Car running poorly, trans issues - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 10-27-2011, 09:07 PM   #1
mikehutch
Fan#: 58369
What I Drive: 2003 Red ZTW
FF Reputation: 1 mikehutch Good Standing Member
So my car recently joined the 200k club and now is having issues.
Tonight I was going down the highway and the car seem to kick out of gear, the multifunction light (trans/coolant) came on and the car seem to die. I let off the gas and was pulling onto the off ramp and all seem to be normal.
I get to the soccer field and when I go to pull in the car again seem to pop out of gear, multifunction light comes on and it dies.
When it was time to go home the car started running very poorly, trans would seem to be in neutral(slipping). I pulled off into a parking lot as there was no way I could drive all the way home like that.
While in the parking lot the car would idle rough, but smooth out above 1100 RPM while in Park or Neutral. If the car was in any gear it would run rough. Not sure if these cars have some time of brake/gas logic, but I tired power braking it and about 1300 RPM was all it would do with the foot to the floor with lots of vibations, seeming to come from the trans. While waiting for a ride I continued to play and the car would pretty much die if put into any gear. In Park or neutral it would stay running but rough at idle.
There is no CEL so I'm guessing no codes to pull.
Not sure what happens with trans failures as I think these have some electronics inside them.
Any suggestions?
Recent fixes were a new EGR, pressure switch and solenoid as it was throwing a code for the EGR. No codes for a few weeks now.
The Stable:
1970 Cougar Convertible 1984 Mustang GT350
1996 Dodge 4X4
2003 Focus ZTW 2008 EB Explorer
mikehutch is offline
Old 11-09-2011, 10:21 PM   #2
Brent72
Fan#: 69545
What I Drive: 2006 Black ZX3
FF Reputation: 1 Brent72 Good Standing Member
Sounds like you def need a trans rebuild. Could be torque converter.
Brent72 is offline
Old 11-08-2012, 10:04 PM   #3
bac512
Fan#: 87149
What I Drive: 2003 gray SE
FF Reputation: 1 bac512 Good Standing Member
Did ya ever figure out the problem? What was it? from what you're describing, at least it sounds to me, like what my car was doing when I had a vacuum leak (at least, I think that was the problem at that time :) )
bac512 is offline
Old 11-08-2012, 11:23 PM   #4
Incognito27
Incognito27's Avatar
Fan#: 34939
What I Drive: 2003 Ford Focus ZX5 Premium - White
FF Reputation: 3 Incognito27 Good Standing Member
There was a time , when i had a issue similar to this , but it was oil leaking down to the spark plugs and cause missfires and making the entire car run rough . Doesn't explain the falling out of gear issue , but maybe the running rough . Also vaccum leaks can cause all sorts of weird things.
Incognito27 is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
