Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus > MK3 TSB, Recall & Problems Archive
Old 01-03-2013, 02:17 PM   #1741
Kabigon
Fan#: 88299
FF Reputation: 5 Kabigon Good Standing Member
Originally Posted by cuozc View Post
Could you please provide more detail about the "ole's 5 hard accelerations". I read from one of the previous posts a list of "adaptive driving cycle"... (13 steps of strange things to do, which will take 20-40 mins). Shall I do that? My se is getting the clutch replaced now. Thanks!
It's not necessary for you to do the adaptive driving cycle steps for the TCM to "learn".
The number 5 (as in 5 hard accelerations) is arbitrary and has no real meaning.
The best thing is to do a lot of mixed driving with (at least) an occasional hard acceleration.
Kabigon is offline
Old 01-03-2013, 02:51 PM   #1742
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: 2012 Red Candy Metallic SEL Sedan
FF Reputation: 9 kam327 Good Standing Member
Yes the 5 is arbitary, but this has worked twice for me and virtually solved the shuddering problem immediately both times. So I wouldn't brush it off so..... arbitrarily.
kam327 is offline
Old 01-03-2013, 03:14 PM   #1743
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
FF Reputation: 6 dan50 Good Standing Member
Thank you! I will give it a try if that happens.
The adaptive drive cycle is difficult to do given where most of us live: too many stop signs, stop lights, too far from an open highway, etc. so it's doubtful dealers even try. Probably best to just drive the car in a varied way for a few hundred miles. If shuddering develops, then you may want to try the series of hard acceleration runs.
If you really want to do the adaptive drive cycle, get way out in the country, disconnect the battery (negative gound is outside the battery compartment) for a few minutes and go for it.
dan50 is offline
Old 01-03-2013, 03:59 PM   #1744
cuozc
Fan#: 107955
What I Drive: 2012 red Focus se
FF Reputation: 1 cuozc Good Standing Member
Thank you guys! I do agree that it's not easy to do the adaptive cycle in my area. So, two options:
1. Drive as I normally do for ~200 miles or till it starts to act abnormal (e.g. shuddering). Then I will give it a few hard accelerations. (I prefer, as it will give the new clutch a little time to fit in.)
or 2. When I get it from the dealer, give it a few hard accelerations, e.g. arbitrarily 5 times. :)
What you guys think?
cuozc is offline
Old 01-03-2013, 04:29 PM   #1745
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Yep, no need to try to fix what ain't broken. Only if shuddering or another malady develops try the hard accels or other suggestions.
kam327 is offline
Old 01-03-2013, 04:32 PM   #1746
Kabigon
Fan#: 88299
My main point was that varying amounts of acceleration (including full accel) on a regular basis works best (rather than accelerating hard only after the shuddering starts).
I haven't experienced shuddering since the car was new (in June 2011).
I do believe that more people would be happy with their DCT if they put their foot to the floor on a regular basis.
Kabigon is offline
Old 01-03-2013, 04:35 PM   #1747
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
My main point was that varying the acceleration (including full accel and everywhere in between) on a regular basis works best (rather than accelerating hard only after the shuddering starts).
What is your definition of "best"? And what are you basing that on? I just said that doing the full throttle accels worked perfect for me. Twice. And I didn't do anything else. I assume it also worked for those that recommended it to me last Spring. So it's pretty much a proven result.
kam327 is offline
Old 01-03-2013, 04:53 PM   #1748
Kabigon
Fan#: 88299
Best means always trouble free (i.e. smooth clutch engagement with no shuddering).
Having an IDS, being able to reset the adaptive learning, and being able to monitor virtually every parameter of the transmission and clutch operation has taught me a lot about how the DCT really works.
Kabigon is offline
Old 01-03-2013, 04:59 PM   #1749
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
Fair enough, guess I just like to provide advice based on direct results I've actually gotten.
kam327 is offline
Old 01-03-2013, 05:08 PM   #1750
bsp_53
bsp_53's Avatar
Fan#: 87580
What I Drive: 2012 FF Titanium HB, Yellow Blaze
FF Reputation: 1 bsp_53 Good Standing Member
I've got a little over 27,000 miles on my car now and today took it to the dealer to have them look at both an ever worsening tansmission shuddering issue and what I think is an upper strut mount on the driver's side that might be loose.
In test drive they were not able to duplicate the problems, but at my request, they removed the aero cover that's under the engine to inspect the tranny bell housing for leaks. I remember seeing a few spots of fluid seepage there when performing the oil change about 5,000miles ago, but it was not anything that "jumped out" at me as a problem. Evidently, upon inspection, they discovered a more substantial seep / leak.
So, the car was worked on all day and will be ready tomorrow mid morning some time (interestingly, they had the transmission seal as well as clutches in stock). I'll make the trip back to the dealer (about 72 miles one way) to get my nugget back. I'm both very excited to discover shifting improvements as well as appreciative for Darling Ford's receptiveness to my chief complaint. As far as the strut clunk, it is intermittent and might have been an ice chunk stuck somewhere up in there (but I doubt it). I'll keep you posted.
Gold Nugget: '12, Spec 400A, Winter Pckg, Yellow Blaze HB
Mods: Llumar Tint:35 frnt, 20 rear; K&N drop-in; Splashguards
Hatch Nation #174
bsp_53 is offline
