My Ford Touch Thread - Page 118 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-24-2012, 01:45 PM   #1171
blackraven456
Fan#: 88061
What I Drive: 2012 Black Focus Titanium Sedan
FF Reputation: 1 blackraven456 Good Standing Member
^^^ yup, all the volumes are independent of one another.
Sent from my Telus Samsung Galaxy S Fascinate
2012 Titanium Sedan, Ebony Black - 400A, Luxury Package
Ordered: July 14 VIN received: August 19 Sticker: Sept 3 Build Date: Sept 10 Delivered: Sept 21
blackraven456 is offline
Old 03-24-2012, 03:07 PM   #1172
xpartmgr
xpartmgr's Avatar
Fan#: 96709
What I Drive: 2012 White Ford Focus Titanium
FF Reputation: 2 xpartmgr Good Standing Member
Originally Posted by mattphoto View Post
I was suspicious of this for a while, finally was able to confirm it today.
Since my update, Auto lamp on with wipers (aka "Rain lights") feature no longer works.
Anyone else have this issue?
Yeah after my update last week mine stopped working also. I must say I am pretty shocked at poorly this touch system and the programming for it works. I would have likely passed on this car had I known all the issues before hand.
xpartmgr is offline
Old 03-24-2012, 03:36 PM   #1173
Richs10
Richs10's Avatar
Fan#: 95786
What I Drive: 2012 Sonic Blue Titanium Hatch
Points 336, Level 6
Points: 336, Level: 6 Points: 336, Level: 6 Points: 336, Level: 6
Level Up 72% Completed
FF Reputation: 1 Richs10 Good Standing Member
I don't think this is a MFT issue. I've got a Jan 2012 build Titanium. Still running original version of MFT. Just drove it in the rain and the headlights did not come on with the rain sensing wipers. Steady rainfall. I not sure MFT has anything to do with this.
Leather, Nav/MFT, Moonroof, 18" wheels, Handling & Winter Packages, Remote Start.
Echomaster DRLs.
Richs10 is offline
Old 03-24-2012, 03:43 PM   #1174
6769MOPARS
6769MOPARS's Avatar
Fan#: 86108
What I Drive: PB Focus ST2 and 67 426 Hemi GTX
Points 556, Level 11
Points: 556, Level: 11 Points: 556, Level: 11 Points: 556, Level: 11
Level Up 12% Completed
FF Reputation: 1 6769MOPARS Good Standing Member
Are your wipers set on intermittent? From the owner's guide:
"Rain-sensing wipers (if equipped)
"The rain-sensing wipers will automatically activate when moisture is
present on the windshield and control is intermittent operation position.
Adjust the rotary control to the desired moisture sensitivity settings. The
speed of the rain-sensitive wipers will vary based on the amount of
moisture detected on the windshield and the sensitivity setting. There
are no interval (intermittent wipe) settings on vehicles with rain-sensing
wipers. The wipers will continue to wipe as long as the presence of
moisture is detected on the windshield. More or less wiping may occur
depending on humidity, mist or light rain, or road spray.
"Keep the outside of the windshield clean, especially the area around the
rear view mirror where the sensor is located or rain sensor performance
may be affected.
"Note: During winter driving conditions with ice, snow or a salty road
mist, inconsistent or unexpected wiping or smearing may occur. In these
conditions, you can lower the sensitivity to reduce the amount of
smearing or override the feature by selecting low- or high-speed wiping
or turning the wiper system off.
"Note: The wipers must be turned off before entering a car wash."
Headlamps:
"Note: If the vehicle is equipped with autolamps, it will have the
headlamps on with windshield wipers feature. If the windshield
wipers are turned on, the exterior lamps will turn on with the headlamp
control in the autolamp position."
6769MOPARS is offline
Old 03-24-2012, 08:26 PM   #1175
Fuzzy Logic
Fuzzy Logic's Avatar
Fan#: 91597
What I Drive: 2012 White Plat Met Tri Ti HB
FF Reputation: 2 Fuzzy Logic Good Standing Member
a little update, i spent the whole day at my local ford service dept. having them look at my issue (seen below).
