My Ford Touch Thread - Page 354 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-28-2013, 12:47 PM   #3531
skramblr
Fan#: 86363
What I Drive: 2012 Focus SEL & 2012 Mustang GT
Points 288, Level 5
Points: 288, Level: 5 Points: 288, Level: 5 Points: 288, Level: 5
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 1 skramblr Good Standing Member
Since the update many things have been improved, but I have one new annoying bug. Sometimes the clock decides to display eastern time instead of pacific time - so the clock is off by several hours. But then it will fix itself after a while. But another annoying bug is that the clock will just decide to set itself back 1 hour - like it isn't using daylight savings time - eventhough it is set. You have to manually change the time back to the correct hour. If you hit the reset to GPS time - it jumps back an hour.
Anyone else have clock problems since the update?
skramblr is offline
Old 09-30-2013, 11:05 AM   #3532
FordIVTteam
Official Ford Rep
FordIVTteam's Avatar
Fan#: 87765
What I Drive: Ford Focus
Points 2,197, Level 28
Points: 2,197, Level: 28 Points: 2,197, Level: 28 Points: 2,197, Level: 28
Level Up 32% Completed
Forum Activity 2%
FF Reputation: 3 FordIVTteam Good Standing Member
When your clock is showing in the Eastern time zone, skramblr, does the navigation show you in a different location as well?
Rebecca
FORD IN-VEHICLE TECHNOLOGY TEAM
p: 800.392.FORD (Prompts 1 then 3)
f: facebook.com/FordFocus facebook.com/Ford
FordIVTteam is offline
Old 09-30-2013, 07:05 PM   #3533
blackraven456
Fan#: 88061
What I Drive: 2012 Black Focus Titanium Sedan
FF Reputation: 1 blackraven456 Good Standing Member
So, since I'm tired of waiting for Ford to issue a new MFT update with a Zune fix, I decided to get proactive and put some music on a micro sd card I had laying around with a usb adapter.
Long story short I found a really easy (though involved) way to get exactly what's on my zune onto the card including the playlists. I stuck it into the car and it indexes and plays within 2 minutes and doesn't re-index when restarting the car.
The trouble is that MFT doesn't play a zune playlist unless its on a zune, so I had to convert them to m3u files. Excellent, now the car see's them. NOT excellent, it says that the files are empty. They aren't.
So I went and looked and the path was pointing at a location that wasn't the root of the card. So, I used notepad to edit the m3u file to remove the reference to that location, only leaving the folder on my card of my music. Awesome, works in winamp, perfectly. I stick the USB into my car and NOT awesome, it sees the files but continues to think they are empty.
What am I doing wrong? I'm super annoyed at the whole situation.
This is why I originally bought a zune years ago, was easy, fast and worked without having to second guess anything.
2012 Titanium Sedan, Ebony Black - 400A, Luxury Package
Ordered: July 14 VIN received: August 19 Sticker: Sept 3 Build Date: Sept 10 Delivered: Sept 21
blackraven456 is offline
Old 09-30-2013, 08:44 PM   #3534
MrMyth
Fan#: 106845
What I Drive: 2013 Performance Blue Focus
Points 21, Level 1
Points: 21, Level: 1 Points: 21, Level: 1 Points: 21, Level: 1
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 2 MrMyth Good Standing Member
You need MediaMonkey. it can behave like the Zune software in that it has smart playlists that can auto-sync to an SD card. The playlists are readable by MFT if you save them as M3u Extended. They can be either in the root of the card or in a folder named 'Playlists'. Either works well for me.
Also, save yourself some frustration and embed the artwork into your files, 500kb or less in size. MFT can read folder.jpg files in the root of the album folder, but it much prefers embedded artwork.
My Zune-less setup works so smoothly now I'm not sure that I'll go back if they fix the compatibility. MFT was clearly designed with an SD card in mind. If only Microsoft's internal divisions weren't all out to get each other. When I think of what could have been in regards to Windows Phone 8 and the Zune pass subscription I still get angry.
MrMyth is offline
Old 10-01-2013, 11:35 AM   #3535
blackraven456
Fan#: 88061
Thanks for all the help, I'll give it a try. As a side note, how long does it take your car to recognize the card? It takes mine like 2 minutes and will actually go to the radio because it can't connect for so long. I switched the microsd from a full SD adapter to a usb one and it boots up much faster now but Id rather have those ports free.
Old 10-01-2013, 12:26 PM   #3536
blackraven456
Fan#: 88061
Well, I'm now ready to throw my computer and car out the window. Media Monkey is good going forward, but doesn't even see the playlists I've already converted from zpl and tried to make work im m3u. I manually edited them in notepad and it STILL won't give me the tracks. Seriously, Ford should pay ME for this waste of time.
Old 10-01-2013, 12:47 PM   #3537
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
So, remake the playlists?
Sonic Crew #28
feta_mgp is offline
Old 10-01-2013, 12:51 PM   #3538
blackraven456
Fan#: 88061
They're like 300 - 600 songs each :-( I have a dozen of them
Sent from my Galaxy Nexus using FF Mobile 4
Old 10-01-2013, 01:16 PM   #3539
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Time consuming to be sure, but the end result is likely a lot better than the frustration you've had thus far. Do one a day for the next two weeks or so?
Sonic Crew #28
feta_mgp is offline
Old 10-01-2013, 01:29 PM   #3540
blackraven456
Fan#: 88061
Maybe - I just wish I didn't have to.
