Auto Dimming Option - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-28-2011, 05:53 PM   #1
cathyvictor
Fan#: 89675
What I Drive: 2012 Candy Apple Red Focus SEL Sed
FF Reputation: 1 cathyvictor Good Standing Member
Auto Dimming Option
On the driver control screen under lights, there is an option for dimming which is either manual or automatic. I have scoured the owner's manual and for the life of me cannot see what this is supposed to dim and what the difference is. Mine was originally in automatic and I have left it that way. This is different that the options for delaying the headlights/lamps which I found and which works. Any ideas?
Thanks
cathyvictor is offline
Old 10-28-2011, 06:01 PM   #2
descentgate
descentgate's Avatar
Fan#: 86793
What I Drive: 2012 Candy Blue Tinted Metallic SEL
FF Reputation: 1 descentgate Good Standing Member
Thanks
This is kinda a weird option. The "dimming" refers to your dashboard lights. Depending on your config, you'll either have a +/- to the right of your headlamp switch, or a set of +/- buttons surrounding your headlamp switch. These buttons won't work to set your dashboard dimming if "automatic" is selected. If you select manual, these +/- toggles are activated, so you can select the proper amount of dimming on your own.
Proud 2x Focus Owner!
- 2002 Ford Focus ZTS (CD Silver Metallic)
- 2012 Ford Focus SEL (Blue Candy Tinted Metallic)
descentgate is offline
Old 10-28-2011, 06:13 PM   #3
cathyvictor
Fan#: 89675
I will try again when it gets dark tonight. I believe however that the two buttons (I have a red candy SEL sedan Canadian version with DRL's) did dim the instrument panel lights when the automatic option was selected, however I am not positive. Will try to verify tonight.
Thanks
Old 10-28-2011, 07:10 PM   #4
Bradm
Fan#: 90623
What I Drive: 2012 Frosted Glass 5 door SEL
FF Reputation: 1 Bradm Good Standing Member
On my SEL the auto setting leaves the dash lights alone but the buttons then control the MFT screen brightness. Off auto it effects both.
Bradm is offline
Old 10-28-2011, 11:09 PM   #5
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,802, Level 78
Points: 14,802, Level: 78 Points: 14,802, Level: 78 Points: 14,802, Level: 78
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 19%
FF Reputation: 16 Elizabeth Great Standing Member
The op's automatic/manual menu choices controls the dimming of the screens.
Say it is raining and you turn on the headlights, well if the setting is manual, the screens will dim to nightime levels.
The setting HAS to be 'automatic' for the screens to stay at full brightness during the day, IF you turn on the headlights during the day (for any reason)
On automatic, the autosensor is used and it knows it is daytime even though the lights are on.
I was stuck with the screens dimming with it raining and I turned on the headlights.. and was like WTF a few times. i figured it had to be some menu thing so i went in and found it.
(I am pretty sure i had turned it to manual myself at some earlier point fooling around)
Elizabeth is online now
Old 12-17-2012, 08:58 AM   #6
Flybigrc
Flybigrc's Avatar
Fan#: 103155
What I Drive: 2013 Ford Focus ST
FF Reputation: 1 Flybigrc Good Standing Member
could this auto dim feature cause the MFT to go blank
I was cleaning my 2013 Focus ST interior with the car off. Later that night I went to go the store and the MFT screen was blank but everything was working. I started pucshing buttons in frustration and turning the car on and off and evetually the screen came back on.
I am wondering if I somehow dimmed the screen when I was cleaning.
Any thoughts?
2013 Focus ST Performance Blue
2004 Corvette Coupe Magnetic Red
1968 Corvette Convertible Safari Yellow
Flybigrc is offline
Old 02-01-2013, 10:00 AM   #7
spinadog
Fan#: 108381
What I Drive: 2013 Focus ST3
FF Reputation: 1 spinadog Good Standing Member
THANK YOU! How can it be that explanation for options like this are not in the manual? Or available online? Frustrating.
spinadog is offline
Old 02-01-2013, 10:08 AM   #8
cobie56
Fan#: 84403
Are you referring to the manual/auto dim function for the MFT screen or the dash gauge lights , as well? I am able to select auto/manual dim for the MFT screen (which does not get dark enough at night on dark roads w/ no ambient light, imo) but must manually adjust the dash lights w/ the toggle switch next to the light switch.(again, imo, not dark enuf on dark roads) thnx
cobie56 is offline
Old 02-01-2013, 10:30 AM   #9
c5karl
Fan#: 105687
What I Drive: 2013 Hatchback SE, 5-speed, silver
Points 71, Level 1
Points: 71, Level: 1 Points: 71, Level: 1 Points: 71, Level: 1
Level Up 43% Completed
Forum Activity 2%
FF Reputation: 1 c5karl Good Standing Member
Same here. Thanks for finding and resurrecting this thread; I wasn't able to find it with a search and had been puzzled by this option for several months. How hard would it be to put a sentence in the owner's manual to explain which lights are being auto-dimmed?
c5karl is online now
