Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus > MK3 TSB, Recall & Problems Archive
Old 01-07-2013, 10:13 PM   #1771
PratoN
PratoN's Avatar
Fan#: 88058
What I Drive: 2012 Kona Blue Titanium Hatchback
FF Reputation: 6 PratoN Good Standing Member
Originally Posted by kam327 View Post
My clutch seals weren't leaking but the dealer said one of them wasn't disengaging properly which was causing the slipping while accelerating. I primarily complained about the slipping, but it was also shuddering from a stop. They replaced the clutches under TSB 11-12-13 despite the lack of leakage.
Was the clutch the only thing replaced? Or were there other components? Because if I don't have the oil leak, but it still made the noise that a manual makes when you shift without fully depressing the clutch, perhaps the clutch isn't the only thing wrong with my car?
2012 FF Ti HB Kona Blue, Built 5/24/2011, 401A + Ti Handling Package, Parking Technology Package, Winter Package, Moonroof, and MFT w/NAV at 3.5.1 53k miles and counting...
PratoN is offline
Old 01-08-2013, 07:42 AM   #1772
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: 2012 Red Candy Metallic SEL Sedan
FF Reputation: 9 kam327 Good Standing Member
It was all the typical parts associated with TSB 11-12-13 that others have posted here.
kam327 is offline
Old 01-08-2013, 07:48 AM   #1773
pozi240
Fan#: 94835
What I Drive: 2012 Focus 5 door SEL Kona Blue
FF Reputation: 4 pozi240 Good Standing Member
I don't know if this applies to Ford USA or if it will even help you out or not PratoN, but, when I was getting my 48K (km's) service on Friday, my service manager has stated that FoMoCo Canada has told them very recently that any DCT complaints on any Focus still under warranty to just "do the job under TSB 11-12-13 regardless of the presence of oil or not". So far, everyone is happy, the dealer and Focus owners... LOL.
2012 Focus SEL 5 door 303a w/Lux pkg in KonaBlue
2012 Escape Limited w/park assist
2010 F150 Supercrew XTR 5.4 4x4
2008 Kawasaki Concours 14 (street)
2008 Kawasaki ZX10R (track only)
pozi240 is offline
Old 01-08-2013, 08:19 AM   #1774
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
That may have been what happened to me. They replaced my clutches under 11-12-13 even though they said I had no leakage or shuddering (I had shuddering after the new clutches were installed but that's another story - 5 hard starts cured that). I thought 11-12-13 was specific to seal leaks and their symptoms - e.g. shuddering.
kam327 is offline
Old 01-08-2013, 08:26 AM   #1775
gostinger
Fan#: 44867
What I Drive: 2013 SE Black Pack Loaded 5 Spd MTX
FF Reputation: 1 gostinger Good Standing Member
I am curious though what is different in regards to the parts and installation that will make this problem disappear? Same parts will still eventually lead to the same result. As for being happy ... 2 replacements and I have indications of a third leaves me....... quite less than so called happy unless there is medication I should be taken that coincides with the tsb.
gostinger is offline
Old 01-08-2013, 09:13 AM   #1776
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Supposedly a redesigned seal to keep fluid off the clutch surfaces?
Also early builds should get updated with the rumored "long-rivet clutches" which I haven't seen any detail on.
kam327 is offline
Old 01-08-2013, 09:42 AM   #1777
PratoN
PratoN's Avatar
Fan#: 88058
Those are the only differences as far as I know. There seem to be less 2013s with bad clutches, though there is still an occasional complaint which kind of worries me.
PratoN is offline
Old 01-08-2013, 11:26 AM   #1778
mishka
mishka's Avatar
Fan#: 107408
What I Drive: Shadowfax: 13' black SE Sedan DCPS
FF Reputation: 1 mishka Good Standing Member
Hello all,
I have a 2013 DCT and that was buit in March 2012. I'm wondering if anyone has experienced any of the issues in this model.
I have put 1800 miles on it in the first three weeks (brand new car). A couple of times it has done a couple weird auto-shifts when I was in sport mode: once when I put it into sport mode it reved up to almost redline (instead of 5-6k RPM, at most, like it normally does. I was on a bit of an incline but it was still really weird. Also I have noticed that the gas pedal vibrates a bit more now than when it was brand new. Also, I drive fairly hard, but do what I can to drive normal/save gas.
Other than that (the weird shift, and the more vibrations) I haven't experienced any significant problems.
Does anyone think I should bring it into a dealership to get it checked out or am I probably okay? Should I try reseting my "shifting strategy", or whatever, that you all were talking about?
And (off-topic) when should my first oil change be?
Thanks.
"Shadowfax"
> Steeda CAI
mishka is offline
Old 01-08-2013, 11:44 AM   #1779
suss6052
Sonic MK3 Crew #06
suss6052's Avatar
Fan#: 95752
FF Reputation: 12 suss6052 Great Standing Member
Originally Posted by mishka View Post
Hello all,
Thanks.
It can't be a March 2012 build and be a 2013 MY, 2013 MY builds didn't start until on or after 7/23/12.
If you floor the accelerator it will repeatedly wind out to 6500 rpm or so, although that's less economical than shifting sooner than this.
Its probably ok, the four cylinder engine does shake a touch and it can be felt through the firewall and the pedal assemblies at times. Sometimes higher octane fuels can smooth it out a bit.
First oil change is up to you, you've already passed 1000 miles, some people do their first change before then, others wait until 5000, just change it before 10k miles or 1 year if you want to keep it within the owner's guide to maintain the warranty.
Moderator for: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, Great Lakes Fanatics
suss6052 is online now
Old 01-08-2013, 11:45 AM   #1780
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Thanks.
I don't have the shift issue but my engine does vibrate more at 10k then when new. I took it in and they were going to look at my engine mounts until they decided the vibration was due to the clutches. It wasn't. It vibrates around 1800-2000 rpm, right where I am during most of my commute.
The dealer probably won't do much ("it's normal") but take it in anyway. Can't hurt.
I'd change your factory fill of oil now. Looks like you had a good break in period and now's a good time to get all the metals outta there.
kam327 is offline
