DCT / PowerShift Transmission Update TSB Thread - Page 148 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 TSB, Recall & Problems Archive
Old 08-16-2012, 11:11 AM   #1471
Gary_C
Fan#: 95312
What I Drive: 2012 White Platinum Focus Hatch
FF Reputation: 1 Gary_C Good Standing Member
I don't know the answer to that.
Did you get the recall notice for the Wiper motor?
If the wiper motor recall was done prior to purchase, the Driveability issue MAY have already been upgraded.
Best bet is call the dealer service dept and ask them. Have your VIN handy so they can check their database.
Gary_C is offline
Old 08-16-2012, 11:15 AM   #1472
suss6052
suss6052's Avatar
Fan#: 95752
FF Reputation: 23 suss6052 Great Standing Member
Originally Posted by nick625 View Post
Gary,
I just bought a 2012 made in 6/12. I'm having the same issues. How can I know if my car already has the Driveability upgrade installed?
Thanks.
According to Ford all vehicles built on or after 3/28/12 were supposed to be assembled with the latest programming for the DCT.
suss6052 is online now
Old 08-16-2012, 11:18 AM   #1473
Cylander
Fan#: 97131
What I Drive: 2012 Sterling Gray Focus Sedan SE
FF Reputation: 1 Cylander Good Standing Member
So after putting some miles on it after the update and not having to run the AC on max, my city mileage went from 26 MPG to 29 MPG.
Cylander is offline
Old 08-22-2012, 08:16 AM   #1474
nick625
Fan#: 102649
What I Drive: 2012 Focus
FF Reputation: 1 nick625 Good Standing Member
Does anyone know what the Ford recommended "adaptive drive cycle" is? Is it the 5 hard 0-60 starts?
nick625 is offline
Old 08-22-2012, 09:14 AM   #1475
jdetzel
Fan#: 102548
What I Drive: 2012 White Titanium Hatchback
FF Reputation: 1 jdetzel Good Standing Member
I do not think this is a Ford recomendation. Take a look at this thread "Possible fix for shaky clutch engagement"
jdetzel is offline
Old 08-22-2012, 12:25 PM   #1476
noahsfocus
noahsfocus's Avatar
Fan#: 90974
What I Drive: 2012 White Platinum Ti Sport Hatch
FF Reputation: 5 noahsfocus Good Standing Member
Here is the "Drive Cycle" Ford recommends there techs perform whenever the Adaptive Learning process is reset due to a PCM (tsb) update. You can also reset your Adaptive Learning manually by disconnecting the battery for around 5-15 min.
http://www.focusfanatics.com/forum/s...271673&page=26
Page 26 of this thread and it is mentioned on other pages too.
noahsfocus is offline
Old 08-22-2012, 01:01 PM   #1477
jdetzel
Fan#: 102548
Pat your Head and rub your Tummy
Originally Posted by noahsfocus View Post
Here is the Drive cycle procedure. I am sure in most cases the dealer performed this during the update. But if people are feeling erratic shifting then this could have been skipped.
I believe I heard in another thread that if you disconnect the battery for 10 min then the transmission adaptive learning process will be manually reset? May or may not be true but if it was that would be an easy way to do a reset and then perform the drive cycle procedure. On the other hand this drive cycle may only be needed after an actual PCM update as performed at the dealer. I suppose someone who had erratic shifting could always ask the dealer to do another reset and make sure they do the proper drive cycle procedure.
My dealer would of performed this but I volunteered so I could be sure it was done correctly and it also saved them time at the end of a busy day.
First steps I did in the parking lot while shifting from drive to reverse then I pulled out to a quiet street to go from 15mph to a slow stop 5 times. Then I drove slowly keeping between 1-4th gears to get to the nearest freeway (about 1.5mi away from dealer) then I drove from 55-65mph down the freeway to achieve 6th gear for 2min keeping rpm's under 3000 to complete the last step.
Then after about 10 min of normal driving I began sport driving and wow it felt really good and has been just great ever since.
Hope this helps.
Sorry but when reading the print out I couldn't help but think about that (Pat your hear and rub your tummy at the same time) and are you also supposed to click your shoes together 3 times.
jdetzel is offline
Old 08-22-2012, 01:07 PM   #1478
noahsfocus
noahsfocus's Avatar
Fan#: 90974
If you think it could help then by all means, give it a try ...
These steps help set the normal operation for the DCT including shift points. May seem a bit excessive but it's what the engineers came up with. They say to skip this step when the adaptive learning is reset may cause driveability issues. This is suppose to be for the Ford service techs, not the customer to perform.
Old 08-22-2012, 01:36 PM   #1479
Kabigon
Fan#: 88299
FF Reputation: 8 Kabigon Good Standing Member
If the adaptive learning is really blanked, the car won't move because the TCM is clueless about clutch enagagement (i.e. it hasn't "learned" the touch points).
The drive cycle simply accelerates the normal "learning" process for clutch engagement. It should be done by the dealer so that the clutches engage correctly (smoothly) before returning the car to the customer.
If the drive cycle is not performed, it doesn't matter after a day or two. For obvious reasons, the TCM is *always* "learning".
Kabigon is offline
Old 08-22-2012, 03:21 PM   #1480
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: '14 Ruby Ti w/ Handling Pkg
FF Reputation: 11 kam327 Great Standing Member
kam327 is offline
