stainless steel brake lines - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Brakes, Suspension & Body Chassis
Old 11-04-2003, 03:07 PM   #1
blackandgold
blackandgold's Avatar
Fan#: 495
What I Drive: 2008 VW GTI 2006 Ford Explorer LTD
FF Reputation: 1 blackandgold Good Standing Member
I have seen these sold at some places. Are they worth the money?? Does it really cause your brakes to help you stop sooner?? thanks for replies
ae86
Originally posted by focusfreak03
^ what the hell is that supposed to mean, you quote me and then put down some american eagle sh**
blackandgold is offline
Old 11-04-2003, 06:02 PM   #2
Chucko
Fan#: 1098
What I Drive: '03 5-door SVT Focus, '89 Mustang 5.0
FF Reputation: 1 Chucko Good Standing Member
Stainless braided brake lines make the pedal firmer, by reducing flex and ballooning. Some people may not like the feel - the pedal hardly moves as you push harder on it. It can be tricky to modulate the brakes if you're used to the normal flex. But I like the firmer feel.
They do have to be checked more frequently than standard rubber brake hoses.
If you switch to stainless, do the whole car at once. I got cheap and only did the fronts at first. I wound up with rear brakes that came on slowly and let go slowly. I don't recommend it!
'03 CD Silver SVT Focus 5-door, #2001 of 2173
(and a '89 Mustang 5.0)
Chucko is offline
Old 11-05-2003, 11:14 AM   #3
TORQUERULES
The Professor
Fan#: 1083
What I Drive: '13 Mazdaspeed 3; '87 'Stang
FF Reputation: 9 TORQUERULES Good Standing Member
I've got'em on my Mustang. What he says above is true.^^^^ They are firm, but work. Last longer too.
TORQUERULES is offline
Old 11-11-2003, 12:21 AM   #4
Katulec
Katulec's Avatar
Fan#: 1497
What I Drive: 2003 French Blue ZTS
FF Reputation: 1 Katulec Good Standing Member
how and how often do you clean the lines?
'03 Focus ZTS
Performance: FC Header w/ flex | Magnaflow 2.25" w/ extra resonator| AEM CAI | FC TB | FC UDP
Show :: Painted Interior
Suspension :: Strut Tower Brace
Projects on hold for a while until I decide where to go next.
Working at a Ford Dealership.
AIM: Katulec
Katulec is offline
Old 11-17-2003, 02:15 PM   #5
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
If your question is how often you should flush your brake lines the answer is in the owners manual. I would however suggest that if you reside in a very humid area to do it more frequently. Brake fluid attracts water. The water will vaporize when heated an will reduce performance and at worst could result in severe fading (a temporary no brake condition). Brake fluid contminated with water can also corrode brake part internals quickly. Using a quality fluid (not a racing fluid...they even attract more moisture!) is the first step. I used Castrol LMA (stands for low moisture absorbtion) on a prorally car with very good results. I did not have to completely flush my system after every event like my buddies who used racing fluids did. I never experienced fading with this fluid even under some pretty harsh use and conditions. Ford heavy duty truck fluid is remarkably good. It has a high boiling point, has low water absorbtion characteristics and is cheap.
Geezer is offline
Old 11-17-2003, 07:22 PM   #6
whiteboyslo
whiteboyslo's Avatar
Fan#: 180
What I Drive: 04 Pontiac GTO - Yellow M6
FF Reputation: 2 whiteboyslo Good Standing Member
Buy-Sell-Trade Rating: (11)
probably bc the ford heavy duty stuff is DOT5 (i'm guessing here). just one more not regarding brake fluid, DON'T USE AN OPENED CONTAINER! for example, you buy the really big container to top off now because you figure you could use some later. WRONG! after it's been sitting on your shelf without the little seal on it, it will get moisture in it! throw it out and get new fluid.
Mike
just visiting now....
whiteboyslo is offline
Old 11-17-2003, 07:55 PM   #7
Katulec
Katulec's Avatar
Fan#: 1497
kindofa just for the heck of it question: what if you reseal it? would the moisture already exposed to it and moisture trapped inside ruin all of it?
'03 Focus ZTS
AIM: Katulec
Katulec is offline
Old 11-18-2003, 02:08 PM   #8
whiteboyslo
Fan#: 180
if you were to cover the opening with some saran wrap or something and then put the lid on... i guess. but how much is a bottle of brake fluid. $2 or $3 for some dot3, right? just be safe and throw it out IMO
Mike
Old 11-18-2003, 02:29 PM   #9
garyk
Guest
Fan#: 171
What I Drive: focus race car, stock svt street ca
FF Reputation: 1 garyk Good Standing Member
ss lines
you can get them from steeda, bat or a no. of other places.
garyk is offline
Old 11-18-2003, 06:54 PM   #10
Chucko
Fan#: 1098
You can use racing brake fluid on the street IF you change it frequently. Most racing brake fluid will have a very high dry boiling point, but a mediocre wet boiling point - and the wet BP is the one that matters when the fluid gets old.
If you run track events where the brakes will see a lot of use (i.e. running laps on road courses for 20 minutes at a time), flush and fill the brake system with fluid from brand new, factory sealed cans just before the event. This is the only way you can be sure of having good dry fluid in the system. A long brake pedal is no fun when you're approaching a hairpin turn at triple-digit speeds. It would be a good idea to flush it again when you get back home - or even before you leave the track.
No matter which fluid you use, or how hard you drive, it's probably a good idea to flush the brake fluid at least as often as you change pads.
Chucko is offline
Similar Threads
Russell Stainless Steel Brake lines for ZX3 fixshun Archive 2 05-25-2006 12:39 PM
For Sale: New Russell Stainless Steel Brake lines for ZX3 island_boy49 Archive 9 05-20-2006 12:43 AM
2000-03 Ford Focus SVT Stainless Steel Brake Lines (New in Box) *SOLD* A4 - Oh Snap Archive 5 07-11-2005 04:29 PM
stainless steel brake lines mrorange7878 Wheels & Tires - Sponsored By Tire Rack 7 05-04-2005 02:02 PM
Stainless steel brake lines reviews? Jason C SBB Wheels & Tires - Sponsored By Tire Rack 1 04-14-2005 09:42 PM