YouTube Video
the tech i was talking to was knowledgeable about the quirks of mft, though he'd never seen my exact issue.
he did what i couldn't do on my own and wiped the system and set it to what it would've been if it rolled off the assembly line with mft v 3.
short story, it worked.
i encourage ANYONE doing the upgrade to remove ALL prior voice tags.
also, a hard reset (disconnecting the batter for over an hour) WILL not work (at least not when i did it - and i disconnected the positive AND negative terminal).
if you still have voice tags set to your favorites, your dealer SHOULD be able to do a wipe, they did it with my focus.
lastly, ford knows about not being able to put spaces in names you give to favorites, they said they'll release an update to correct the issue... for now use "_".
hope this helps some people.
...SLOFOFO...
2012 Platinum White Tri-Coat Metallic Titanium
401A, Winter Package, Sport Package, Park Tech. Package, Power Moonroof, MFT/HD Sirius/Nav
Fuzzy Logic is offline
Old 03-24-2012, 08:42 PM   #1176
Krzydmnd
Fan#: 94963
What I Drive: 2012 Tuxedo Black Focus Ti
FF Reputation: 1 Krzydmnd Good Standing Member
all of my touch buttons turned red one day i turned the car on, i had to touch every single button on every page to reset them.
Krzydmnd is offline
Old 03-24-2012, 09:57 PM   #1177
mattphoto
Fan#: 95657
What I Drive: 2012 Black Focus SEL
FF Reputation: 1 mattphoto Good Standing Member
Here's a new one... and potentially a troublesome bug.
Neighbor knocked on my door just now, said I left my radio on.
I was home about 30 minutes after a drive.
I don't think I did anything out of the ordinary to cause this. I just listened to music over BT on the way home as usual, paused playback, turned off car, removed key... as usual. I don't recall seeing if the MFT went through the shutdown procedure or not. I just know what music wasn't playing after I hit pause.
Anyways, I went out right after he told me... saw immediately the MFT lit up. Hear the radio loud. No key in or anything. It went to HD radio, which the system will do by default. Low battery warning up in the driver's info panel.
Me, pissed as ever. Now worried one morning I'm not going to start my car because of a dead battery. Do I have to start walking out at night to make sure my radio doesn't come on automatically?
I don't think I have ever regretted a purchase this much in my life. I bought this car in hopes of having something I could rely on to get to work every morning, and now I have to worry about radio turning itself on and draining my battery in the middle of the night.
mattphoto is offline
Old 03-24-2012, 10:45 PM   #1178
Altis
Fan#: 89540
What I Drive: 2012 Sterling Grey SEL Hatch 5MT
FF Reputation: 1 Altis Good Standing Member
......now I have to worry about radio turning itself on and draining my battery in the middle of the night.
I've had this happen, too. I left my BT audio on a fairly high volume when parking at work. Could hear it thumping from inside the building. Took me 10 mins to realize it was my car. It started about 5-10 minutes after I got there.
Now I have an OCD habit of turning the volume down to mute most times I leave the car, in case it does it again. I've never had to do that before... As far as I know, though it's only done it the once, although since I mute the audio now, I can't be certain.
I like to think the battery level protection will kick in and prevent MFT from draining it flat... but then again, I also like to think the radio will stay off when I leave the car... Maybe it gets bored?
Altis is offline
Old 03-25-2012, 08:40 AM   #1179
lewisra
Fan#: 93289
What I Drive: 2012 Tuxedo Black SEL
Points 1,423, Level 21
Points: 1,423, Level: 21 Points: 1,423, Level: 21 Points: 1,423, Level: 21
Level Up 23% Completed
FF Reputation: 3 lewisra Good Standing Member
Was this after the update?
lewisra is offline
Old 03-25-2012, 08:47 AM   #1180
mattphoto
Fan#: 95657
yes.
