DCT / PowerShift Transmission Update TSB Thread - Page 146 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 TSB, Recall & Problems Archive
Old 08-14-2012, 05:57 AM   #1451
jdetzel
Fan#: 102548
What I Drive: 2012 White Titanium Hatchback
FF Reputation: 1 jdetzel Good Standing Member
I am using S more and I will have to say it is more likely to be in the right gear when you need to go but it still has enough hiccups for me to say I wish it would sense throttle input better.
jdetzel is offline
Old 08-14-2012, 06:43 AM   #1452
Gary_C
Fan#: 95312
What I Drive: 2012 White Platinum Focus Hatch
FF Reputation: 1 Gary_C Good Standing Member
Exactly.. If the old school method of a kickdown linkage can select the proper gear, Why can't the new computer software do it by the throttle position??
It would seem simple enough since the pedal is no longer a mechanical item. It is just a variable potentiometer that operates a servo motor. Use the output voltage from the pedal to determine downshifts as well as the manifold vaccum. Sometimes you cant build a better mouse trap.
Yes the car is fun to drive in S mode and zip around like a little hot rod but,,
my commute to work everyday which is what i bought it for, doesn't warrant speeding around town.
Driving in D mode, IN MY OPINION, is terrible.
Perhaps the few uf us that are unhappy, have a mis adjusted accelerator pedal, and the ford mechanics are not aware, thinking it is the DTC complaint????
Just thinking outloud.
Gary_C is offline
Old 08-14-2012, 06:47 AM   #1453
Dysan911
Fan#: 95746
Agreed!. I would say it seemed to me like the prior update you could accelerate with a light foot. Meaning you didn't have to have it floored but instead could roll through a few gears with just a light pressure on the gas pedal and it would only shift sooner if you actually let up on the gas. The first thing I noticed after my reprogram that it seems to want to get into the tallest gear as soon as possible. Even while accelerating (Non-floored) it will shift even before it needed too and its usually then where I accept the fun is over. LOL
I can only hope another update happens soon that will resolve these issues.
I should also mention too that if I drive the car like an old lady, it does seem to be fine and the symptoms above aren't really an issue. I suspect because if I'm really not trying to accelerate out of turns and just lugging along trying to drive as conservative as possible then no problems usually. Perhaps thats what Ford was trying to achieve with the latest update. I just wish S mode for me would hold the shift points a bit higher.
Dysan911 is offline
Old 08-14-2012, 06:53 AM   #1454
jdetzel
Fan#: 102548
Amen on that. I would like to think it is a programing or software issue but is seems there are others with the same that are not experiencing any problems. So is my car haunted?
jdetzel is offline
Old 08-14-2012, 07:11 AM   #1455
bball40dtw
Fan#: 85847
What I Drive: 2012 Focus Ti and 2013 C-Max SE
FF Reputation: 1 bball40dtw Good Standing Member
It could be haunted, but it could also be programing, software, or hardware. I've had issues with all three. After the replacement of the clutch packs I don't have the shudder or unresponsive throttle.
bball40dtw is offline
Old 08-14-2012, 07:23 AM   #1456
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: '14 Ruby Ti w/ Handling Pkg
FF Reputation: 11 kam327 Great Standing Member
Unfortunately there are many people having much different experiences with the same software. For some reason the exact software/hardware interaction can result in myriad different results. For example after 12B37 the 6th gear shift point changed for me and one other poster on here that I know of, but most other people say their shift point didn't change. Why??? It's the same software!!!
I'm beginning to wonder if the engineers have taken this adaptive learning way too far. Why can't all cars just come with the same, set-in-stone programming that never changes over time. That way everyone would have the exact same driving experience. Barring a serious hardware problem of course.
kam327 is offline
Old 08-14-2012, 07:54 AM   #1457
smizak
Fan#: 92058
What I Drive: 2012 Black SEL
FF Reputation: 2 smizak Good Standing Member
+1,000,000
One calibration procedure for the computer to learn the clutch engage points and be done with it. I can't stand driving my car now after this "recall".
smizak is offline
Old 08-14-2012, 12:04 PM   #1458
unfocused1
Fan#: 95246
What I Drive: 2012 Candy Blue Ford Focus SEL
FF Reputation: 1 unfocused1 Good Standing Member
Originally Posted by VOLDAR View Post
rp3583, next time you buy a car, test drive it and get the most of the information possible about it. I am sure you didn't do this when buying your Focus, so blame yourself for your stupidity, not everyone else.
Try telling that to all the salesmen who tell customers "it drives just like an automatic". When customers ask questions, then they are not as stupid as you want them to be.
You do raise a good point, but in case the people you're responding to don't respond, it is possible they asked...
And the salesmen are still human, incapable of error along with everyone else...
A fan of Ford, Freedom, Duncan Yo-Yos (but not Duncan Hines confectionary), and Strattera...
unfocused1 is offline
Old 08-14-2012, 03:38 PM   #1459
VOLDAR
VOLDAR's Avatar
Fan#: 90444
What I Drive: Ford Focus 2012 SEL Hatchback
FF Reputation: 3 VOLDAR Good Standing Member
@unfocused1
I was so many times "the stupid", you cannot imagine how embaressed I am about this.
But since some time, I decided to change this and never buy what ever anyone sells without double checking. And a new car is not something you buy after 15 minutes of dealer's talk, IMO. Not even after 30 minutes, nor 45. They are salesmen, so who think they will speak also about the not that good things, they live in Lalaland. Internet is best for finding the information about what you want and Google is simple to use. Rant closed.
White Platinum Metallic Tri-Coat
303A, 6-Speed SelectShift Automatic, 17" Aluminum wheels, Luxury Package,
Parking Technology, Navigation, Winter Package
---------changed for--------------
Chevy Volt 2014, White Diamond, Luxury Package, S1
VOLDAR is offline
Old 08-14-2012, 03:48 PM   #1460
r1derbike
r1derbike's Avatar
Fan#: 62667
What I Drive: '12 SE Sport Hatch - Sterling Grey
FF Reputation: 4 r1derbike Good Standing Member
I drive mine in S mode, selectshift 90 percent of the time, except on the open highway.
My feeble brain is still smarter than any software programming Ford has to offer with this vehicle to date. The auto downshifting in S mode when tapping the brake on steep inclines is ridiculous, sometimes revving the engine to over 6K on its own, when just a little brake is needed. This is in S mode, with no selectshift intervention, letting it do its thing.
Other than quirks I may drive-around with the DCT, I absolutely love this car. It's a shame that the evolution of the DCT may take a few more years to comb and groom, before it becomes the game changer I know it is capable of. I'd be ecstatic if they left the computer control castrated in S mode, and just have selectshift as its option only.
2012 Focus; Maybe 3rd Time's the Charm?
r1derbike is offline
