DCT / PowerShift Transmission Update TSB Thread - Page 115 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-14-2012, 11:22 PM   #1141
RustyPonds
RustyPonds's Avatar
Fan#: 84824
What I Drive: Grey 2012 Focus Ti Hatchback w/Nav
FF Reputation: 1 RustyPonds Good Standing Member
Originally Posted by bdashrad View Post
So after a week the car is still driving well, but I have noticed that when putting the car in park and shutting off the engine, it occasionally does one of two things:
Lurches, similar to when you let off the clutch in a manual while it's in gear and it stalls.
Rolls slightly before actually "locking" into park, definitely more than it did prior to the update. This is (obviously) more noticeable on hills, but has occurred even on a slight incline.
Has anyone else noticed either of these things?
Same here. Got the TSB 11-10-02A update and while the car is smoother over all, it seems I get a little "boot" once I hit my push start to turn the engine off.
I always put the the break on first though, so I don't know about lurching, but the bump at the end is definitely new.
Respect Begets Respect
RustyPonds is offline
Old 05-15-2012, 12:17 AM   #1142
Kabigon
Fan#: 88299
Points 4,568, Level 43
Points: 4,568, Level: 43 Points: 4,568, Level: 43 Points: 4,568, Level: 43
Level Up 9% Completed
Forum Activity 14%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by kam327 View Post
Why do you have to shift into park first? I always pull the parking brake first and then shift into park.
It's a good habit, especially if you ever park your car and leave the engine running for whatever reason.
With the engine running, the shift lever in 'D', the parking brake on, and your foot off of the brake, you may get partial clutch engagement (i.e. it wants to creep forward as normal but it can't because of the parking brake). In this case, the clutch would heat up and you would get unnecessary wear.
Actually, I believe that this problem may have been corrected in the last PCM/TCM reflash but it has happened to me in the past.
Why did I leave it in 'D' with the parking brake on? I shouldn't have but I think it had something to do with the fact that this is my first car with an automatic.
Kabigon is offline
Old 05-15-2012, 12:28 AM   #1143
Kabigon
Fan#: 88299
Forum Activity 14%
Originally Posted by VOLDAR View Post
From the day one, when parking my car on an incline, I was told to first use the hand-brake, put the car in N to transfer the weight to it, then to P. This car is acting almost as a manual transmission one and you should always use the hand-brake before putting into P.
That works, or without shifting to 'N':
1) Keep your foot on the brake pedal (you would normally have your foot on the brake anyway when parking).
2) Shift to 'P'.
3) Engage parking brake.
By keeping your foot on the brake pedal, there is no stress on the parking pawl.
Kabigon is offline
Old 05-15-2012, 12:35 AM   #1144
bdashrad
bdashrad's Avatar
Fan#: 48741
What I Drive: 2015 Tornado Red GTI S 5-Door
Points 14, Level 1
Points: 14, Level: 1 Points: 14, Level: 1 Points: 14, Level: 1
Level Up 27% Completed
FF Reputation: 1 bdashrad Good Standing Member
Originally Posted by Kabigon View Post
If you are parking on anything other than a level surface, it is a good idea to engage the parking brake (after putting the trans. in 'P' but before taking your foot off of the brake pedal).
The parking pawl should be used only as a "backup".
I got in a bad habit with my last focus (2001 zx3) who's parking brake did not work of just leaving it in gear, so I do try to put the parking brake on first now. However, on a very slight incline it's still noticeable, and I never noticed it before the update. Just commenting on my experience.
Anyway, I'm still much happier overall since the upgrade.
bdashrad is offline
Old 05-16-2012, 09:24 PM   #1145
Richs10
Richs10's Avatar
Fan#: 95786
What I Drive: 2012 Sonic Blue Titanium Hatch
Points 336, Level 6
Points: 336, Level: 6 Points: 336, Level: 6 Points: 336, Level: 6
Level Up 72% Completed
FF Reputation: 1 Richs10 Good Standing Member
Just thought I would mention that a lot of people in the FSA 12B37 thread are noting very substantial improvements in the operation of their DCTs after getting that update on their cars. Anyone who is eligible should get this done. My DCT was pretty good before the update. Now I think this may be one of the best automatics in a four-banger that I've driven. I think I now understand why Ford wanted this transmission in their car. Maybe they have finally got the bugs worked out. (But I still think those complaints of 'grinding' are a separate issue Ford has got to deal with. Fortunately I've never experienced that. )
Rich
Leather, Nav/MFT, Moonroof, 18" wheels, Handling & Winter Packages, Remote Start.
Echomaster DRLs.
Richs10 is offline
Old 05-16-2012, 10:26 PM   #1146
bsp_53
bsp_53's Avatar
Fan#: 87580
What I Drive: 2012 FF Titanium HB, Yellow Blaze
Points 519, Level 10
Points: 519, Level: 10 Points: 519, Level: 10 Points: 519, Level: 10
Level Up 38% Completed
FF Reputation: 1 bsp_53 Good Standing Member
Rich
^^...This! I just got mine done today, wow, no regrets!
Gold Nugget: '12, 400A, Wintr Pckg, Yellow Blaze HB
Mods: Llumar Tint:35 / 20; K&N fltr + Snrkl Del.; Splashgrds; Grill Pinstripes
Hatch Nation #174
bsp_53 is offline
Old 05-17-2012, 07:56 AM   #1147
Scott S
Fan#: 98137
What I Drive: 2012 Focus Titanium Blue Candy,
FF Reputation: 1 Scott S Good Standing Member
Rich
I have a job 2 car which I suspect had all the latest updates applied at the factory and although I only have 2000 on it I really like the DCT. I too feel it is one of the best automatics out there. Mannerisms and power transfer of a manual with the gas and go benefits of an automatic for ease of use in traffic.
Scott S is offline
Old 05-17-2012, 08:33 AM   #1148
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: '14 Ruby Ti w/ Handling Pkg
Points 7,615, Level 58
Points: 7,615, Level: 58 Points: 7,615, Level: 58 Points: 7,615, Level: 58
Level Up 33% Completed
Forum Activity 3%
FF Reputation: 13 kam327 Great Standing Member
Ahhh, well I guess seems to me that forgetting to shift into park can happen whether yo normally do it as the first or second step, but it shouldn't matter as long as taking your foot off the brake is the third step.
kam327 is offline
Old 05-21-2012, 04:42 PM   #1149
hothatch
hothatch's Avatar
Fan#: 93693
What I Drive: 2012 5-Door SE, Sport Pkg
FF Reputation: 1 hothatch Good Standing Member
I had an update done in early February, is the FSA 12B37 an even newer update? Just wondering if I should have it done.
hothatch is offline
Old 05-21-2012, 04:45 PM   #1150
6769MOPARS
6769MOPARS's Avatar
Fan#: 86108
What I Drive: PB Focus ST2 and 67 426 Hemi GTX
Points 556, Level 11
Points: 556, Level: 11 Points: 556, Level: 11 Points: 556, Level: 11
Level Up 12% Completed
FF Reputation: 1 6769MOPARS Good Standing Member
If you get the letter which is being mailed to applicable car owners this week, yes.
6769MOPARS is offline
