"How To" - Front Sway Bar Install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-09-2004, 07:43 PM   #1
Shady R
Fan#: 3138
What I Drive: Euro 2003 PitchBlack SVT Focus
FF Reputation: 8 Shady R Good Standing Member
Well I would like to mention if your not sure of your mechanicall skills let a PRO do the install. This install will take 2 hours for an experienced person but for some one who is considerd a Rookie it may take 6 hours from start to finish. By all means have a second person with you to ease the install time and for safety reasons of course.
Tools Required:
1/2 inch drive sockets, Metric
1/2 inch drive ratchet
1/2 inch torq rench
13MM
15MM
18MM
Box wrench
13MM
Hydraulic jack
2 Jack stands
Nice long breaker bar or extension pipe for ease of bolt removeall.
Oh yahh one more thing, clean pair ooooo shorts on hand. Some bolts require some Arm, Back, and some grunting muscles. Darn bolts are tight, Not kidding.
So here it goes, hope you guys like the write up.
Bwaha ha ha ha ha ha, Bleach Fan from day 1. 07-2005:: Spoiler:: Aizen is a good guy. Every one dies. Orihime Saves every one. All there memories are erased as if NONE of it happend.
Shady R is offline
Old 10-09-2004, 07:54 PM   #2
Shady R
Fan#: 3138
jack placement
lift car by subframe. notice that the jack is lifting on the the subframe at the motor mount bolt location.
The stands need to be placed 2 inches behind the subframe. Note it's very important to have the spaceing.
Name:	jack placement and stands pic 1.jpg
Shady R is offline
Old 10-09-2004, 08:03 PM   #3
Shady R
Fan#: 3138
hate posting pics here. 50000 more like 20000jpg
Don't pinch fuel or brake lines.
Name:	placement of stands pic2.jpg
Shady R is offline
Old 10-09-2004, 08:07 PM   #4
Shady R
Fan#: 3138
This connection maybe the easiest part of the whole install.
Name:	swaybar end pic 3.jpg
Shady R is offline
Old 10-09-2004, 08:10 PM   #5
Shady R
Fan#: 3138
1. Best position for removeal.
2. place 13MM box wrench on opposite side to prevent the connecter from spinning.
Name:	break loose swaybar ends pic4.jpg
Shady R is offline
Old 10-09-2004, 08:14 PM   #6
Shady R
Fan#: 3138
Now lets see some muscle. this is where you get dirty.
You will need the 18MM socket to break these loose. Make sure the bolts your breaking loose are these or this could become really dangerous for you very quickly. There will be the 2 on the passenger side and two on the driver.
Name:	sub frame bolts 1.jpg
Shady R is offline
Old 10-09-2004, 08:18 PM   #7
Shady R
Fan#: 3138
Pic on driver side.
Name:	sub frame bolts 2.jpg
Shady R is offline
Old 10-09-2004, 08:23 PM   #8
Shady R
Fan#: 3138
These are the upper subframe bolts these are tighter than the lower subframe bolts. No reallly I'm not kidding these are held in place with a grade 10.9 bolt there tight so if you got this far with a 3/8 ratchet stop now before you hurt your self. These are 15MM bolts.
Name:	sub frame bolts 3.jpg
Shady R is offline
Old 10-09-2004, 08:43 PM   #9
Shady R
Fan#: 3138
After the removeal of the bolts from driver and passenger side it's time to lower the subframe. Lower jack slowly and be sure the car doesn't rock or woble for safety reasons of course.
Name:	sub frame lowering1.jpg
Shady R is offline
Old 10-09-2004, 08:51 PM   #10
Shady R
Fan#: 3138
Remove brackets from subframe and sway bar. the assembly will be re used so be careful not to damage the bolts. The rear bolts are about 4 inches long so those are where I started first. Basicly get the hard part outa the way first. The driver side looks identicle but there is a slightly more confined space to work with, the steering components are an inconvenience but easily worked around.
Name:	sway bar mount1.jpg
Shady R is offline
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
Front sway bar enlink question niko General Technical Chat 4 03-06-2009 12:19 AM
New Sway bar in front... new sound in front Rujokinjal Wheels & Tires 1 07-02-2008 08:01 PM
front sway bar, better handling sirjohnw Focus Tuning Chat 5 06-30-2008 11:26 AM
New Volkswagen Rabbit!! nomoreavril Ford Focus & General Car Chat 30 06-29-2006 12:55 PM
