DCT / PowerShift Transmission Update TSB Thread - Page 177 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-04-2013, 07:56 PM   #1761
bsp_53
bsp_53's Avatar
Fan#: 87580
What I Drive: 2012 FF Titanium HB, Yellow Blaze
Points 519, Level 10
Points: 519, Level: 10 Points: 519, Level: 10 Points: 519, Level: 10
Level Up 38% Completed
FF Reputation: 1 bsp_53 Good Standing Member
I got my car back this afternoon. They were not able to isolate what I thought was a driver's side upper strut mount issue, but that's OK. If it wasn't a rogue ice chunk, the problem should become more obvious and easier to diagnose over time.
The transmission work was done (new seals, clutch assembly, etc. TSB 11-12-13). As expected, it shifts like a dream. The dealer indicated that so far none of the seal / clutch assembly jobs they have done have come back with the same problem. I am hoping / expecting that the new seals are superior and will hold up. I was pleasantly suprised with improved gas mileage on the drive home. That trip with winter tires usually gets me 37.1 - 37.3 mpg. Coming home today I got 39.3!! Besides being a few degrees warmer (28F instead of 18F, the only difference is the clutches not being contaminated with gear oil. It is logical to expect better efficiency, I just didn't expect to see any kind of noticable improvement in the numbers. Only time will tell.
Gold Nugget: '12, 400A, Wintr Pckg, Yellow Blaze HB
Mods: Llumar Tint:35 / 20; K&N fltr + Snrkl Del.; Splashgrds; Grill Pinstripes
Hatch Nation #174
bsp_53 is offline
Old 01-07-2013, 12:27 PM   #1762
cuozc
Fan#: 107955
What I Drive: 2012 red Focus se
Points 13, Level 1
Points: 13, Level: 1 Points: 13, Level: 1 Points: 13, Level: 1
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
FF Reputation: 1 cuozc Good Standing Member
Congs!
I won't be able to get mine back till the 14th. The samo clutch replacement. Yet, the dealer said some special part on back order...
Glad to hear that no one has come back after the new seal and clutch; and the fact that yours is working perfectly for you!
cuozc is offline
Old 01-07-2013, 03:30 PM   #1763
Tonybaloney
Fan#: 87335
What I Drive: 2012 Candy Blue Metallic Hatch Sel
Points 149, Level 2
Points: 149, Level: 2 Points: 149, Level: 2 Points: 149, Level: 2
Level Up 98% Completed
FF Reputation: 1 Tonybaloney Good Standing Member
So after 5 days of driving mine after an apparent 2nd TSB update, its now WORSE. It now shudders while at highway speed. Before it was just 1st-3rd. Now if I let off the gas to coast a bit and then accelerate I feel the shudder again. And just looked up the info, and in MD after 18,000 miles or 2 years I cannot file for the Lemon Law on a new car. I'm at 27,000. I'm so done with this car. I JUST WANT A SMOOTH DRIVING EXPERIENCE! IS THAT SO MUCH TO ASK FOR FORD?!?!?!?!?!
Build date 02/17/2011
Tonybaloney is offline
Old 01-07-2013, 03:53 PM   #1764
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,002, Level 33
Points: 3,002, Level: 33 Points: 3,002, Level: 33 Points: 3,002, Level: 33
Level Up 68% Completed
Forum Activity 8%
At least your dealerships replaced your clutch (right?) or did they just replace the seals? If it's the latter, that's probably your problem. I still have shuddering (same as you - releasing the gas and pressing it again causes shuddering). I don't think you're out of luck, though. Check the BBB to see if they can do repairs. I also don't qualify for the lemon law (over 40k miles), but I'll be contacting the BBB in the summer when it starts acting up again to see if I can force Ford to do the repairs without a full lemon buy-back.
PratoN is online now
Old 01-07-2013, 03:56 PM   #1765
Tonybaloney
Fan#: 87335
Points 149, Level 2
They said the transmission was bone dry, no leaks. What do I have to do to make it leak? Seriously, how can I sabotage my car so it gets fixed PROPERLY!!!
Old 01-07-2013, 04:01 PM   #1766
PratoN
PratoN's Avatar
Fan#: 88058
Forum Activity 8%
Weird... although, my car shudders and they also said it was dry. I think they're lying, but they've also never completely opened it up and replaced seals like on your vehicle. They tried to look at it through the starter opening or something?
I think there's a chance we have bad clutches (glazed/broken/etc.) without the oil contamination as well. But Ford seems to be ignoring that possibility, so if there is no oil, they won't replace the clutch.
Old 01-07-2013, 05:59 PM   #1767
Strix
Fan#: 85696
What I Drive: Not a Ford
Points 539, Level 10
Points: 539, Level: 10 Points: 539, Level: 10 Points: 539, Level: 10
Level Up 78% Completed
FF Reputation: 0 Strix Poor Behavior Needs Improvement
Apparently, it is. My Focus vibrates and shudders more than any car I've ever owned. And I've owned some real junkers in my day.
Funny thing is, it didn't vibrate and shudder until after a Ford dealership worked on it.
But Ford doesn't care... they 'fixed it', so they now feel entitled to dismiss my concerns and label me a crank.
A couple words of advice to anyone considering contacting Ford 'customer service' on this forum: don't bother. Worse than a waste of time for me... it's been an insulting and frustrating waste of time. They are more interested in keeping dealerships from making 'unnecessary' warranty repairs than in making customers happy.
Strix is offline
Old 01-07-2013, 06:48 PM   #1768
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: '14 Ruby Ti w/ Handling Pkg
Points 7,206, Level 56
Points: 7,206, Level: 56 Points: 7,206, Level: 56 Points: 7,206, Level: 56
Level Up 28% Completed
Forum Activity 12%
FF Reputation: 13 kam327 Great Standing Member
My clutch seals weren't leaking but the dealer said one of them wasn't disengaging properly which was causing the slipping while accelerating. I primarily complained about the slipping, but it was also shuddering from a stop. They replaced the clutches under TSB 11-12-13 despite the lack of leakage.
kam327 is offline
Old 01-07-2013, 09:21 PM   #1769
BigFuzzyArchon
Fan#: 87167
What I Drive: 2012 SE Hatch Sport Package
FF Reputation: 1 BigFuzzyArchon Good Standing Member
I had all the funky transmission problems with my car. I started driving it harder and flooring it a bunch. Seemed to have smoothed everything out, no more noise either while shifting. I'm just over 22k miles.
BigFuzzyArchon is offline
Old 01-07-2013, 09:37 PM   #1770
gostinger
Fan#: 44867
What I Drive: 2013 SE Black Pack Loaded 5 Spd MTX
FF Reputation: 1 gostinger Good Standing Member
Originally Posted by cuozc View Post
Congs!
2 repairs and there will be a third....False hope. Same parts = same problem will occur until a fix is found.
gostinger is offline
