"How To" SVTF Short Shifter Install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-08-2004, 06:18 PM   #1
WD40
The Librarian
WD40's Avatar
Fan#: 5157
SVTF Short Shifter - Install Pics
Got it! Works great! Nice crisp improvement in the SVTF’s shifting abilities.
I acquired mine from NorthCoast Performance (very nice folks to deal with) for $84.95 + $5.00 shipping and handling.
It’s actually the Ford Racing Performance Parts shifter, which others have noted, is the same unit as the Steeda.
With the good reviews I received for my VF Engineering Rear Mount-Install Pics thread,
I decided to put together another one for the short shifter.
It appears after reading about the trials and tribulations of others in doing the STS install,
that the removal of the stock shifter and components is the hardest part.
For this reason, the concentration of this write up will fOCUS on the removal process.
You’ll also note, I was able to do this install without having to remove the entire console,
which also appears to be a “bone of contention” with previous installers.
Here’s the FRPP (Steeda) short shifter kit.
WD40 is offline
Old 10-08-2004, 06:19 PM   #2
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Here’s the before (left) and after (right) pic showing the difference in the shifters.
Stock height was 7-3/4”, and the STS is 6-3/8”
WD40 is offline
Old 10-08-2004, 06:20 PM   #3
WD40
The Librarian
WD40's Avatar
Fan#: 5157
These are all the tools I utilized for the removal and installation.
Missing in the pic, is the 3/8 to 1/4 drive adapter for the Torx bit.
WD40 is offline
Old 10-08-2004, 06:21 PM   #4
WD40
The Librarian
WD40's Avatar
Fan#: 5157
With that…..on with the STS install.
Have a cup of coffee. This is going to be LONG.
Note: You’ll see I used the word gently several times.
If you have to force it, take a deep breath, and come back to it in a little more relaxed manner.
1) Remove the shift boot:
At the rear of the boot, with your left hand, push in and pull up on the boot,
while with your right hand, gently push in and pry up with a screwdriver.
Pull the boot up and over the shifter. There’s no need to remove it completely.
WD40 is offline
Old 10-08-2004, 06:22 PM   #5
WD40
The Librarian
WD40's Avatar
Fan#: 5157
2) Remove the shift knob:
Using a 17mm open end wrench, unscrew the shift knob.
You’ll see there’s “flats” for this purpose cast into the base of the knob.
WD40 is offline
Old 10-08-2004, 06:23 PM   #6
WD40
The Librarian
WD40's Avatar
Fan#: 5157
3) Remove the center console trim piece:
Pull it up at the front first, till it unsnaps from the console, then grab both sides at the back, and pull up.
Remove the 3 connectors for the seat warmers and traction control if so equipped.
You can see by the pic, that you squeeze on the top portion, and pull out from the sockets.
All 3 connectors have unique fitments, so there’s no worries of getting them confused upon reinstallation.
WD40 is offline
Old 10-08-2004, 06:23 PM   #7
WD40
The Librarian
WD40's Avatar
Fan#: 5157
4) Remove the 2 shifter cables:
Place the shifter in 1st gear.
Remove the inner cable directly underneath the shifter by gently prying it off with a screwdriver.
Use the same method to remove the outboard shift cable.
WD40 is offline
Old 10-08-2004, 06:24 PM   #8
WD40
The Librarian
WD40's Avatar
Fan#: 5157
5) Remove the 4 Torx bolts holding the shifter:
Use a T-30 bit and a 3/8 drive ratchet. Firmly press down as you break the bolts loose, then turn them out.
They will be hard at first, as LocTite was used to secure them.
I broke them all loose first, then turned them out in a criss-cross pattern, as you would with wheel lug nuts.
Once all the bolts are removed, carefully extract the shifter taking care not to catch the cables.
WD40 is offline
Old 10-08-2004, 06:25 PM   #9
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Now, set up a nice clean area on your work bench to work on the shifter itself.
Have some rags handy, because your hands will get greasy.
6) Remove the shifter from the shift housing:
Push the shifter out and to the right as shown, and then remove the plastic clip by gently pulling it off.
WD40 is offline
Old 10-08-2004, 06:26 PM   #10
WD40
The Librarian
WD40's Avatar
Fan#: 5157
7) Disassemble the shifter:
Remove the rubber sheath by pulling it off over the pivot cup. Remove the plastic white half of the pivot cup.
WD40 is offline
Similar Threads
"How To" - Cutting the Stock shifter microtonal General Technical Chat 114 03-31-2013 03:49 PM
Ebay short throw shifter install guide netdrgoon General Technical Chat 6 03-31-2012 03:46 PM
Focus SVT OEM shifter with bolts! great for short shifter project! zx3zetec Archive 1 04-12-2010 12:50 PM
short shifter problem totalfocus ZETEC Performance (2000-2004) 3 03-21-2005 03:33 PM
my short throw shifter thoughts QuikHAtCH MK1 Interior Mods & Upgrades 3 01-22-2005 10:07 AM
