"How To" - Front Sway Bar Install - Page 10 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-18-2012, 11:16 AM   #91
svtguy88
svtguy88's Avatar
Fan#: 13476
What I Drive: 2003 Infra Red SVT
Points 8,660, Level 62
Points: 8,660, Level: 62 Points: 8,660, Level: 62 Points: 8,660, Level: 62
Level Up 70% Completed
FF Reputation: 17 svtguy88 Great Standing Member
Again, this is going off of what my car is like, but dropping the subframe isn't really that difficult. I didn't want to do it either, but once you bite the bullet, it's not that bad.
The bolts are tight, so air tools are useful, but not absolutely necessary. Back them out evenly, and the subframe will drop down nice and slow. Put a floor jack under it to support it (just in case you back the bolts out too far).
svtguy88 is offline
Old 08-18-2012, 01:53 PM   #92
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
Forum Activity 2%
You don't need to drop the subframe completely.
Leave the forward two bolts in, tilt the subframe so the rear is hanging down 3".
I didn't find any part of the front swaybar install tricky, very straightforward.
elsolo is offline
Old 08-20-2012, 03:12 PM   #93
Mumford
Mumford's Avatar
Fan#: 99437
What I Drive: 2009, Sangria Red, SE Coupe
Points 1,607, Level 23
Points: 1,607, Level: 23 Points: 1,607, Level: 23 Points: 1,607, Level: 23
Level Up 7% Completed
Forum Activity 3%
FF Reputation: 3 Mumford Good Standing Member
oh ok that makes it sound so much better and less stress full then i thought lol thanks guys ill let you know how it goes here pb next month lol
have you been mumfed yet
FF14 2nd place winner non-hatch 00-11 sponsored by focus power
Mumford is offline
Old 03-16-2014, 10:20 AM   #94
mjoyce
mjoyce's Avatar
Fan#: 74948
What I Drive: 2004 SVT EAP Screaming Yellow
FF Reputation: 1 mjoyce Good Standing Member
So I replaced my stuts with some Konis and it was raining so I when ahead tackled the sway bars. It looks easy enough in the pics and I have air tools so I started. It took every bit of four hours. With air it helps but the sway bar brackets air can't be used. So it took most of the time getting those out. Oddly enough it went back together alot faster. I completely removed all sub frame bolts and it hangs nicely. I actually could have used more of a drop to get more room. Anyway putting all the sub frame bolts back in as far as lining them up with the holes was easy. No issues at all. Maybe 30 minutes after the new sway bar was positioned. Hours laying on concrete takes it toll. My body hurts. Lol.
mjoyce is offline
Old 03-16-2014, 04:23 PM   #95
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,409, Level 75
Points: 13,409, Level: 75 Points: 13,409, Level: 75 Points: 13,409, Level: 75
Level Up 40% Completed
Forum Activity 99%
Moved to "Brakes, Suspension & Chassis".
Useful "How To" left behind when the sections were split.
Good to see it helped again, and appreciate the notes on what worked easiest for you.
Rest up the sore back, then have some fun with the new suspension!
Cheers
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
Front sway bar enlink question niko General Technical Chat 4 03-06-2009 12:19 AM
New Sway bar in front... new sound in front Rujokinjal Wheels & Tires 1 07-02-2008 08:01 PM
front sway bar, better handling sirjohnw Focus Tuning Chat 5 06-30-2008 11:26 AM
New Volkswagen Rabbit!! nomoreavril Ford Focus & General Car Chat 30 06-29-2006 12:55 PM
