poly control arm bushings/ball joint - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-29-2011, 07:01 PM   #1
DanUSVT
Fan#: 80691
What I Drive: 2003, Red, SVT 3dr
Points 473, Level 9
Points: 473, Level: 9 Points: 473, Level: 9 Points: 473, Level: 9
Level Up 46% Completed
FF Reputation: 1 DanUSVT Good Standing Member
Does anyone have experience with installing poly front control arm bushings?
Also, i noticed the balljoints are riveted to the control arm, although, apparently, replacements are available. I guess you have to drill out the rivets, then bolt the new ones in? Might not be a bad job, but would be easier wih a drillpress, which I don't have.
It seems like the way to go would be to try and reuse the old arms with new bushings and ball joints, if replacing ball joints is really practical. Seems like removing bushings from a new arm would be harder than pulling worn ones out of a new part.
Any advice appreciated.
DanUSVT is offline
Old 10-29-2011, 08:15 PM   #2
drjkel
Fan#: 34025
What I Drive: 2001 Amazon Green ZTS, 2012 SE Seda
FF Reputation: 9 drjkel Good Standing Member
I just tried doing a lower ball-joint only replacement. I used center punches to pick up the centers of the tops of the rivets and cobalt-steel drill bits to do the drilling. I had done this job easily many times before on Contours/Mystiques. I took my time and gradually increased the drill bit size while drilling out the rivets. The Focus rivets appeared to be much harder than the Contour/Mystique rivets. In the end, I distorted the control arm in trying to drive the rivet remains out and had to purchase an entire new control arm with bushings and ball joint. If I have to do the other side, I'm going straight to replacing the entire control-arm.
Others have had a better experience. Whatever you decide to do, Good Luck.
2001 Amazon Green ZTS 100,000mis
2012 Sterling Grey SE Sedan M/T!
drjkel is offline
Old 10-29-2011, 09:22 PM   #3
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
What I Drive: '03 SVT EAP "Eurotrish"
Points 2,073, Level 27
Points: 2,073, Level: 27 Points: 2,073, Level: 27 Points: 2,073, Level: 27
Level Up 49% Completed
Forum Activity 9%
FF Reputation: 22 Sniper Focus Great Standing Member
Buy-Sell-Trade Rating: (13)
I'm about replace the ball-joints soon, I'm gonna try grinding the rivets down and knocking them out with a punch, that's how most people seem to do it. The drill method scares me a little because it can be off and elongate the hole.
Fox Hound: Liquid Stang - Sniper Focus - Decoy Escort (or was it a Tracer...)
Sniper Focus is online now
Old 10-29-2011, 10:01 PM   #4
dirtbrown
what it be like
dirtbrown's Avatar
Fan#: 40563
What I Drive: 03 EAP
Points 41,796, Level 100
Points: 41,796, Level: 100 Points: 41,796, Level: 100 Points: 41,796, Level: 100
Level Up 0% Completed
Forum Activity 8%
FF Reputation: 27 dirtbrown Great Standing Member
try and find a used set at a junkyard and then find someone to press the old ones out that way you have no downtime....some people torch em but you dont have to on the fronts..I did mine at home with a little home made press the result was a very rough ride but a very beefy looking control arm! LOL
heres a thread with some more info
http://www.focusfanatics.com/forum/showthread.php?p=2651032#post2651032
dirtbrown is offline
Old 10-29-2011, 11:56 PM   #5
msperber
Fan#: 80053
What I Drive: 05 ST Focus 2014 SE Champion
Points 296, Level 5
Points: 296, Level: 5 Points: 296, Level: 5 Points: 296, Level: 5
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 3 msperber Good Standing Member
I did this job with an air chisel then to the drill and then the punch. Car was on a lift, it's doable but loud and hard. I needed replaceable ball joint cause the car is a track dedicated piece. If u don't have to just replace as a unit.
msperber is online now
Old 10-30-2011, 06:26 PM   #6
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
Points 4,174, Level 41
Points: 4,174, Level: 41 Points: 4,174, Level: 41 Points: 4,174, Level: 41
Level Up 12% Completed
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
I've done the LCA polly bushing and just bought new LCA's with new ball joints already installed. For the time you'd spend grinding,drilling, air hammering out the rivets for the ball joints, unless you have access to lift and shop air, isn't worth it to me. Especially after the time to burn out and clean up old bushings.
I didn't have access to a shop torch and used a MAP tank with pencil tip from hardware store to burn out rear bushing. With my new LCA's the front bushing came out with my hands. I used a sawzall to cut out inner sleeve. Pressed them in with a table mounted clamp.
Yeah, buy new LCA's. Besides makes the job sooo much easier to have the new LCA's assembled before taking out the old ones.
I now drive a Japanese Ford.
macdiesel is offline
Old 10-31-2011, 10:26 AM   #7
apagios
apagios's Avatar
Fan#: 40891
What I Drive: '03 ZX5 SVT, '05 Mazdaspeed Miata
Points 873, Level 15
Points: 873, Level: 15 Points: 873, Level: 15 Points: 873, Level: 15
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
FF Reputation: 3 apagios Good Standing Member
You can buy an entirely new LCA with new ball joint and bushing for ~$45. $45 for the new arm or ~$20 for a ball joint plus lots of work drilling rivets. I just bought new arms.
I will caution that I got the Mevotech brand from Rock Auto, and the rear bigger bushing had a thin steal collar inside the bracket that bolts to the sub frame (it was the outer shell of the rubber bushing that came installed on the LCA). The Prothane bushing would not fit till that pressed out. I did the entire prothane kit and pressed all the bushings myself with a cheap 6 ton harbor freight benchtop press. Except for those Mevotech brackets. Those too a machinist friend turning a couple custom pieces to fit in and using a 10 ton press. The other option was to dremel a slot through the sleeve/collar and pry it out without marring up the bracket too much.
The sleeves that were pressed out of the bracket to let the Prothane bushing fit in are pictured below:
If you have any questions feel free to PM me for an email convo.
EDIT: Ok after going back and looking at my pics, the stock LCA had the same collars, it's just the steel outer shell to the bushing. Because it's such a large diameter with such a thin wall thickness, its a b*tch to press out. Unless you have machine shop access, I'd recommend the dremel method to carefully slit the collar and be able to just carefully pry it out without mucking up the LCA bracket to the subframe. This issue never came up on the big large diameter bushing on the rear suspension trailing arm, because for that one the rubber bushing is simply bonded to the trailing arm, so when you burn/clean out the rubber the Prothane bushing slides right in (after some cussing and getting bushing grease all over you hands obviously )
apagios is offline
Old 10-31-2011, 10:32 AM   #8
apagios
apagios's Avatar
Fan#: 40891
Or you could just buy new LCA's and simply swap in the front poly bushing and leave the big back bushing as rubber, thats the least amount of work. Though I decided I had the poly bushings, and I wanted to spend the time on that rear bushing to complete my full set.
apagios is offline
Old 10-31-2011, 11:24 AM   #9
macdiesel
macdiesel's Avatar
Fan#: 31579
It actually didn't take too long to cut and pry out. I've done just the front bushings and after doing the fronts and rear it feels a lot tighter.
Old 10-31-2011, 12:58 PM   #10
macdiesel
macdiesel's Avatar
Fan#: 31579
Apagios and dirt brown, your pictures makes me wish I bought the red bushings.
