unalignalble lowered focus? my arse.... - Page 3 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Focus Tuning Chat
Old 10-12-2004, 10:16 AM   #21
whiteboyslo
whiteboyslo's Avatar
Fan#: 180
What I Drive: 04 Pontiac GTO - Yellow M6
FF Reputation: 2 whiteboyslo Good Standing Member
Buy-Sell-Trade Rating: (11)
they probably won't be able to pull the rear camber into spec, but everything else will be OK. being toe in or out is what really kills tires anyway.
Mike
just visiting now....
whiteboyslo is offline
Old 10-12-2004, 05:41 PM   #22
Ford Freak 9603
Fan#: 8593
What I Drive: 2003 Focus ZTS
FF Reputation: 1 Ford Freak 9603 Good Standing Member
You CAN NOT adjust the camber on a Focus from the factory. So they have no way of adjusting the rear camber. So you really should get the bolts. Having too much negative or positive camber will affect handling and tire wear. They are only $30 so it's not like they will cost you much. Why only do things half-a**? If your gonna lower your car, do it right.
-J
Ford Freak 9603 is offline
Old 10-12-2004, 06:52 PM   #23
dannyq
dannyq's Avatar
Fan#: 7183
What I Drive: 2001 FOCUS Sedan
FF Reputation: 1 dannyq Good Standing Member
Whats camber exactly? the mech told me today that my camber ( i think) is off by 0.5 of a degree and thats the best they can get. now the top of the tire is leaning in a bit, so is that camber? is 0.5 of a degree close enough or do you think i should buy the kit? will the kit fix this?
dannyq is offline
Old 10-12-2004, 07:26 PM   #24
mofocus
mefocuslongtime
mofocus's Avatar
Fan#: 5
What I Drive: Beltfed,extra pullified,weeemachine
FF Reputation: 6 mofocus Good Standing Member
Buy-Sell-Trade Rating: (17)
-J
half assed and buying things you dont need are two different things
MAY 2007 ROTM WOOT [/COLOR][/B][/U]
my dyno video
mofocus is offline
Old 10-12-2004, 08:01 PM   #25
Ford Freak 9603
Fan#: 8593
If you have a 2" drop with the Sportlines, you will need them. Did you lower your car to handle better? Because if you did, you need to get the bolts because too much negative camber is not good for handling. Read Below...
dannyq -
Originally posted from ozebiz.com
WHAT IS CAMBER?
Camber is the angle of the wheel relative to vertical, as viewed from the front or the rear of the car. If the wheel leans in towards the chassis, it has negative camber; if it leans away from the car, it has positive camber (see next page). The cornering force that a tire can develop is highly dependent on its angle relative to the road surface, and so wheel camber has a major effect on the road holding of a car. It's interesting to note that a tire develops its maximum cornering force at a small negative camber angle, typically around neg. 1/2 degree. This fact is due to the contribution of camber thrust, which is an additional lateral force generated by elastic deformation as the tread rubber pulls through the tire/road interface (the contact patch).
To optimize a tire's performance in a corner, it's the job of the suspension designer to assume that the tire is always operating at a slightly negative camber angle. This can be a very difficult task, since, as the chassis rolls in a corner, the suspension must deflect vertically some distance. Since the wheel is connected to the chassis by several links which must rotate to allow for the wheel deflection, the wheel can be subject to large camber changes as the suspension moves up and down. For this reason, the more the wheel must deflect from its static position, the more difficult it is to maintain an ideal camber angle. Thus, the relatively large wheel travel and soft roll stiffness needed to provide a smooth ride in passenger cars presents a difficult design challenge, while the small wheel travel and high roll stiffness inherent in racing cars reduces the engineer's headaches.
It's important to draw the distinction between camber relative to the road, and camber relative to the chassis. To maintain the ideal camber relative to the road, the suspension must be designed so that wheel camber relative to the chassis becomes increasingly negative as the suspension deflects upward. The illustration on the bottom of page 46 shows why this is so. If the suspension were designed so as to maintain no camber change relative to the chassis, then body roll would induce positive camber of the wheel relative to the road. Thus, to negate the effect of body roll, the suspension must be designed so that it pulls in the top of the wheel (i.e., gains negative camber) as it is deflected upwards.
While maintaining the ideal camber angle throughout the suspension travel assures that the tire is operating at peak efficiency, designers often configure the front suspensions of passenger cars so that the wheels gain positive camber as they are deflected upward. The purpose of such a design is to reduce the cornering power of the front end relative to the rear end, so that the car will understeer in steadily greater amounts up to the limit of adhesion. Understeer is inherently a much safer and more stable condition than oversteer, and thus is preferable for cars intended for the public.
Since most independent suspensions are designed so that the camber varies as the wheel moves up and down relative to the chassis, the camber angle that we set when we align the car is not typically what is seen when the car is in a corner. Nevertheless, it's really the only reference we have to make camber adjustments. For competition, it's necessary to set the camber under the static condition, test the car, then alter the static setting in the direction that is indicated by the test results.
The best way to determine the proper camber for competition is to measure the temperature profile across the tire tread immediately after completing some hot laps. In general, it's desirable to have the inboard edge of the tire slightly hotter than the outboard edge. However, it's far more important to ensure that the tire is up to its proper operating temperature than it is to have an "ideal" temperature profile. Thus, it may be advantageous to run extra negative camber to work the tires up to temperature.
-J
Similar Threads
Ford Focus - A History of Ford's C-Segment World Car Tom Ford Focus & General Car Chat 7 01-26-2010 09:47 PM
Australia gets the new Focus next month Kneel Ford Focus & General Car Chat 27 11-26-2007 09:17 PM
2008 Ford Focus US-Spec part 1 mitchlguzin Ford Focus & General Car Chat 9 01-08-2007 06:57 PM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
