"How To" SVTF Short Shifter Install - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-08-2004, 06:26 PM   #11
WD40
The Librarian
WD40's Avatar
Fan#: 5157
8) Disassemble the shifter (cont):
Remove the other half (black plastic piece) of the pivot cup by pulling down on it with both hands.
WD40 is offline
Old 10-08-2004, 06:27 PM   #12
WD40
The Librarian
WD40's Avatar
Fan#: 5157
9) Clean all the parts to be transferred to the new shifter,
as the standard grease is different than what’s supplied in the kit.
The sum of an SVTF’s shifter’s parts.
Noted parts are what will be transferred to the new shifter.
WD40 is offline
Old 10-08-2004, 06:28 PM   #13
WD40
The Librarian
WD40's Avatar
Fan#: 5157
I’m not going into much detail on the installation process.
If you are able to get this far successfully, you’ll most certainly be able to put everything back together.
However, there’s a few hints I found that I’ll pass along for the installation process.
Use the supplied lube liberally when assembling the parts on the new shifter.
There were 2 tubes in the kit I received. It’s icky sticky gooey stuff, but it works exceptionally well.
WD40 is offline
Old 10-08-2004, 06:29 PM   #14
WD40
The Librarian
WD40's Avatar
Fan#: 5157
1) I removed the plastic shift lever from the housing, lubed the shaft, as well as the noted areas in pic.
WD40 is offline
Old 10-08-2004, 06:30 PM   #15
WD40
The Librarian
WD40's Avatar
Fan#: 5157
2) Before I even started the process,
I covered both seats with towels to avoid unwanted “foreign substance” intrusion onto the fabric or leather.
WD40 is offline
Old 10-08-2004, 06:30 PM   #16
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Enough already. Let’s get that thing installed!
OK, I was feeling a bit goofy at this point, and it was getting late.
WD40 is offline
Old 10-08-2004, 06:31 PM   #17
WD40
The Librarian
WD40's Avatar
Fan#: 5157
3) Clean the mounting area well before putting the shifter in.
Don’t forget to put the supplied spacer in place before you lower the shifter into it’s new home.
WD40 is offline
Old 10-08-2004, 06:32 PM   #18
WD40
The Librarian
WD40's Avatar
Fan#: 5157
4) Using a 5mm 3/8 drive allen head socket, I torqued the bolts to 96 in-lbs (8 ft-lbs).
Use a criss-cross pattern as if you were torquing wheel lug nuts.
WD40 is offline
Old 10-08-2004, 06:33 PM   #19
WD40
The Librarian
WD40's Avatar
Fan#: 5157
5) Make sure you lube the cable pivots on the shifter, before installing the cables.
6) This pic shows how I used the screwdriver to pop the inner cable back on the shifter.
I was able to install the outer cable by using both my hands to pop it back on.
WD40 is offline
Old 10-08-2004, 06:35 PM   #20
WD40
The Librarian
WD40's Avatar
Fan#: 5157
All right….there you go! Enjoy that new shifter!
My fingers are tired from typing all this up.
I sure hope this is a help for those folks that will attempt doing the install.
Total R&R time should take just over an hour.
Took me quite a bit more than that, since I was taking pics and writing notes.
WD40 is offline
Similar Threads
"How To" - Cutting the Stock shifter microtonal General Technical Chat 114 03-31-2013 03:49 PM
Ebay short throw shifter install guide netdrgoon General Technical Chat 6 03-31-2012 03:46 PM
Focus SVT OEM shifter with bolts! great for short shifter project! zx3zetec Archive 1 04-12-2010 12:50 PM
short shifter problem totalfocus ZETEC Performance (2000-2004) 3 03-21-2005 03:33 PM
my short throw shifter thoughts QuikHAtCH MK1 Interior Mods & Upgrades 3 01-22-2005 10:07 AM
