points: 15,238, Level: 79 Points: 15,238, Level: 79 Points: 15,238, Level: 79
Level Up 78% Completed
Forum Activity 6%
FF Reputation: 13 GhiaFan Great Standing Member
Kysor radiator shutters is Fords innovative feature ... active grille shutters
If air is required to cool the engine, the vents are opened. If no airflow is needed the vents are shut, contributing to significantly reduced aerodynamic drag.
Mounted in the grille aperture ahead of the radiator, the active grille shutters feature motorized horizontal vanes that can rotate through 90 degrees to block the airflow. Automatically controlled by the car’s electronic control unit, the vanes can be rotated into 15 different positions – from fully closed to fully open – depending on the amount of cooling air required.
When fully closed, the reduction in drag means the active grille shutters can reduce CO2 emissions by 2 percent.
As an additional benefit, the system keeps the vanes closed as long as possible when starting from cold, so the engine reaches its most efficient operating temperature more quickly. This also helps reduce fuel consumption.
YouTube Video
GhiaFan is online now
Old 01-13-2012, 11:44 AM   #34
Hawktwoe
Hawktwoe's Avatar
Fan#: 91129
Thanks GhiaFan. I thought these were only on the SFE package. Apparently I was mistaken.
09 Edge SEL
94 FXSTC
Hawktwoe is offline
Old 01-13-2012, 12:32 PM   #35
unclebrud
Fan#: 85754
What I Drive: 2012 Ford Focus S (Ingot Silver)
FF Reputation: 1 unclebrud Good Standing Member
12.04.2011 (April 12th) ... so far, quality has been pretty good for the first 11k (knock-on-wood, then do a rain dance).
unclebrud is offline
Old 02-10-2012, 05:58 PM   #36
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: '14 Ruby Ti w/ Handling Pkg
Points 7,615, Level 58
Points: 7,615, Level: 58 Points: 7,615, Level: 58 Points: 7,615, Level: 58
Level Up 33% Completed
Forum Activity 3%
FF Reputation: 13 kam327 Great Standing Member
I read elsewhere that the build date is on the bottom of the window sticker. My window sticker says 11 23 11 (Nov 23rd) which matches the dealer's invoice which I needed for my financing. But on www.etis.ford.com it says 02.12.11 (Dec 2nd). The sticker on my door frame says 12/11 (Dec). So which is right?
Not that it really matters, must mildly curious.
kam327 is offline
Old 02-10-2012, 06:21 PM   #37
Rogerschro
Rogerschro's Avatar
Fan#: 90661
What I Drive: '12 FFE Frosted Glass
Points 910, Level 16
Points: 910, Level: 16 Points: 910, Level: 16 Points: 910, Level: 16
Level Up 10% Completed
Forum Activity 2%
FF Reputation: 3 Rogerschro Good Standing Member
My guess is the 11/23 date is when the car was put into the Que. 2/12 would be the actual build date. Just a guess.
Rogerschro is offline
Old 02-10-2012, 06:31 PM   #38
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Forum Activity 3%
Makes sense. Thanks.
kam327 is offline
Old 02-10-2012, 11:37 PM   #39
ladytonya
Fan#: 94805
What I Drive: '12 Sterling Gray Metallic SE hatch
FF Reputation: 1 ladytonya Good Standing Member
My build date is Jan. 11, 2012! I took delivery on Jan. 27, I just think that is so cool, my car rolled off the assembly line 16 days before I picked it up!
ladytonya is offline
Old 05-16-2012, 02:35 AM   #40
vela123321
Fan#: 98759
What I Drive: 1987 VW Vanagon
FF Reputation: 1 vela123321 Good Standing Member
That site wasn't working for me... I found this link http://researchmaniacs.com/Ford/Trac...CarOrders.html that had the info on the window sticker, which I could download from the VIN. If the car were parked out front I could just check the door jam... tomorrow...
vela123321 is offline
