2001 Auto transmission problems help! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-12-2011, 05:48 PM   #1
Johninmass
Fan#: 90790
What I Drive: 2001,White,Focus
FF Reputation: 1 Johninmass Good Standing Member
I have a 2001 focus that after a while of driving will not go into overdrive. At 45 or over I can put in neutral then back in drive and sometimes it will shift into overdrive. Sometimes the engine light will come on give code P0761 (Solenoid C) Also the tranny will overheat the " ! " light will come on the car is then stuck in limp mode 2nd only. After it cools down for a couple of hours it shift normal again till it gets hot again. Now I have done a fluid flush, new Shift Solenoids A,B & C, also new filter. After changing solenoid C the engine light still came back on code P0761. Anyone have any ideas I need help and can't afford a trip to the Tranny shop? When it is cold it shifts great.
Johninmass is offline
Old 10-12-2011, 10:48 PM   #2
DueceCoupe
DueceCoupe's Avatar
Fan#: 32955
What I Drive: 07 Infra Red ST,2002 ZX3.
Points 7,298, Level 56
Points: 7,298, Level: 56 Points: 7,298, Level: 56 Points: 7,298, Level: 56
Level Up 74% Completed
Forum Activity 2%
FF Reputation: 5 DueceCoupe Good Standing Member
Buy-Sell-Trade Rating: (29)
Was the fluid flush before or after the problems started?
Fluid level is perfect?
I know jack about the tranny's our Cars have,but hope this bumps your thread so someone can Help You.
Also,welcome to the Forums!
Even if You don't stick around on the forums,please keep this thread updated till the problem is resolved as it Helps others in the future.
I used to be DueceCoupe,but now I gots a 4 door!
ST Crew Member # 666
DueceCoupe is offline
Old 10-13-2011, 07:45 PM   #3
BlueOvalWRC
BlueOvalWRC's Avatar
Fan#: 89573
What I Drive: '04 Vermilion Red SE Wagon 2.0 AT
FF Reputation: 3 BlueOvalWRC Good Standing Member
This explains how the 4F27E functions so it might help: http://www.atsg.biz/dyndata/articles...%20June-04.pdf
Wagons of the World #22
ZETEC Crew #373
BlueOvalWRC is offline
Old 10-16-2011, 07:51 AM   #4
Johninmass
Fan#: 90790
Thanks for the link. Does anyone think it's the EPC solenoid?
Old 10-17-2011, 09:11 AM   #5
BlueOvalWRC
Fan#: 89573
You could give these guys a call and see if a complete valve body might be the solution. Lentech
ZETEC Crew #373
Old 11-09-2011, 06:04 PM   #6
Johninmass
Fan#: 90790
Still working on problem. Anyone have any other ideas.
Old 11-10-2011, 01:23 PM   #7
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
Points 1,725, Level 24
Points: 1,725, Level: 24 Points: 1,725, Level: 24 Points: 1,725, Level: 24
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 10%
FF Reputation: 5 Miller88 Good Standing Member
The ! could be an indication of a transmission malfunction - not an overheat (from what I understand).
Have you looked into the solenoids yet?
Miller88 is offline
Old 11-10-2011, 11:01 PM   #8
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Good article referenced.
The "!" can indicate ATX fluid overheated, SPI engine (means something else on ZETEC), or a speed sensor failing - which combined with your ATX starting off in 2nd may be a strong case for the OSS.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 09-14-2012, 02:41 PM   #9
Johninmass
Fan#: 90790
Still need ideas if anyone can help.
I'm about to replace the whole tranny with a used one. $200 with 90K on it.
Old 09-14-2012, 03:56 PM   #10
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,576, Level 30
Points: 2,576, Level: 30 Points: 2,576, Level: 30 Points: 2,576, Level: 30
Level Up 84% Completed
Forum Activity 8%
It could be the Transmission Fluid Temp (TFT) sensor.
(or the wiring to it)
The CPU won't let the car get into 4th gear if it's too cold
It won't lock up the converter if it's too hot.
If it gets too hot, it will enter a pre-set shift mode, disable the lockup in 2,3,4 gears, and turn on the dash light
elsolo is offline
