DCT / PowerShift Transmission Update TSB Thread - Page 128 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-03-2012, 12:14 AM   #1271
Timthom62
Timthom62's Avatar
Fan#: 97579
What I Drive: 2012 Red Candy 5-Door SEL 303A
Points 2,786, Level 32
Points: 2,786, Level: 32 Points: 2,786, Level: 32 Points: 2,786, Level: 32
Level Up 24% Completed
FF Reputation: 5 Timthom62 Good Standing Member
Originally Posted by Freedom540 View Post
Is it possible for the transmission to forget the update after receiving it? I got the update a couple months ago but returned to Ford to have a clunking in the suspension fixed (strut bearings which are once again clunking) and after the repair i noticed the transmission seems to be up to its old pre-flash tricks. Is this possible?!
It appears that the memory of the TCU is cleared if the battery is disconnected. Assuming that the Ford techs disconnected your battery while they were working on it, this could be the cause.
Timthom62 is offline
Old 07-03-2012, 12:54 AM   #1272
Kabigon
Fan#: 88299
Points 4,414, Level 42
Points: 4,414, Level: 42 Points: 4,414, Level: 42 Points: 4,414, Level: 42
Level Up 32% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 11 Kabigon Great Standing Member
The firmware of all modules (PCM, TCM, BCM, etc.) are stored in flash memory.
If you upgraded your OS from OSX Weasel to OSX Aardvark , your computer would not revert to OSX Weasel if the power was removed.
Kabigon is offline
Old 07-03-2012, 12:58 AM   #1273
Kabigon
Fan#: 88299
Forum Activity 15%
Originally Posted by dberezin View Post
You shouldn't have to baby the car when driving it.
I have reason to believe that it may be just the opposite. The clutches may become "grabby" if the car is always babied. I would be curious to know if the clutches "smooth out" after several 0-60 runs with your foot to the floor.
Kabigon is offline
Old 07-03-2012, 06:55 AM   #1274
JL330
Fan#: 99616
What I Drive: 2012 silver focus S
FF Reputation: 1 JL330 Good Standing Member
Mine did. I normally baby it, but I said screw has mileage and romped on it for a while during my lunch break. It's driven great since then and it's even less noisy. I love that under the right conditions, I can chirp the tires on the 1-2 shift in a car like this.
JL330 is offline
Old 07-03-2012, 07:11 AM   #1275
smizak
Fan#: 92058
What I Drive: 2012 Black SEL
FF Reputation: 2 smizak Good Standing Member
Speak English, iTard.
j/k
smizak is offline
Old 07-03-2012, 08:41 AM   #1276
Timthom62
Timthom62's Avatar
Fan#: 97579
The firmware would be stored in non-volatile memory, yes.
Do you have some documentation that says that this is also true for the 'learned' portion of the memory in the TCM?
According to the Ford techs I've spoken with, and the little documentation I've been able to find, the 'learned' portion is stored in volatile memory that is cleared when power is removed. This type of memory allows the 'learned' portion of the program to be constantly overwritten, as opposed to having to be externally 'flashed' like the EPROMs used for the firmware.
Old 07-03-2012, 08:49 AM   #1277
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2014 Titanium 5-speed
Points 2,446, Level 29
Points: 2,446, Level: 29 Points: 2,446, Level: 29 Points: 2,446, Level: 29
Level Up 98% Completed
FF Reputation: 3 cbdallas Good Standing Member
I've had mine since 6/15 but it only has about 400 miles on it, and it seems to be a little smoother every time I drive it. I do keep it in "S" though, and that in itself exhibits some weird behavior.
On my way home from school last night, someone ahead of me slowed to make a right turn, and I 'got on it' after I went past them, & it downshifted to 3rd, and then stayed there. I hadn't initiated manual mode, but for some reason it just locked itself in 3rd even after I let up on the throttle. It never did upshift until I hit the 'up' button, and then the gear numbers appeared on the screen and it shifted. Wierd anamole.
I still get a bit of bog when I turn into my subdivision and accelerate, but it does it less in "S" mode. Not sure what that's about either.
Overall it's getting better than the day I brought it home. I can tell it's learning something about the way I drive. Thankfully.
cbdallas is offline
Old 07-03-2012, 09:03 AM   #1278
Brabs_Weather
Fan#: 93741
What I Drive: 04 Ex Ltd, 08 Edge Ltd, 12 FF Ti
FF Reputation: 2 Brabs_Weather Good Standing Member
Mine shifts by itself in S mode, however it will not shift into 6th automatically. Once you use the shift button in S mode it will not shift until you redline it. You have to go up to D and back to S. Well thats how mine seems to work.
White Platinum Tricoat Metallic
2012 Ford Focus Titanium
Handling Package Nitto Motivo's
Borla Exhaust with UltraQuiet resonator
K&N X-4870. Steeda RSB
Brabs_Weather is offline
Old 07-03-2012, 04:23 PM   #1279
Kabigon
Fan#: 88299
Forum Activity 15%
In 'S' mode, the transmission will not shift into 6th gear automatically (I'm not sure if you are aware of this).
Kabigon is offline
Old 07-03-2012, 04:39 PM   #1280
Kabigon
Fan#: 88299
Forum Activity 15%
In my experience, if the adaptive learning of the TCM is really cleared (which would happen with some firmware updates), the car won't even move when you put it in gear. This is because the TCM doesn't know the point of enagagement for the clutches.
Kabigon is offline
