My Ford Touch Thread - Page 64 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-08-2012, 04:13 PM   #631
Zip60912
Fan#: 93826
What I Drive: 2012 White Titanium 4 dr
Points 23, Level 1
Points: 23, Level: 1 Points: 23, Level: 1 Points: 23, Level: 1
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
FF Reputation: 1 Zip60912 Good Standing Member
Originally Posted by Emmortal View Post
Had to do a reboot of the system to get the install to run, once that was done it worked and I'm currently just waiting for it to complete. Here's hoping it finishes without a hitch.
Guess there was something up with my system from the get go since I've only had the car for about 10 days. No wonder album art never really worked right.
What version are you installing? The one shared in this thread or the download from Ford Sync?
2012 Focus Titanium Sedan
White Platinum Metallic Tri-coat
401A & Luxury Package & 17" Machined alloy painted wheels
Zip60912 is offline
Old 03-08-2012, 04:15 PM   #632
Emmortal
Fan#: 92957
What I Drive: 2012 Sterling Grey Focus Titanium
Points 21, Level 1
Points: 21, Level: 1 Points: 21, Level: 1 Points: 21, Level: 1
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 1 Emmortal Good Standing Member
Downloaded from Ford Sync, though I would be willing to bet the one from here would work since the update direct from ford gave me the same error originally.
Emmortal is offline
Old 03-08-2012, 04:17 PM   #633
Zip60912
Fan#: 93826
Points 23, Level 1
And was the one you downloaded 680MB?
Zip60912 is offline
Old 03-08-2012, 04:19 PM   #634
Emmortal
Fan#: 92957
Points 21, Level 1
Once it's done I'll report back on the size. :)
Emmortal is offline
Old 03-08-2012, 04:46 PM   #635
hotleadsingerguy
hotleadsingerguy's Avatar
Fan#: 86687
What I Drive: 2012 Black Titanium 5-Door
FF Reputation: 5 hotleadsingerguy Good Standing Member
I have a theory on the size difference...Ford released mobile apps for iOS and Android that were basically the interface (almost fully-functionality) and since some of the things don't really work (radio, nav, etc...) they were "created" with shockwave videos that would play when you try to use those functions. That way, it looked as though things were running correctly, even when they weren't.
The total size of the download was 89MB, if I'm not mistaken, and it was mostly video files. If they were, for some idiotic reason, included in the installer that was sent out...that would explain the difference.
hotleadsingerguy is offline
Old 03-08-2012, 04:59 PM   #636
Emmortal
Fan#: 92957
Points 21, Level 1
Update done successfully. Looks great from what I can tell, I like the layout and it seems much snappier so far. Now to grab some wallpapers and put them on tonight. :)
For the sizes:
From Syncmyride.com - 680MB
Download from here - 696MB
Emmortal is offline
Old 03-08-2012, 05:38 PM   #637
Kabigon
Fan#: 88299
Points 4,428, Level 42
Points: 4,428, Level: 42 Points: 4,428, Level: 42 Points: 4,428, Level: 42
Level Up 39% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by txskeets View Post
I'm still convinced (though I have no way to test this) that even though my MFT did not come with NAV, that if I popped an official SD card from Ford into the SD slot that the NAV would work perfectly. Fords BS line that it has to be activated at the factory in my mind is just wrong.
It is true.
There is a difference in the APIM (firmware wise).
If the Nav SD card is not present on a vehicle with Nav, you will get a message "Insert Nav SD Card".
Kabigon is offline
Old 03-08-2012, 05:39 PM   #638
jeb5000
Fan#: 95481
What I Drive: 2012 Black Focus Titanium
FF Reputation: 1 jeb5000 Good Standing Member
I was sent to dealer last night because of extreme problems with MFT. They had USB and Nav Card for me. Have gone 24 hours without a problem, a new record. Only problem was I could not program the two favorites on the steering wheel. Called Ford and they had no idea. They implied I may have lost this functionally with the upgrade. If I don't have black screens of death, totally black dash board at night, max air, max heat, max volume while parked at night, etc, I guess I should be happy. Good luck to everyone. They did the upgrade because Ford had no idea when my upgrade would arrive since mailings are being staggered.
ver 302
jeb5000 is offline
Old 03-08-2012, 05:45 PM   #639
Kabigon
Fan#: 88299
Forum Activity 16%
Originally Posted by hotleadsingerguy View Post
5) Volume indicator doesn't update for every change. It only updates every *other* change.
They fixed one of my biggest gripes.
The reason for changing the indicator for every 2 volume steps (instead of 1 step in the previous version) should be obvious.
Kabigon is offline
Old 03-08-2012, 06:17 PM   #640
bsp_53
bsp_53's Avatar
Fan#: 87580
What I Drive: 2012 FF Titanium HB, Yellow Blaze
Points 519, Level 10
Points: 519, Level: 10 Points: 519, Level: 10 Points: 519, Level: 10
Level Up 38% Completed
FF Reputation: 1 bsp_53 Good Standing Member
I'm still convinced (though I have no way to test this) that even though my MFT did not come with NAV, that if I popped an official SD card from Ford into the SD slot that the NAV would work perfectly. Fords BS line that it has to be activated at the factory in my mind is just wrong. Even though I dont have NAV, I can use Sync Destinations and it will give me turn by turn directions though MFT. I'm going to figure out a way to test this theory one day. :)
Please do, as I have a similar suspicion.
Regardless, it is just a matter of time before a tech company (ie. http://www.coastaletech.com/synclockpick.htm) takes care of this for us (assuming insertion of the appropriate nav SD card does not enable the system).
Gold Nugget: '12, 400A, Wintr Pckg, Yellow Blaze HB
Mods: Llumar Tint:35 / 20; K&N fltr + Snrkl Del.; Splashgrds; Grill Pinstripes
Hatch Nation #174
bsp_53 is offline
