2001 Auto transmission problems help! - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-30-2012, 11:16 AM   #11
Johninmass
Fan#: 90790
What I Drive: 2001,White,Focus
FF Reputation: 1 Johninmass Good Standing Member
Where is the Transmission Fluid Temp (TFT) sensor located?
Johninmass is offline
Old 09-30-2012, 10:13 PM   #12
RuffnRider77
Fan#: 97528
What I Drive: 2012 Red Candy Focus SE
FF Reputation: 1 RuffnRider77 Good Standing Member
I have seen a fair amount of internal harnesses in the trans causing it to do this style concern as well as possible taking the solinoid out, the tft is loacated int the trans in the valve body, usually when it gets hotter it will change the resistance of the wires and cause these faults. I could be incorrect just saying from my experince its a slightly less expensive try than a whole tranny.
Low Life
RuffnRider77 is offline
Old 10-01-2012, 04:58 AM   #13
amc49
Fan#: 96610
Points 3,267, Level 35
Points: 3,267, Level: 35 Points: 3,267, Level: 35 Points: 3,267, Level: 35
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 7%
The TFT sensor is located right on the filter IIRC.
I've heard from trans techs that 4F27E has valve body wear problems that are pretty common. Meaning simply changing solenoids ain't gonna do it all the time.
I have not run into it on these but my previous Contour would disable OD when a spark plug wire got bad enough and the engine performance really did not reflect it either, no missing that I could perceive. I simply changed plugs and suddenly no OD. Found out and change wires and then OD is back. I guess I damaged a wire pulling them. Wonky...........
amc49 is offline
