Can I use taurus winter rim/tire for 2012 focus - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-09-2011, 09:45 AM   #1
malanfan
Fan#: 65812
What I Drive: 04 RX8 GT/07 ZX5 SES/12 HB TI
Points 124, Level 2
Points: 124, Level: 2 Points: 124, Level: 2 Points: 124, Level: 2
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 1 malanfan Good Standing Member
I have set of winter tires mounted&balanced on mags from 2006
Taurus. Size is 215/60/16. The tires are new only one season. Can I use it for the Titanium replace 235/40/18.
Stock Tire - 235/40R18
Section Width: 9.25 in 235 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range:8 - 9.5 in
Overall Diameter:25.40 in 645.16 mm
Sidewall Height:3.70 in 93.98 mm
Radius: 12.70 in 322.58 mm
Circumference: 79.79 in2026.6 mm
Revs per Mile: 818.8
Actual Speed: 60 mph 100 km/h
Speedometer Difference: -
Diameter Difference: -
Tires Tire 1 - 215/60R16
Section Width: 8.46 in 215 mm
Rim Diameter: 16 in 406.4 mm
Rim Width Range:5.5 - 8.5 in
Overall Diameter:26.15 in 664.21 m
Sidewall Height:5.07 in 128.77 mm
Radius: 13.07 in 331.97 mm
Circumference: 82.15 in 2086.6 mm
Revs per Mile: 795.4
Speedometer1: 58.2 mph 97.1km/h
Speedo Difference: 2.941% too slow
Diameter Difference: 2.87%
malanfan is offline
Old 10-09-2011, 02:06 PM   #2
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
In this case its not as much about tire size (both are reasonably close per your numbers) but more about wheels. Naturally the taurus wheels must have the same bolt pattern and dimensions and the wheel offset should be close as well. Since you already have the wheels and tires, a test fit seems to be the easiest solution.
Geezer is offline
Old 10-11-2011, 08:45 AM   #3
28HopUp
28HopUp's Avatar
Fan#: 85449
What I Drive: 2012 SE 5-door
FF Reputation: 3 28HopUp Good Standing Member
Yes, OEM wheels for a 2006 Ford Taurus will fit. Here is a link to the type of wheels I bought for my winter tires.
http://cgi.ebay.com/ebaymotors/16-OE...item3a57dd3939
And here is a link showing the pictures with the 205/60R16 Blizzak WS70 tires mounted on the new rims with TPMS sensors -
http://www.focusfanatics.com/forum/s...&postcount=126
Your tires are slightly taller than mine, so you should test fit them on the car to be sure. But you will probably be OK to use 215/60R16 tires, despite them being 0.75" more in overall diameter than your stock tires. Just remember that your speedometer will be reading slower than you are actually going.
Bill Jr.
28HopUp is offline
Old 10-25-2011, 09:48 AM   #4
malanfan
Fan#: 65812
Points 124, Level 2
Here is the pictures with the Ford tuarus mags and winter (215/60-16) tire.
malanfan is offline
Old 10-25-2011, 10:08 AM   #5
28HopUp
28HopUp's Avatar
Fan#: 85449
Those look great!
Bill Jr.
28HopUp is offline
Old 10-25-2011, 03:00 PM   #6
red2009se
Guest
Fan#: 79513
What I Drive: car
FF Reputation: 1 red2009se Good Standing Member
They look better on Focus than older Taurus. Ford dealer nearby used to have tons of used Taurus rentals with these rims, so there's plenty to find.
red2009se is offline
Old 07-05-2013, 01:39 PM   #7
Alexleblanc
Alexleblanc's Avatar
Fan#: 114169
What I Drive: '13 F250 XLT 6.7/'13 Focus Hatch SE
FF Reputation: 1 Alexleblanc Good Standing Member
i'm going to pick up a set of the 2006 Taurus wheels for 100$ tonight. Good excuse to go for a drive in the new Mustang too!
DD - '13 Focus SE 5door
Tow Vehicle - '13 F250 XLT 6.7
Toys - '89 Scirocco 16v / '80 Camaro Z28 / '37 Plymouth Coupe / '11 JD 1123E / '14 Mustang GT
Alexleblanc is offline
Old 07-05-2013, 04:43 PM   #8
TheBigMortboski
TheBigMortboski's Avatar
Fan#: 115429
What I Drive: Kenworth T-800
Points 50, Level 1
Points: 50, Level: 1 Points: 50, Level: 1 Points: 50, Level: 1
Level Up 50% Completed
FF Reputation: 0 TheBigMortboski Newbie
This might be sort of a thread jack, but does anyone know if 15s will fit on an SE with rear discs? I've got some snow tires from our old Hyundai that would work, but no matter how hard I try, I can't stretch them enough to fit these 17" wheels I've got.
TheBigMortboski is offline
Old 07-09-2013, 12:31 PM   #9
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,052, Level 67
Points: 10,052, Level: 67 Points: 10,052, Level: 67 Points: 10,052, Level: 67
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
Forum Activity 23%
Activity: 23% Activity: 23% Activity: 23%
The rear brakes are smaller than the front brakes on the Focus, and the base Focus S with it's 15" wheels clears the front calipers just fine. You can't go any smaller than this on the stock brakes.
With the Focus ST you can't go any smaller than 16" wheels as the front rotors are 12.6" dia vs 10.9 or so for the front of the n/a. The rear disks are just 10.7" diameter so the 15" wheels should also clear the rear brakes.
You would need wheels with the proper bolt pattern though.
suss6052 is online now
Old 07-12-2013, 02:04 PM   #10
Alexleblanc
Fan#: 114169
picked up the Tauru wheels for 100$ and just scored a set of 205/60R16 Studded Goodyear Nordics for 200$ - 1500 km's on them. I'm in it for 300$ and i'll have a set of steelies from the tires that i can sell to pay for the tire install. Talk about getting away cheap!
