Tricks to hold the crank pulley? - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 10-18-2011, 10:47 AM   #1
slow-cus
Fan#: 43472
Points 181, Level 3
Points: 181, Level: 3 Points: 181, Level: 3 Points: 181, Level: 3
Level Up 62% Completed
FF Reputation: 1 slow-cus Good Standing Member
I have searched for this, and most info is for taking the bolt out. I did a timing belt replacement on my 2003 ZX3 a week ago, and I have continued to be nervous whether or not the crank bolt is at a sufficient torque.
When I reassembled everything, I tighten the bolt w/ just a ratchet until the assembly started spinning, then zipped it for a quick second with an electric impact, to hope for a bit more snuggness. And I do mean a quick second - I was paranoid about damaging any seals/bearings around the crank.
I couldn't hold the bolt/pully still to check it w/ my torque wrench ( I think the haynes manual calls for 85 ft-lbs).
Any ideas - now that everything is assembled? I don't want to kick myself in the a$$ if this thing rattles apart during the cold of winter. Thanks in advance for your advice!
slow-cus is offline
Old 10-18-2011, 11:24 AM   #2
alex62390
BACON?
alex62390's Avatar
Fan#: 60434
Location: People's republic massivetwoshits, United States
What I Drive: 2004 svt focus EAP
FF Reputation: 22 alex62390 Great Standing Member
impact is good, just don't hold it for to long. i don't think its easily possible to damage the seals by over tightening. if you are really concerned you could have an assistant hold the ring gear while you torque the bolt.
2004 svt focus EAP #658
Former Hatch Nation #08
alex62390 is offline
Old 10-18-2011, 12:45 PM   #3
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,323, Level 51
Points: 6,323, Level: 51 Points: 6,323, Level: 51 Points: 6,323, Level: 51
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
I secured the pulley with a strap wrench and had a friend hold it in place (big friend) while I torqued it. Never had a problem after that.
2004 ZX3 MTX - Twighlight Blue
2001 ZX3 S2 ATX - JAN 2009 ROTM - SOLD
Moderator for [Ford Focus & General Car Chat][Ford Focus Non-Performance Discussions]
Hatch Nation #29_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 10-18-2011, 01:03 PM   #4
DEMENTED SVTF
PARTS HUNTER
DEMENTED SVTF's Avatar
Fan#: 71669
What I Drive: 2013 F150 FX2 5.0 SUPERCAB
FF Reputation: 9 DEMENTED SVTF Good Standing Member
Buy-Sell-Trade Rating: (18)
If its a stick have someone put the car in 3rdthe gear and have them hold the brakes then u can loosen or tighten the crank pulley. If its an auto i have no clue
2013 F-150 FX2 SUPERCAB 5.0 BRIGHT RED. HIDS, NAVIGATION
LEATHER, SONY 700WATT SYSTEM, 9.8 1/8 mile for now stock
DEMENTED SVTF is offline
Old 10-18-2011, 01:22 PM   #5
drostedrummer89
I <3 my SVT
drostedrummer89's Avatar
Fan#: 69059
What I Drive: 2002 Sonic SVT
Points 5,160, Level 46
Points: 5,160, Level: 46 Points: 5,160, Level: 46 Points: 5,160, Level: 46
Level Up 5% Completed
FF Reputation: 8 drostedrummer89 Good Standing Member
Buy-Sell-Trade Rating: (10)
I dont think an electric impact can damage the bolt or the crank. Whats the max torque it puts out? I would just gun it for a few seconds. If it doesnt spin then you're good. A strap wrench is a good idea also.
Matt
Posted via FF Mobile
drostedrummer89 is online now
Old 10-18-2011, 03:56 PM   #6
slow-cus
Fan#: 43472
Points 181, Level 3
thanks for the responses everyone! ...as for the power impact I used...I believe it was a Milwakee, good for neighborhood of 250 - 350 ft/lbs. I'll give the "put it in gear and hold the brakes" a shot...hopefully my clutch isn't too worn at 110K for that to work.
slow-cus is offline
Old 10-18-2011, 04:03 PM   #7
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
FYI the torque spec is only 85 ft. lbs., so don't go crazy on it. The in gear and standing on brakes method works well.
6SPD_soul is offline
Old 11-17-2012, 11:14 PM   #8
Novaxclio
Fan#: 99095
What I Drive: 2000, Bright Atlantic Blue, SE
FF Reputation: 1 Novaxclio Good Standing Member
Can definitely second that, I just finished replacing my timing belt (without timing tools :p hehe) and once everything was put back together, couldn't find a way to tighten the crank bolt to the 85ft-lb spec. I came across this post, went out to the garage and tried it and it worked like a charm! 3rd Gear + Break for the win! .
Thumbs up for start on first crank
Novaxclio is offline
Old 11-18-2012, 03:26 AM   #9
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 2,889, Level 32
Points: 2,889, Level: 32 Points: 2,889, Level: 32 Points: 2,889, Level: 32
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 2%
FF Reputation: 9 emsvitil Good Standing Member
There's 2 holes in the crank pulley for a pin wrench:
I just made one with 1/4" bolts and iron stock from home depot.
Ed
emsvitil is online now
